Mk7 Manual Transmission Oil change howto
OldVWFan
NW Arkansas
17 GTI Sport
Weird about the difference in volume between the two transmissions and also the video that I viewed. Agreed that as long as you are not experiencing any hard shifting, grinding, or different noises than from before that you are good to go. As already suggested calling the dealer to find the correct fluid volume is really the next step. If it is a lower capacity ask why?
Raguvian
Bay Area, CA
2019 GSW 4MO 6MT
Did anyone replace the drain and fill plugs on their transmission after this service? Trying to find the right part numbers for those to order. Thanks!
OldVWFan
NW Arkansas
17 GTI Sport
Go to ECStuning.com or shopdap.com or fcpeuro.com and put in your vehicle and buy the kit for the 6mt fluid change. The kit from ECS comes with the drain and fill plugs, but don't know about the others but they will be listed. here is a link to ECS: https://www.ecstuning.com/Volkswagen-Alltrack--1.8T_Gen3/Drivetrain/Manual_Transmission/. I believe that this is your vehicle. I did replace both plugs on my 17 GTI Sport.
Raguvian
Bay Area, CA
2019 GSW 4MO 6MT
Thank you! I was going to try the Pennzoil Synchromesh, but I'll probably just go with the kit you've linked.
OldVWFan
NW Arkansas
17 GTI Sport
You can probably just look up the part numbers for the two plugs, they are the same, and just get those from the dealer or order them if you want to use the Pennzoil fluid.
hoffnung
CA
'17 GTI Sport
I just changed my fluid with Fuchs Titan Sintofluid 75W GL-4 at just over 30,000 miles. Shifts are noticeably smoother. I also swapped to the OEM European shift cable linkage several months back and that made shifting quite a bit more enjoyable, shorter throw travel with a bit more engagement.
ervybaby00
Canada
Golf MK7 TSi
Hi,
I realize this is an old thread but here is my experience for a Golf MK7 TSi manual (2015). The drain plugs required a 17mm hex bit to remove and not 10mm. Only about a quart and half of fluid drained out - I was expecting over 2 qts. Before anyone asks, yes the car was level & engine warm. I increased and decreased the inclination of the car to be sure to get every drop out. I used 1.5 x Royal Purple High Performance Synthetic Gear Oil 75W90 (946-ml) - the transmission feels much smoother now.
Tnx for the tutorial.
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Hi,
If you have the MQ250 or MQ200 gearbox types the info is in this thread:-
https://www.golfmk7.com/forums/inde...250-5-speed-or-6-speed-manual-gearbox.348763/
