Ezekiel81923
- Royersford, PA
- 2019 Volkswagen GTI
Do I need new hardware when I do my RSB and endlinks? Trying to swap them out next weekend, just need to know if I can reuse the bolts / screws.
When my RSB was installed the stock end links and hardware were reused. 90,000 miles since then and all is well.Do I need new hardware when I do my RSB and endlinks? Trying to swap them out next weekend, just need to know if I can reuse the bolts / screws.
I initially reused the stock end links and brackets/bolts with my Eibach RSB.
For whatever reason, the stock end links wouldn't stay torqued (I eventually replaced them with Moog end links and haven't had any subsequent issues), but the OE brackets and bolts have been fine. I have no idea why the stock links gave me trouble; I tightened everything down with all 4 wheels on ramps in both cases.
Meh...you can't always read too much into that.Then, you always have to ask "why was a car with under 5k miles traded in?
You shouldnt. Should replace.Is it ok to reuse the stock bolts from my OEM RSB and end links when I swap them out?
Assuming you use the proper size tire, yes. Otherwise....19” wheels on stock suspension gti
I assume the gap would stay the same?
We doing 19s now??19” wheels on stock suspension gti
