Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
These are off the car, so the piston hasn't been pushed back in yet 🤣
But when I did it last time, yes, I popped them off. Mine didn't break.
My stupid question, is what exactly did you do to remove them? Perhaps my weekly car wash/wheel cleaning routine has actually come back to bite me. . . :cautious:
Acadia18
Rhode Island
2019 Golf R
Tapped them with a hammer and punch from behind, gently.
JTM88
Tulsa, OK
2016 GTI
Is it normal for there to be more soot after installing an upgraded turbo? I have way more soot on the back of my car than I ever did on stage 1 or 2.
supergrine
CT
From what I understood is that a bit of grease always comes out like that? I did as he said lol, cleaned it and will check it out again in a few months.... Ill need to do the haldex in a few months, so I will also ask my indy shop then....
Is yours like that too? coming out of the axle itself where it joins the transmission case, not from the cv boot? I have had a CV boot tear and leak grease everywhere but never this way....
My issue is described best in these pictures, while up on a lift during oil change. One of the bolts isn't fully tightened. Back in about Sept 2021, I replaced my front wheel bearings, so the loose bolt might be a result of poor worksmanship.
How bad does this look in terms of urgency to fix?
GTI Jake
Charlotte, NC
Do NOT drive till those are properly torqued
berserker6
South Jersey
2018 Golf R
I don't know the answer but I'm reviving your question in the hope someone with more knowledge answers and I can learn some more shit. Did you change your tune?
JTM88
Tulsa, OK
2016 GTI
No answer yet, I’m not super concerned about it since I have a custom tune and everything looked good in the logs.
Subliminal
Vegas
Slow FWD VW Hatch
I haven't upgraded my turbo but I remember soot being the worst when the car (and turbo) was brand new so it might be related? At the time it seemed like it got better after I got a muffler delete but in hindsight maybe it was just the turbo getting fully broken in
GTIscream
MA, USA
GTI Mk7.5
Stupid question: just about every site i've looked at says NGK 95125 Ruthenium HX plugs are NOT compatible with a 2020 GTI. Why? They only support up to a 2018 according to Rock Auto and others.
The OEM plugs are part # 06K905601K (iridium?). VW's website recommends the previous revision 06K905601D (platinum?) for the 2018 GTI. But when i put in the 06K905601K plug for the 2018 it says they are fine.
i can't assert transitivity in spark plugs, but it kind of seems if a 2018 can take the ruthenium plug or a 06K905601D or a 06K905601K and a 2020 takes a 06K905601K...
GTIscream
MA, USA
GTI Mk7.5
Same motor. Same plugs work.
Thanks. That's what my brain told me, but when i see that red banner saying not compatible i sometimes second guess.
Better stupid question: i don't need to change my plugs for three more years, why am i wasting my time looking something like this up???
EpicTech
Houston
MK7 GTI 6sp w/PP
car-guy phobia/preventative maintenance
swcrow
7.5 GTI/'29 Ford
anyone with experience on DSG tunes.......regular DSG tune vs BT DSG tune (does this even exist?)
manu97
Chicago
MK7 R
Might change the shift points to be higher to take advantage of the bigger turbo - pretty sure EQT has a different tune for bigger turbos
