MK7 GOLF 2.0 TDI FUEL PUMP ISSUES
Togoodaman2
UK
Mk7 GOLF 2.0 GT
Recently the power was not there when trying to accelerate floor flat down which started off as a one off but became very intermittent very quickly within a week
The coil light started flashing and engine management light came on and limp mode
The car then struggled to start and when it did ran very rough lots of white smoke from exhaust wouldn't accelerate above 25mph and Jolts along going uphill and would stall at random timing if just left there to idle
There is a gushing sound coming from behind the dashboard if this has anything to do with the fuel and a ticking noise from rear
Using vcds the error came back as P0087 low fuel rail pressure intermittent
After changing the LPFP and filter the same problems occurred hard starting, stalling during idle , white smoke
Could this issue be down to the Fuel module chip or something else
Mk7 GT tech bluemotion
Engine - 2.0 TDI 150 CRBC 6MT
c31561
East Coast, USA
2017 GTI Sport
You have a newer model of TDI than I did, I had an early revision with the fuel pump known to disintegrate. Did you look in your filter housing to see if there were any metallic bits in there?
When my HP fuel pump went, the coil light flashed, then the CEL, then I finally got a message "Engine Malfunction, shutdown" on the display as the engine turned off. I had a P0087 code and when I opened the fuel filter you could see lots of fine metal particles.
davegsm82
Blyth, Northumberland - England
MK7 Golf and T3 Tdi
Around this time last year I had failure of the low-pressure fuel pump control module, on top of the tank under the rear seat. That presented itself as the engine misfiring and complete lack of power, with DTC's for low fuel rail pressure. Then when I tried to restart the engine I got 'failure of pump electronics'.
As C31561 says, you can check the filter housing for metal particles but it's also possible to remove the valve on the top of the fuel pump, just a couple of torx bolts, and have a look for anything sitting in there.
Togoodaman2
UK
Mk7 GOLF 2.0 GT
Turned out to be the fuel pump module chip all issues gone went straight after
The gushing noise from dashboard area Is the main indication apparently for fuel module
