krs
Las Vegas, NV
MKVIIS R
How long do y’all’s front wipers last? 6 mo and mine are starting to fail and leave streaks
Do you clean the actual rubber blade? Pretty much every time I do a detail on my car I clean the blade with a rag and Windex, or rubbing alcohol.
I replace mine annually.
swcrow
7.5 GTI
I've never cleaned mine with rubbing alcohol.....interesting. I'll try that and see if it helps.....if not, I'll replace and institute that methodology
CaptainRatty
Winston-Salem, NC
MK7 GTI
3+ years on my Bosch Icons, but my car is garaged most of the time. I do however, use the shit out of my windshield wiper fluid.
Dameon
How do I access inside the rear door where the window mechanism would be? I popped the door card loose hoping to vacuum out all the broken glass from a smashed window but the Only way I could see was to drill the speaker out? Wife’s 2018 Tiguan if that makes a difference but I'm assuming they’re similar.
MonkeyMD
TSI 1.8 Alpha
Canada
2017 mk7 1.8 TSI Gol
So I had similar issues with APR coils, two of the four went bad and were causing misfires. Did a big shuffle of apr and oem coils until the second one went. When it went cyl 3 would just constantly misfire, even at idle. Had the packs maybe 7k miles, oems had 50k and are still going strong.
If you have your stock coils, swap one to cyl 3 or whatever misfire cylinder you're having and see if it goes away.
Got mine from FCP, so at least I can send them back.
I am an idiot. Spark plugs weren't tight enough. Been good for a week now.
swcrow
7.5 GTI
Need to start gathering replacement pads/rotors for my TT RS front bbk.......anyone have experience with Paragon? They offer 2 piece floating for 1150
or Girodisc.....they offer same type of floating for about the same.
  • Wow
Reactions: krs
manu97
Chicago
MK7 R
I bought Girodisc replacements for the ST40 Kit I had. Easy enough to follow, they suggested a wicking, Red loctite for the hardware, and included fresh hardware. Install was easy enough, but you may need a baby (1/4") torque wrench.
swcrow
7.5 GTI
So I’m moving from OEM rotors to Giro disc, so I’m assuming they will come pre-assembled. I need to verify with them about that.
manu97
Chicago
MK7 R
Oh if they're direct replacements, they should be coming assembled.
But even if they don't, instructions are clear enough that a 6 year old with some patience could do it.
swcrow
7.5 GTI
awesome...lol....thanks!
Still rocking that ST40? How is it?
manu97
Chicago
MK7 R
ST40 is gone, unfortunately. Took it off the GTI when I sold that one, and now am waiting for a 355mm one to pop up in the classifieds.
Loved it though, no complaints. Porterfield R4S pads were also quite nice.
Anthony3o55
South FL
Saw this today since I have everything gutted except the carpet on sides. Pull one back and saw this. I know its supposed to b black. Is that mold? I assume it is. The piece is ruined. What material is this? It’s like a sponge. Can I order a sponge like this and glue it on. Or rove it e
