Gonna take a screenshot of that….Nope. I’m really happy how it is right now, exactly how I envisioned it.
lies and slander
Can you hear if the pump is running but maybe the nozzles are plugged up?My front washer pump doesn't work. The wipers work when I pull the stalk. The rear pump still works. Where do I start with troubleshooting? I can't find a fuse.
I used one the other day on a friends car. it had a polar bear on the container. I don't know if that's a good one or not but it did workAny of you guys used one of those auto parts store AC rechargers? If so, which one do you recommend and how well did it work? My AC seems to have a leak and my mechanic wanted me to replace the compressor last year. He recharged it and it lasted a while, though I wasn't driving the car much. It seems to be out of juice again and I don't want to spend the dough to replace the compressor so I figure I'll recharge until it doesn't take.
Was it pretty straight forward/easy to use? That is good to know it worked. Thanks!I used one the other day on a friends car. it had a polar bear on the container. I don't know if that's a good one or not but it did work
Just ordered, was it just a "pop the old one out and pop the new one in" install?I believe it was this one. It was not from deautoled. It is a complete assembly, not a replacement bulb. I load up seats down a lot at night and it's a great help.
On a cobalt ss. Yes, absolutely. On a GTI, no idea but I assume it’s easy tooWas it pretty straight forward/easy to use? That is good to know it worked. Thanks!
The setting is in the media center.Hey guys, anyone know how to disable the Rain water sensors in a 2020 Jetta??
It's not running.Can you hear if the pump is running but maybe the nozzles are plugged up?
its not a fill plug that you fill it from at the top by the selector actually, its this tension locator type ball for the gear selector.So apparently I don't have the normal manual transmission housing with the fill plug in the usual spot. Instead it's a plastic fill plug right below the shifter. Does anyone else have this and happen to have a part number for that plug? I can't find it online and googling "mk7 gti manual transmission plastic plug" just turns up a bunch of oil plugs.
(found this picture online)
Does everyone else have a little storage compartment under their driver seat or is it just mine? I know on the Mk6 it was a popular aftermarket mod and I actually had it when I bought leather seats off a local since he already did the compartment mod. Wasn't sure if VW just made it standard for the 7s...
