IWMTom That's great, thank you for going to those lengths to help out, The symptom of SS working when you turn off the A/C was exactly where I was at with the Aliexpess panel, at present I can't remember if it's the same with the used Golf one, but I think it might be.
Ok, so I've just been out sitting in the car in my jim-jams idling the engine and looking at the coding.
As I suspected the coding was set to have an internal humidity sensor active, as far as I know I don't have one so I deactivated this and it got rid of one of the items listed on the SS status screen, which was "Windscreen could become fogged". However it still said "A/C requires engine to be running". This led me to try and run the A/C compressor run in again, which would not work, just faults out with a 'sequence' error, even after running the Flap endstops adaption. This can also be done by pressing the demister button and the A/C together but this didn't work either.
So.... I took it for a drive round the block, sure enough the SS wasn't working still, even if I turn off the A/C I still have the "A/C requires engine to be running" message, only if I turn off the Climatronic completely does the engine stop. Turn it back on and engine starts again. So I got back to my driveway, clima and A/C on, and was just about to give up when the A/C message disappeared, but the engine was still running. So I poked the SS on/off button and it went to deactivated, then poked it again and the engine stopped(!).
I tried this a couple of times and it seemed to work ok while stationary, my journey tomorrow commuting to work will prove whether this is just a fluke or if it's something that just needed to reset to start working again.
I'll report back my findings tomorrow.
Also; in your scan above, I can see you have the error messages similar to what I have, for things like the defrost and RHS flap which are to be expected, but you have an error for the Fresh/Recirc flap, did you run the flaps adaption? (or from the front panel).
I'd quite like to sort out the temp sensor errors on mine, so will try to get some more sensors and plug pins, same goes for the sunlight sensors.
Thank you for your help
Dave.
