MK7 Climatronic upgrade with instructions and pictures.
George Ab
Pacific NW
Anyone have a link to the old model with the knobs? The one linked in the OP now looks to be full touch controls.
https://www.aliexpress.com/item/4000959269245.html?spm=a2g0s.9042311.0.0.6f4f4c4d9AoeWQ
Here are a couple. https://www.aliexpress.com/item/1005002657173916.html?spm=a2g0o.productlist.0.0.364a4b630iYtSG&algo_pvid=217e47fc-1b52-46a0-836c-c263edd99e45&algo_exp_id=217e47fc-1b52-46a0-836c-c263edd99e45-0&pdp_ext_f={"sku_id":"12000021585293770"}&pdp_pi=-1;99.95;-1;515@salePrice;USD;search-mainSearch https://www.aliexpress.com/item/4001053693840.html?spm=a2g0o.productlist.0.0.4d2d7b13bRCgMz&algo_pvid=16f05b1a-2562-4cc0-a861-be217c886957&algo_exp_id=16f05b1a-2562-4cc0-a861-be217c886957-24&pdp_ext_f={"sku_id":"12000021507584745"}&pdp_pi=-1;135.0;-1;-1@salePrice;USD;search-mainSearch Personally, I would just buy a NAR unit and the outer plastic piece off of eBay and then get a cable and sensors off of Aliexpress. I've seen them sold separately. https://www.aliexpress.com/item/4001212098968.html?spm=a2g0o.productlist.0.0.153b557aC9QauI&algo_pvid=413bdda1-d783-4523-93df-d0928d440bfb&algo_exp_id=413bdda1-d783-4523-93df-d0928d440bfb-14&pdp_ext_f={"sku_id":"12000021702045543"}&pdp_pi=-1;23.58;-1;-1@salePrice;USD;search-mainSearch I like the NAR unit as I prefer the Max AC over the unusable Clean Air and was unable to connect to unit with Vagcom. I like to change settings so in winter the heat seats are always on in the last position set to as opposed to default which is off. https://www.golfmk7.com/forums/inde...ions-and-pictures.379148/page-17#post-7567605
bobloblawGTI
DC
19 GTI SE 6MT
motech
New Jersey
MK7.5 GTI
im having trouble getting my AC working. i installed this in the winter, heat worked great. Now its getting how and im realising i have no AC! lol
can anyone help?
motech
New Jersey
MK7.5 GTI
It basically says hold the lower left and right buttons and the compressor will calibrate. If it doesn't, then turn it off and on, then try again.
yah i tried many variations of that.
Should the engine be on? i have the engine running while working on it.
im going to take it back to the shop the swapped out the panel for me. try again with him and check wiring.
If that doesnt work ill have to put the old panel in. its too hot out! crazy i never thought of 65F as too hot out but im sweating in there.
davegsm82
Blyth, Northumberland - England
MK7 Golf and T3 Tdi
Sorry for the lack of replies, all of my golfMK7.com notifications go to my Spam folder in Hotmail and I have no idea why.
So yea, you have to have the engine running when you do the adaption, as it's adapting the internal compressor actuator vanes so it knows how much voltage it needs to apply to get the right amount of cold out of it.
If you can't get it working then you probably need to have the codes read and see if there's anything other than the **normal** codes which will be stored after doing this mod, I think there's something like 7 standard codes, maybe more, for actuators missing, sunlight sensor etc.
You should probably also check to see if the new panel has things turned on such as the air quality sensor etc, I think mine came with that option enabled. That will throw an additional code which who knows, might stop the adaption from running.
Dave.
Guto
Australia
Golf Wagon MK7
Hi there,
I just done the upgrade a couple weeks ago but I’ve been having few problems related to the flaps and compressor sync, they are not working. I tried in both ways (pressing the buttons and VCDS as well) but still not working.
Did anyone have this problem as well?
Also, just want to check if these errors are the ones expected?
Code:
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 0212000410010001100400401210182A
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6C81CD4AC60EC38B037-8038
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
10 Faults Found:
328197 - Motor for Right Temperature Flap
          B108D 54 [009] - Missing Calibration / Basic Setting
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:12
                    Voltage terminal 30: 12.5 V
                    Outside temperature: 15.0 °C
                    Inside temperature: 24.6 °C
                    Right temperature flap: actual value: 0.0 %
                    Right temperature flap: actual value: 237
                    Temperature door right - Specified value: 15
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [009] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:12
329989 - Motor for Defroster Flap
          B1090 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:11
                    Defroster flap: actual value: 18
                    Defroster flap: actual value: 0.0 %
                    Defrost door - Specified value: 15
329991 - Position Sensor for Defrost Flap Motor
          B1098 15 [009] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:11
328965 - Motor for Front Air Distribution Flap
          B1091 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:11
                    Voltage terminal 30: 12.4 V
                    Front air distribution flap: actual value: 204
                    Front air distribution flap: actual value: 100.0 %
                    Air distribution door front - Specified value: 205
329477 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:12
                    Actual value for fresh air/recirculation air flow flap: 0.0 %
                    Actual value for fresh air/recirculation air flow flap: 78
                    Fresh air/recirculating air/back pressure door specified value: 78
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [009] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:12
197378 - Temperature Sensor for Right Vent
          B1088 15 [009] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:11
                    Vehicle speed: 0 km/h
262402 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:11
262404 - Sunlight Photo Sensor
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 304064 km
                    Date: 2022.06.11
                    Time: 16:33:11
Thanks!
Canecreekfreak
Boston area
MK7 GTI sport
Back from the 'dead'.
Just double checking the wiring for the temp sensors. The one already attached to the loom goes to the upper vent, and the one with the loose wires that you have to add to the wiring harness connector goes to the footwell vent, correct?
Also, on my car, the "flap re-synch" procedure worked, but then I tried the "AC Run-in" cycle w/the AC & Max Demist buttons, but the lights didn't blink back and forth. I seem to have cold AC, but it's also only 40F outside, so it's hard to tell. Is there a way to do that w/OBD 11?
TIA!
George Ab
Pacific NW
TIA!
This thread shows the location of the G150 and G192 sensors.
https://www.golfmk7.com/forums/inde...ions-and-pictures.379148/page-18#post-7589083
Canecreekfreak
Boston area
MK7 GTI sport
Thanks. I'm still unable to tell which wire goes to which location. Maybe it doesn't matter- as long as 1 is in the upper vent, and one is in the footwell vent??
The shitposter formerly
known as Acadia18
Correct
