Anthony3o55
- South FL
How deep can you drive a GTI in flooded waters?
I really curious though. Right now there’s Tropical storm Eta hitting South FL right now and my block is a river. The deepest part is above ankle like if you were wearing high socks.Until it stalls.
No, that's a normal 57mm caliper normally found on models like the alltrack that fit 16" wheels.If someone could help, I would greatly appreciate it... is this a pp/golf r caliper?View attachment 191776
Yes. Most places will check your alignment for free and you can see if it's out of spec, then decide if you need it. It depends on your mileage, but I get mine checked at least annually and it usually needs some adjusting.Maybe 18 months or so? Last time I rotated my tires I noticed the fronts were wearing a little bit more on the inside, but didn't seem too bad.
Would you recommend another one with the new wheels/tires?
Im curious. Cars can go into flooded water as long as the intake doesnt get water. Is this true? Doesnt our intake get air from the grill. I wouldn’t do it but it’s nice to know how deep you could actually go.
Right, there is also the issue of all the electronics that are by the center tunnel. It doesn't take much to total a car these days with water.It's difficult to answer the question. The speed you're driving is a big factor. But I don't know why you would want to take the risk. In Arizona anyone who now drives through a flooded street and needs to be rescued has to pay the bill for the rescue. It isn't worth the potential risk of your life or to destroy your car.
But, I can't seem to find the Driver Mode on the infotainment system. Pressing the button on the side of the shifter does not bring it up. Is there another way? Is it disabled?
Another question I have is what pressure should I put in these Pirelli Strada Sport 225/40R18 tires? is 36PSI ok?
Thank you!
Did water just come in even with the doors closed? or you opened the door?I had a scary drive thru a deeply flooded parking lot just a few months ago. My exhaust tips were at least 50% submerged and burbling, the water came up to just below the door sill on the sides of the car. No damage except for the driver side carpet I flooded with my soaked pants and shoes. It took two cleaning attempts to get the funky rain water smell to go away.
