Anthony3o55
South FL
I’ve been getting a screeching noise when coming off a stop if I dont give enough rpm. What could that be? it doesnt sound good when I do it
cb1111
Newbie
Virginia, USA
Anybody here from Albuquerque? I'm buying an Alltrack at University and would like to see if I could persuade somebody to swing by to take a quick look at the cosmetics.
uberdot
GTI S 6MT
What’s a safe knock limit for the EA888 gen 3?
okMK
Gti
Hey guys... Southbend Stage 2 Daily clutch came in. It doesn't have any instructions in the box whatsoever, aside from don't install it backwards... does anyone know if the torque values for the install are different from the stock setup?
Also, for anyone who has handled a Southbend clutch, did you notice the pressure plate was a little tough to align on the riser pins from the flywheel? I had to do a little work to get it off and on, was worried it may be bent somewhere.
Dog Dad Wagon
Innnnn West Philadelphia...
19 Alltrack 6MT
Ugh, I was hoping Colorado would be nicer about that. I want to go IS38 on the wagon but not if there's going to be visual inspection. I was hoping to leave that behind in California.
The DP is pretty well hidden behind the turbo and engine, so maybe you could get away with it? Either way I believe an R DP wouldn't line up with the rest of your exhaust.
I have read that it in fact won’t line up? Plus all is38 tunes mess with emissions sensors due to their assumptions that your running an aftermarket downpipe
I’m so confused now LOL.
APR’s new IS20/IS38 tunes work with stock downpipes
Dog Dad Wagon
19 Alltrack 6MT
Wouldn't an IS38 require a new DP (or at least an R DP in the case of an AWD wagon)?
Good question. I just checked their site, and I see they have separate drop downs for “Stage 3 IS20” and “Stage 3 IS20DP,” meaning the former is for stock down pipe cars with an IS20, and the latter with aftermarket DP. There is no IS38 non-DP file, so yes you would need an aftermarket one. The OEM R DP won’t even suffice.
Raguvian
Denver
2019 GSW 4MO 6MT
Dang, I was hoping to get an IS38 + R DP for the wagon.
