Mk7 dragy times, 60-130, 1/8, 1/4,
vw671
San Diego
Best time I've been able to get, but I'm getting a "transmission over temp" notification on my dash with both Cobb LC and OEM LC.
I also logged this run if anyone wants to take a look at the data? https://datazap.me/u/projecttv/1131-quarter-mile-run?log=0&data=6-9-12-15-20-26-27-28-29
2017 Audi A3 quattro full weight
E85 tune by OC Tuning (car made 481whp)
EQT Vortex std
I also had "overheat" warnings but worked them out with my tuner with ECU and TCU tweaks.
Here's what my Vortex Std did when I was running it:
projectTVMK7
Lompoke
2017 Audi A3
Wow! Nice times! Is this full weight?
What changes did your tuner make to your ECU and TCU to fix the "overheat" issue?
vw671
San Diego
Sorry couldn't tell you the details because I would be guessing to be honest with you. He did a bunch of things, also keep in mind that this was when Cobb first released MPI support two years ago.
The run was done at 3,540 lbs with driver, 3126 DA, and airride
GTMCooper
GTI S DSG SneekyTune
Drag radials in the front, stockers in the back. Motegi wheels are sub 17lbs.
These ones are actually 22-23. My mistake when buying, I didn't check if they were the same weight as the traklites. I also prefered the look, so meh, I'll fix it eventually.
railroader
Yuma Arizona
2015 audi s3, maestro tuned by me, 33psi@14° dynoed at 506whp and 426wtq, fbo, eqt xl, e85, mpi 1300cc, pr dual 450lpfp
railroader
Yuma Arizona
Congrats on running 10s on the street in that heat, the HP tuners DSG software seems to be working good
Thank you, ya I like it so far, it has help alot, with my apr I was never able to get better than a 1.94 60'
arob157
Ended up “accidentally” doing my first 60-130 during a log. Probably can cut it down due to shifting 3rd at 6500 RPM.
Your build is eerily similar to mine lol. That L450 is doing work for sure.
Ostateballer
Oregon
2016 GTI S PP/LP
Yeah, a little smaller than the Vortex STD. I’m at 31-32psi FYI.
I hit the track the other week and left a little disappointed. Best was 11.59 @ 121.5 — 1.87 60’ and IATs were 140 at start though, etc.
Next time will be much better. We shall see.
MK7Davey
MN
Maxed out around 30psi on my E85 5150 tuned 6mt RX500 finally managed my best time, twice haha. Needed a bigger turbo for the 7's it seems :(
