El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
Oh, sorry I missed reading the part about the rear mufflers being deleted, now knowing that, you need to refer to the first post of this thread and replace the smaller first resonator with the one recommended.Like I said, it was a mistake! (Trying to fix a mistake with another mistake really) The mid section wasn't quite long enough and so they had to use a small piece to fill the gap to the dp, and that piece is welded directly to it.
The og mufflers in the Y, like you see in the picture, are gone, it's just the resonator in the midpipe and the Borla in the bend now. There isn't any contact I can see. The question is, is the drone between 2k-3k caused by my janky setup or normal? I also have a feeling these engines just don't sound good, which is why inside it just sounds very monotone, without much "thrrrum."
When I first built my exhaust I ignored the original recommendation and used and super small $40 dollar resonator and still had lots of drone, switched it out to the larger vibrant. And it curbed a lot of it. Mind you this was with a aftermarket DP, when I was running the stock DP and my custom catback with 2 borla xr1 mufflers in the rear section I was fully resonator -less and donāt recall have drone issues.
This was with stock DP -
https://www.instagram.com/p/CU9b0WgLjkF/?igshid=YmMyMTA2M2Y=
