Hopefully this is come through as I’ve copied it . Below are my faults
Thursday,24,December,2020,11:50:23:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZAUZDP040715 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDP040715 Mileage: 144642km-89876miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 4944
Revision: 84H22---
Coding: 01110012034505092000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM16TDI01104L906021M 002007
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F6DA6BB761D45FEBA-807A
3 Faults Found:
8189 - Exhaust Gas Temperature Sensor; B1 S3
P242B 00 [096] - Range/Performance
Intermittent - Not Confirmed - Tested Since Memory Clear
5290 - Throttle Actuator Control Circuit
P2100 00 [096] - Open Circuit
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 144496 km
Date: 2020.12.19
Time: 22:56:56
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 62 °C
Intake air temperature: 37 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.500 V
Unlearning counter according OBD: 25
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: -0.10 %
Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 0
Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 55
Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4462.2 mV
10060 - Fuel Pump
P308D 00 [104] - RPM too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 144463 km
Date: 2020.12.19
Time: 11:02:18
Engine speed: 889.00 /min
Normed load value: 43.9 %
Vehicle speed: 6 km/h
Coolant temperature: 90 °C
Intake air temperature: 67 °C
Voltage terminal 30: 14.720 V
Unlearning counter according OBD: 38
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0 1 0 0 0
