MK7 GTI Front Bumper Conversion Issues
Righteousness
Australia
MK7 Sportswagen
Hey all,
I've got a 2015 Sportswagen TDI SEL. I've decided to achieve the GTD style. The bumper was colour matched and fitted.
The issues I am encountering:
1. Right hand side OEM MK7 GTI LED Fog light is non operational. Left hand side is operational. No corrosion in wiring. Fitted original halogen fog light back to right hand side to test and it operates but it doesn't like LED!
(Harness Adapter - https://www.ebay.com.au/itm/174780696631). I've swapped the harness adapters around for both sides and still have the same outcome. I've coded via VCDS from halogen to LED and no difference. Cannot reverse the connectors around as it's blocked by the way it's inserted.
2. Front 2 parking sensors are not operating properly. Front parking sensors beep and detect objects in front whereas none are around. Cleansed the area and problem continues. The issue disappears when driving on smooth white pavement (car parks). Problem continues whilst on asphalt (black road). WTH?!
Righteousness
Australia
MK7 Sportswagen
Address 10: Park/Steer Assist Labels: 5Q0-919-294.clb
Control Module Part Number: 5Q0 919 294 E HW: 5Q0 919 294 A
Component and/or Version: PARKHILFE 8K H03 0048
Software Coding: 0031151011
Work Shop Code: WSC 00028 028 00067
ASAM Dataset: EV_EPHVA18AU3700000 002024 (VW37)
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: BD2CD38EADFD92130C7-80E8
1 Fault Found:
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Mileage: 32220 km
Date: 2021.11.16
Time: 14:42:56
AND
8714 - Bulb for Left Fog Lamp
B121F 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 138
Mileage: 32617 km
Date: 2021.11.30
Time: 14:55:46
8970 - Bulb for Right Fog Lamp
B1220 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 138
Mileage: 32223 km
Date: 2021.11.23
Time: 14:34:19
Nineeightyone
19 GTI 04 JSW 10 MZ3
Great detective work, and thanks for posting the solution. I'm sure that will come in handy for others as well.
