BadHombre760
Vegas
Slow FWD VW Hatch
gti_up
New England
2020 GTI S
Here's a stupid one for you guys:
Is it normal for a wheel spacers to not fit flush against the wheel? I ordered a set of 11mm spacers from shopdap. The spacers fit flush against the wheel hub, and the wheels are secure against the lip of the spacer, however there's probably a 1mm gap between the spacer and the wheel.
Seems strange to me.
GenX Retread
Canada
2021 GTI Autobahn
How accurate do you find your fuel consumption readings vs. a manual calculation? I honestly don't care too much about the absolute number, but I like to see the relative change based on how I drive. I haven't done a manual calculation with this car, but my wallet tells me it burns about 45% of the fuel my F150 does, which lines up with the display.
My Fords were all about 5% optimistic, Dodges about the same, GMs must have been using that new math, because they were all out by over 15%.
I did the math when I filled up today, and the displayed fuel economy was out by less than 4% on the 'Since Refuel(?)' calculation. Good enough for me.
Acadia18
Rhode Island
2016 GTI SE
What could cause a spark plug gap to close? I replaced a set of Ruth's that had maybe 15k miles on them, and the gap had closed to ~0.020 or so. When I installed them, they were pre-gapped to 0.024 - 0.025 (same as the new ones), and I had left them as-is. Usually they open after time, not close...
DrFunkalupicus
Topeka
2016 VW GTI S
Maybe they are for Australian models?
I've not heard of that either.
Keehs360
Denver
Mk7.5
That’s impossible. Shouldn’t it widen little by little?!
:) I only asked because I wasn't smart enough to check behind the manufacturer the first time I purchased pre-gapped plugs.
The Ruthenium plugs come pre-gapped to 032. He gapped his to 024 and after 15,000 miles the gap had tightened. Plugs always open up the gap after some mileage.
Acadia18
Rhode Island
2016 GTI SE
You confirmed this?
Yes, I distinctly remember checking them when I got them. Both sets, the old and the one new today, were pre-gapped around 0.024 - 0.026. Gap wasn't touched on either set.
These are both old ones. The one on the right, I opened the gap to ~0.024 for comparison. The one on the left, I can barely check with my gap tool which starts at ~0.020 (one of those metal circular ones the size of a half dollar):
What is the white scale on them?
