Desslok
PA
2019 Rabbit
I know this has been asked a million times...
I'm looking into Neuspeed RSe11Rs, 18x8.5. Trying to decide between 235/40/18 and 245/40/18 tires. Does anyone have any thoughts? I'm leaning towards 245.
I'm going with PS4S tires for what it's worth.
If you are lowered or going to lower, the 235s are the safe choice. 245s may rub in certain situations, if your car is lowered.
No plans to lower, then definitely go for the 245s. The taller sidewalls will fill up more of the wheel gap and give a slightly better ride, as well as look fatter on the wheels.
BadHombre760
Vegas
Slow FWD VW Hatch
If I wanted to eliminate the high-flow cat smell from my exhaust, would it be better to:
-Buy a $400 GESI cat and replace the cheap 200 cell that sits at the end of the dp
or
-Buy a $500 ARM dp with the cat in the factory spot right after the turbo
I guess another way of asking this question- I know the GESI cat would be better quality than what's in the ARM but how much difference does the placement really make?
oddspyke
Middletown, DE
2016 GTI, 2018 ZL1
or
Placement mostly helps with catalyst light off; basically how fast it warms up and starts working. Having it in the factory location means it will heat up faster and stop smelling bad sooner. Once everything is already up to temp, it doesn't make much difference. Having the cat further down can protect it from excessive heat, but I haven't heard of that being a problem on this platform.
gti_up
New England
2020 GTI S
That's exactly what I wanted to hear, you're the man.
No plans on lowering though. The roads around here are horrendous.
Desslok
PA
2019 Rabbit
You could also opt for 17" rims with 235/45/17 tires for an even better ride.
StorableComa
Long Beach, USA
17 GSW S
or
Just picked up the ARM catted DP with the 200 cell high flow. Hopefully should be installing this weekend.
Smell was a concern for me, but looking at DPs.. almost all from 500-800ish bucks come with 200 Cell. HPA has a 300 cell, but when I was looking around it was on backorder everywhere. MAP has a GESI catted or Catted and Ressed for 800. I think they were the only OTS with a GESI I saw when searching around. I'll update once I get the ARM in and put a 100 miles or so on to burn off any manufacturing oils how the smell is on cold start and at a stop.
Honestly if it does end up being an issue, I'll probably look into a local shop swapping the CAT for a 300/400 cell GESI.
The ARM has the cat butted up against the turbo, unlike the CTS turbo 3.5" pipe. The O2 bung is also Post cat rather than Pre-cat which is nice on the ARM:
BadHombre760
Vegas
Slow FWD VW Hatch
The ARM has the cat butted up against the turbo, unlike the CTS turbo 3.5" pipe. The O2 bung is also Post cat rather than Pre-cat which is nice on the ARM:View attachment 205383
I'd imagine you'd still need a spacer with the ARM dp to avoid CEL, but if I'm wrong I'd love to know. If you don't then that's a very good sign the CAT is kickin ass in that spot. I've also been looking at the ARM fmic kit
okMK
AZ
16 2dr MK7
Let us know how that turns out, can't say I have seen many people with this DP but I am super interested.
StorableComa
Long Beach, USA
17 GSW S
I'll update. Should hopefully go on this weekend. Still stage 1, so I'll see if it pops a CEL for the o2. If it does i'll probably look at a Vibrant medium straight spacer, though I think those were discontinued? Might have to do some some looking around.
Keehs360
Denver
Mk7.5
That was fast! Didn’t u buy that on Monday?
StorableComa
Long Beach, USA
17 GSW S
Yup, Ordered the DP and FMIC along with a t-shirt direct from ARM on Monday. Showed up yesterday via UPS. DP box had a corner that was kinda smashed, like it had been dropped - But the DP and other parts were fine with no scratches or dents.
FMIC came packed really well too, a few spots that look like damage, but are not, on the fins - It's just some of the back paint/enamel either didn't adhere or fell off between the fins so cosmetic and not functional. Can still see light through the other side of the core. So I'm not going to worry about it, can't really tell unless you stare at it up close anyhow.
Only thing that was back ordered was the T-shirt.. Should be here around the 14th :ROFLMAO: So -10 HP for me until then.:LOL:
Keehs360
Denver
Mk7.5
FMIC came packed really well too, a few spots that look like damage but are not on the fins - It's just some of the back paint/enamel either didn't adhere or fell off between the fins so cosmetic and not functional.
Gotcha. Good info
Anyone interested in a DP should take a look at the Trackslag 4 " DP. The turbo spools earlier and the throttle response is improved a lot. The catted version is expensive. I got the no cat one delivered for $600. Also look at the flex section which is the same as the OEM DP so it doesn't turn the DP into a motor mount. Too many of the other DP 's have a very small flex section which will result in the DP having too much stress on it.
https://www.trackslag.com/index.php?id_product=45&controller=product
Keehs360
Denver
Mk7.5
wow thats a solid price
StorableComa
Long Beach, USA
17 GSW S
DP looks amazing..but at 1.2k for the catted version I don't know if an extra inch of pipe diameter is going to help with an IS20 build.
