Righteousness
- Australia
- MK7 Sportswagen
Hey all,
I've got a 2015 Sportswagen TDI SEL. I've decided to achieve the GTD style. The bumper was colour matched and fitted.
The issues I am encountering:
1. Right hand side OEM MK7 GTI LED Fog light is non operational. Left hand side is operational. No corrosion in wiring. Fitted original halogen fog light back to right hand side to test and it operates but it doesn't like LED!
(Harness Adapter - https://www.ebay.com.au/itm/174780696631). I've swapped the harness adapters around for both sides and still have the same outcome. I've coded via VCDS from halogen to LED and no difference. Cannot reverse the connectors around as it's blocked by the way it's inserted.
2. Front 2 parking sensors are not operating properly. Front parking sensors beep and detect objects in front whereas none are around. Cleansed the area and problem continues. The issue disappears when driving on smooth white pavement (car parks). Problem continues whilst on asphalt (black road). WTH?!
