cb1111
Newbie
- Virginia, USA
This guy has you beatI made it all the way home an hour from the track with it under the car.
Pretty sure they're brand specific.Are Cobb Access ports generic across all lines? Like say you get one from a totaled Subaru, can you upload an EQT tune to it and use it in ours? Or are the access ports, like, serialized for manufactures?
No. They’re model/platform specific.Are Cobb Access ports generic across all lines? Like say you get one from a totaled Subaru, can you upload an EQT tune to it and use it in ours? Or are the access ports, like, serialized for manufactures?
Well then! Was hoping to broaden the used marketNo. They’re model/platform specific.
So, this little bracket that holds the brake line to the knuckle... Does anybody know the size of the bolt that attaches to the knuckle? Or a part number? I've seem to have lost one...
Remove the other one and measure it.
Just visually inspecting it is the easiest way to know when to clean it. There's no set mileage due to the environment you drive in. An example is in Phoenix because of how dry and dusty it is it would need to be cleaned more frequently.how often should I clean or replace the filter(s) of aftermarket air intake?
I rotate it 180 degrees after 2500 miles. Then after another 2500 miles I toss it and get a new onehow often should I clean or replace the filter(s) of aftermarket air intake?
Dry cone filters, never saw one I ever wanted to run longer than 5k milesYou know we're talking about aftermarket reusable filters, not underwear, right?
I thought you had an aftermarket air intake with reusable filter?Dry cone filters, never saw one I ever wanted to run longer than 5k miles
Yes. I do. But the cone filter is garbage. They all are. I like the Cobb oiled filter. I’ll run that one for 10-12k miles for sure. But the dry ones suck, their filtration rate tanks little by little.I thought you had an aftermarket air intake with reusable filter?
How much does it cost? My AEM dry flow is somewhere around $40 for a replacement. Too expensive to toss.Yes. I do. But the cone filter is garbage. They all are. I like the Cobb oiled filter. I’ll run that one for 10-12k miles for sure. But the dry ones suck, their filtration rate tanks little by little.
