JTM88
- Broken Arrow, OK
- 2016 GTI
Holding backup on the ground stud to remove the ground nut.Which part are you having trouble with? The ground stud, the clip, or pulling the coil itself?
Have a deep socket? Tends to be the easiest way to get the ground stud out.Holding backup on the ground stud to remove the ground nut.
I use one from this set I got,Holding backup on the ground stud to remove the ground nut.
I think you miss understand, I need a recommendation for a thin wrench to hold the stud so I can remove the grounding nut that is on top.Have a deep socket? Tends to be the easiest way to get the ground stud out.
needle nose pliers wouldn't do the job?I think you miss understand, I need a recommendation for a thin wrench to hold the stud so I can remove the grounding nut that is on top.
Crack the windows until it goes awayany tips on what'll clear it?
Yeah did seem to make it worse at times.If it's on the outside - the front defroster may be hurting rather than helping
Was raining pretty hard unfortunately.Crack the windows until it goes away
You gotta blast the heat.Anyone know how to fix a windshield that won't de-fog? Got the front defroster on, AC, no recirc, and still it never clears. Goes away briefly with wipers and then comes back. I assume it's something on the outside, any tips on what'll clear it?
https://www.weathertech.com/volkswa...rE0CNA6EFHQ0e9GDim-uY958lswCspDRoCgi4QAvD_BwEYeah did seem to make it worse at times.
Do you use rain-x? I had terrible fogging on my mk6 after using it. It was only a problem at night with really wet/humid conditions. 0 problems since switching to aquapel.Anyone know how to fix a windshield that won't de-fog? Got the front defroster on, AC, no recirc, and still it never clears. Goes away briefly with wipers and then comes back. I assume it's something on the outside, any tips on what'll clear it?
I use bicycle wrenches for these situations like:I think you miss understand, I need a recommendation for a thin wrench to hold the stud so I can remove the grounding nut that is on top.
