CoryJo
- Hanford. CA
- mk7 gti autobahn pp
2017 autobahn gti
dsg/tune
cts is38
e35 dyno tuned COBB accessport dyno tuned
Intake/intercooler/downpipe/HPFP/turbo Inlet/Exhaust
245/40/18 hypergrams
back seats removed/all plastics/wiper motor/mats/jack/tire/
only 2 front seats.
Im not sure it will make sense, but this car is slower at times even in similar/same conditions, actually it might just be slower in general/ a majority of time.
I do understand that DA and temperature/humidity will effect how turbo cars behave, and performance.
maybe through typing this and explaining it I will come to some sort of conclusion, the only point of reference I have are the 60-130 times that i have recorded in the dragy.
below are some times that the car has run, along with temperature and DA reported for the times in which the data samples *times* were taken these were not all done in the same night, these are random times that i've run in the 7 months i have had it tuned
current best time is 9.80 0.0 slope flat.
BEST TIME SINCE I've been playing this game.
10.34 -0.13 & 10.35 -0.02 slope ten mins later
what I find this interesting. some of these times have been faster than what i would consider ideal boost weather. (to me)
i have over 59 pulls in my dragy history.
all of which have been done at night, all in best weather possible for the time in which they were ran. of course there is some improvement in driving technique, and some variance is to be expected. but generally the car is a 10.2x-10.5x car, except for a few outliers when it runs low 10.0x *one time* and then 9.8x *3 times out of 56 attempts.
but looking at the 59 times one 10.01 with a -0.69 slope and 3 in a row in the 9.8x time range, and then all others 10.3x and above, should i be looking at the clutches, are they to blame for the time difference, surely its not making enough power to cause that. I havent noticed them slipping, just that the car feels neutered at times. and other times its ripping.
the car was initially tuned it was 77 degrees stock turbo inlet and stock air box (not sure that makes a whole lot of difference) ,
the only additions to the car since the tune have been, INJEN tube intake, an inlet pipe and light weight wheels and better tires, all these runs/attempts have been brake boosted and or/conscious efforts to break my best time. the car just will not go faster or get close.
also before anyone says it, no these runs are not back to back runs. there is ample time between them, especially cruising the highway at 50*'s for 10 to 15 mins between runs. i source my fuel from the same 2 places since June '21 always mix to the same e35 blend using the Bluetooth content analyzer.
all of my data logs have shown the car making the requested boost, timing seems fine with no large knock instances, HPFP looks like its holding pressure as requested..
am I crazy for worrying about 1/2 or more a second..? i think this should be faster than it is, maybe im expecting too much? correct me if i am wrong
I can feel the car some nights under performing and definitely when its slower its noticeable, it just doesn't have that same pull, as if its soft or dialed back.
I am trying to keep this as short as possible, i realize that the tune is pretty set for its parameters, and the air quality/temperature is really the only differentiating factor. i do understand that driver error can account for some variance, but ive tried to eliminate this by leaving it in sport and letting the car shift itself, even non brake boosting to see if i can create repeated times. *which i can*
TDLR: WHY DIS CAR SLOW? what am i missing, and what else can i look for?
maybe the answer is, the turbo is small, and the set up is basic.. but its the inconsistency in the cars performance that is peaking my interest.
dsg/tune
cts is38
only 2 front seats.
- 45 deg F
- 94% humidity
- 30.02 Hg
- 43 deg F
- 41.3
- NW 3 mph
- 102.34 %
- -793 ft.
- 46 deg F
- 99% humidity
- 29.97 Hg
- 46 deg F
- 45.3
- SE 0 mph
- 101.87 %
- -637 ft
- 46 deg F
- 93% humidity
- 29.82 Hg
- 44 deg F
- 42.8
- NE 0 mph
- 101.44 %
- -492 ft.
- 41 deg F
- 93%
- 29.87 Hg
- 39 deg F
- 35.2
- NW 0 mph
- 102.81 %
- -951 ft.
- 70 deg F
- 65%
- 29.60 Hg
- 58 deg F
- 71.9
- NW 10 mph
- 95.48 %
- 71 deg F
- 69%
- 29.60 Hg
- 60 deg F
- 79.1
- NW 9 mph
- 95.14 %
- 1696 ft.
