Was just wondering how often you guys use your parking brake, do you put it on everytime you park or only on certain occasions (upward/downward hill or uneven surface)
I use the parking brake anytime it's not a perfectly level parking spot.
cbass
Couple Loose Screws
Peenhandle
milfs
I understand the theory but I'd be surprised if it happened. Unless you drive in city a lot and you become a slowrider
Reminds me of my favorite troll. Saying that you understand physics, and that since lowering the car puts it closer to the ground, and force decreases over distance, ask how much power you gain from lowering a car.
DSC808
HI State
2016 GTI SE MT
Rims or tune :eek:
Konig Oversteer 18x8 or APR Stage2+ (when its available). Rims are 20lbs vs 25lbs stock (I think). I have Firehawk Indy 500 225/40/18 to swap on. Price is about the same for either.
I KNOW rims will get curbed eventually, crappy roads here. And I know I'll need a clutch eventually if I get the tune. Weight reduction from the rims should make the driving experience more enjoyable, but so would the tune :p
Have a family vacation to plan so can't get both :eek:
swcrow
Rims or tune :eek:
I KNOW rims will get curbed eventually, crappy roads here. And I know I'll need a clutch eventually if I get the tune. Weight reduction from the rims should make the driving experience more enjoyable, but so would the tune [emoji14]
Function over form. If the wheels were 18lbs, is say wheels, but go for the tune
shovelhd
Western MA
Rims or tune :eek:
Wheels, because you have the tires.
Strange Mud
Small Town CT
2017 GTI (+3 more)
I understand gas mileage is the last thing to consider but have you noticed better after lowering your cars?
but if you lower just the front the car will be going downhill all the time = better MPG.
Shadowtuy
NY
Hello All!
I'm new and I have a difficult question! So, I noticed golfs seems to be sorted by mark versions. If i'm searching for parts/mods and it says its compatible with a "MK7 GTI" would that mean (as long as its not engine related) It would fit my "MK7 Tsi?" I would love if this would be this way! This is most likely to general of a question.
Hello All!
Not necessarily and probably not. You would need to look for parts specifically for the TSI.
burchtd
Oregon
'17 GTI S
So I’ve got a stupid question (that’s probably been covered by plenty of people in this thread and others)
But...TPMS, it’s an indirect system which from my understanding uses ABS to measure tire rotation and speed to determine air in the tires. I’m curious to know if I’m doing this right? I got my tires rotated and balanced, filled with air; pressed SET, and nothing happened. So is it remembering the 37 PSI and logging it for a later time when my air starts to get low, or should I just invest in a little reader to check my tires 0.5 to 1 month at a time like I used to? (I read on other posts that it doesn’t catch a reading when you are driving fairly sporty and my job is only...4-8 miles away from my apartment so I don’t really have a lengthy drive for data gathering)
Strange Mud
Small Town CT
2017 GTI (+3 more)
Hello All!
idk but I'd say not necessarily but maybe. If we know what mabe we can give a better answer.
Strange Mud
Small Town CT
2017 GTI (+3 more)
I read somewhere (don't remember) that you had to adj PSI, hit set then go for a drive. I think checking PSI with a guage 1x month (along with oil/fluids) is just a good general practice/habit
