MK7 Climatronic upgrade with instructions and pictures.
davegsm82
Blyth
MK7 Golf and T3 Tdi
IWMTom thanks for those picutres, I was going to ask the same question to everyone but I've been too busy with work to get on with this.
Looks like you have to disassemple half of the car to get to the sensor location, I think I'll just be trying to put mine somewhere in the duct closer to the footwell, probably just drill a hole and poke a sensor through.
Certainly looks like the provided G192 isn't the same as the one in the manual, so I have to assume that the sellers have gotten the wrong end of the stick and provided 2x sensors intending them to go in to the upper ducts.
Dave971
Us
Is there any difference between the sensors besides one has a right angle attachment? They read the same ?
davegsm82
Blyth
MK7 Golf and T3 Tdi
In all seriousness, they're probably all standard thermistors, but from past experience I've found that VW use different types in different places, i.e. 10Kohm for the upper vents, then maybe 4.7K for the lower vents etc.
I'm going to have a bit of a mess around with my spare panel tomorrow and find out.
Dave.
Dave971
Us
Ok I guess my question is can I use the AliExpress kit with the 2 sensors for the upper and lower? Will it read OK?
davegsm82
Blyth
MK7 Golf and T3 Tdi
I should have an answer for you tomorrow, but either way, at the minute mine only has the 2x sensors placed in the upper vents and the system appears to be working just fine despite this.
Rollback50k
Yeshhhhhhhhh
NY
So I’m half way through the process. Got the driver side (upper vent sensor) fitted fine but I can’t locate the footwell slot for the sensor. I see the passenger upper vent sensor slot but my sensor won’t fit because of the 90* angle the connector has.
thoughts or suggestions? (I’ve been going through the thread over and over to see if I’m missing where the location is for it but can’t seem to find it)
thanks in advance!
