Hello everyone,
I am facing a problem for the last few months.
My Golf 7 (1.2 TSi) makes loud constant noise when i drive above 50 kmph. It is much worse at around 70-80 kmph and then still slowly increases with the speed. It is very easy to get headache and/or irritation if I drive for more than an hour.
Here is my video snippet: https://www.veed.io/view/1c9a0b9e-f393-4017-b830-79853eef5ea3
Some observations/things to note:
1. The noise raises with the speed
2. The noise is there even when the engine is off (eg. switching of the ignition key while driving)
3. I believe the noise is not from the engine - e.g. while the car is parked when I give gas to get the rpm to 3-4k the noise I get is pure engine noise - and it is not the noise I get while driving
4. The noise is present at all gears and no direct link to RPM (apart from the regular noise that happens at a higher RPM)
5. Changed tires 2 months back to check whether the noise is coming from the enigne
6. Yearly service (in Jan) didn't fix the issue.
7. Noise is heard around the year summer/winter, with AC on/off.
Can anyone help me to understand the cause?
Thanks a lot and best regards,
RR
RR
