THEREALVRT
- The great white north
- Golf R
Sam, Scott, Tapp has two (RS3 and S3).
i forgot about chris.
So much misinformation in this thread. The 4 bar problem has NOTHING to do with Eurodyne.
Be wary of people giving out advice when they don't know what the hell they are talking about i.e. 805mk7.
What Ed and Sam said is correct. The Bosch 4 bar is not qualified linear below 0.5 bar which is fine for the diesel cars it was designed for, but not for gasoline ones.
UM is running a more expensive AEM 5 bar map, this is why the car runs perfect. The 4 bar kits everyone is selling for the manifold are not ideal. Throttle pipe is fine and will get you 4-5 seconds of over 3 bar boost (running one sensor) before you get a code.
P.S. Ottawa is a great MQB city. 4 10 second MQB's here and our population is like 800,000. Two will probably be 10.5-10.6 or lower this summer.
Just a FYI....Not all UM cars are running the AEM sensor. UM has plenty of other cars running the 4 Bar set up.
I am aware yeah, i've seen the pics.
What I am saying is that the sensor itself is not accurate for load/airflow calculation in a vacuum operated manifold on a gasoline car. Period.
So then how are all the UM cars running perfectly fine? the ones running the 4 bar sensors?
they don't, it's a UM find fuck sent out to all the UM users via that dude from xmen
crafty fuckers they are
Does anybody sell the AEM 5 bar with mounting equipment for MQB's other than APR?
edit: Didn't realize APR's boost tap was so cheap. Maybe i'll do what therealvrt recommended then. Thanks!
They probably aren't using that exact sensor, or they added support for non-linear mapping.
Curious... have you bench tested the sensor at high vacuum? I know the factory calibration doesn't go that low, but that may just have to do with application (diesel). The sensor itself might be linear in that range.
I have one of these on my desk and I'll try to bench test it this week to see how it really responds.
-- Ed
From tuning them on 10+ cars and including my own, with a linear calibration you can basically accept perfect idle with low speed driveability problems/cruise lambda all screwed up, or driveability better and idle crap.
No bench tests, I don't have the necessarily hardware (vacuum chamber).
I'll report back with what I find. I was going to return my set based on the data I found, but PR swears that they have a lot of customers out there running these with no drivability/idle issues with several different tuners. So I'm going to investigate further and see if it may be a viable solution.
-- Ed
