MK7.5 OEM LED Tails
hydeco
N3L 2V1
2019 GTI
Please share pics of the plugs.
Those are the plugs on the lights
Those are the plugs on the DAP harness.
ZERO815
Köln Germany
2017 GTI SE DSG
Trim connector w/ knife. Should have come that way from DAP imo. VW uses hardware and color coding „Poka Yoke“ system. Remove hardware coding and you‘re good to go.
ZERO815
Köln Germany
2017 GTI SE DSG
The lights themselves appear to be the same according to the part numbers. Looks like the more expensive kit are individual collected lights while the second option is the official retrofit-kit including wiring for MK7.5 cars.
  • Like
Reactions: Sov
Sov
EU
MK7 GTD ABT
Thank you for your reply. What do you mean by individual collected lights? On the cheaper one it explicitly mentions that it's not compatible with mk7 golfs, while on the other hand the expensive one does not.:unsure:
kingkhan
Canada
It means that they put the kit together themselves by bundling each individual light/part number. The other kit is the official retrofit kit from VW and only has 1 part number.
Sov
EU
MK7 GTD ABT
Oh right, that explains a lot. Thanks.
blaqsheep
Canada
IS38 GTI
Coding for rear side marker lamp:
Leuchte27NSL RC6-Lasttyp 27 41 - LED Kleinleistung
Leuchte27NSL RC6-Lampendefektbitposition 27 0
Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 54
Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
Leuchte27NSL RC6-Lichtfunktion B 27 not active
Leuchte27NSL RC6-Dimmwert AB 27 127
Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always
Leuchte27NSL RC6-Lichtfunktion C 27 not active
Leuchte27NSL RC6-Lichtfunktion D 27 not active
Leuchte27NSL RC6-Dimmwert CD 27 0
Leuchte27NSL RC6-Dimming Direction CD 27 maximize
Leuchte27NSL RC6-Lichtfunktion E 27 not active
Leuchte27NSL RC6-Lichtfunktion F 27 not active
Leuchte27NSL RC6-Dimmwert EF 27 0
Leuchte27NSL RC6-Dimming Direction EF 27 maximize
Leuchte27NSL RC6-Lichtfunktion G 27 not active
Leuchte27NSL RC6-Lichtfunktion H 27 not active
Leuchte27NSL RC6-Dimming Direction GH 27 0
Leuchte27NSL RC6-Dimmwert GH 27 maximize
Still getting this error after coding Leuchte27NSL back to stock. :(
B145B15 - Rear side marker lamp bulb Open circuit/short circuit to B+
Intermittent
TheGreekFreak
MA
Ok, last question: anyone with a US model with halogens, preferably a 2017, have the original coding for the following channels under 09 - Central Electronics:
Leuchte27NSL RC6 - Dimmwert AB 27
Leuchte27NSL RC6 - Lasttyp 27
Leuchte28RFL LC11 - Lampendefektbitposition 28
Leuchte28RFL LC11 - Lasttyp 28
Leuchte28RFL LC11 - Lichtfunktion A 28
I copied a Canadian members adaptations to revert back and the issues I'm having are 1) the running lights don't turn on either in the running light switch position or lights on switch position and 2) brake light overrides turn signals. Everything else seems fine but suspect these two channels might be different cuz his had some kind of LED input for one of them.
lijetta18t
Here is everything from both channels:
(1)-Leuchte27NSL RC6-Lasttyp 2736 - LED Kleinleistung
(2)-Leuchte27NSL RC6-Lampendefektbitposition 27
0​
(3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27
47​
(4)-Leuchte27NSL RC6-Lichtfunktion A 27Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte27NSL RC6-Lichtfunktion B 27not active
(6)-Leuchte27NSL RC6-Dimmwert AB 27
127​
(7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27Always
(8)-Leuchte27NSL RC6-Lichtfunktion C 27not active
(9)-Leuchte27NSL RC6-Lichtfunktion D 27not active
(10)-Leuchte27NSL RC6-Dimmwert CD 27
0​
(11)-Leuchte27NSL RC6-Dimming Direction CD 27maximize
(12)-Leuchte27NSL RC6-Lichtfunktion E 27not active
(13)-Leuchte27NSL RC6-Lichtfunktion F 27not active
(14)-Leuchte27NSL RC6-Dimmwert EF 27
0​
(15)-Leuchte27NSL RC6-Dimming Direction EF 27maximize
(16)-Leuchte27NSL RC6-Lichtfunktion G 27not active
(17)-Leuchte27NSL RC6-Lichtfunktion H 27not active
(18)-Leuchte27NSL RC6-Dimmwert GH 27
0​
(19)-Leuchte27NSL RC6-Dimming Direction GH 27maximize
(1)-Leuchte28RFL LC11-Lasttyp 289 - allgemeine Gl¸hlampe 27W; auch H15
(2)-Leuchte28RFL LC11-Lampendefektbitposition 280B
(3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28
31​
(4)-Leuchte28RFL LC11-Lichtfunktion A 28Rueckfahrlicht
(5)-Leuchte28RFL LC11-Lichtfunktion B 28not active
(6)-Leuchte28RFL LC11-Dimmwert AB 28
100​
(7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28Always
(8)-Leuchte28RFL LC11-Lichtfunktion C 28not active
(9)-Leuchte28RFL LC11-Lichtfunktion D 28not active
(10)-Leuchte28RFL LC11-Dimmwert CD 28
0​
(11)-Leuchte28RFL LC11-Dimming Direction CD 28maximize
(12)-Leuchte28RFL LC11-Lichtfunktion E 28not active
(13)-Leuchte28RFL LC11-Lichtfunktion F 28not active
(14)-Leuchte28RFL LC11-Dimmwert EF 28
0​
(15)-Leuchte28RFL LC11-Dimming Direction EF 28maximize
(16)-Leuchte28RFL LC11-Lichtfunktion G 28not active
(17)-Leuchte28RFL LC11-Lichtfunktion H 28not active
(18)-Leuchte28RFL LC11-Dimmwert GH 28
0​
(19)-Leuchte28RFL LC11-Dimming Direction GH 28maximize
TheGreekFreak
MA
0​
47​
127​
0​
0​
0​
31​
100​
0​
0​
0​
Thanks man! Strange.....have the same values as you for these two channels but still having issues with the running lights + brake light override.
These are the only other channels I would have made adaptations for:
Leuchte20BR LA71
Leuchte21BR RC8
Leuchte23SL HLC10
Leuchte24SL HRA65
Could I bother you for the stock values from these as well? Guessing there is some mismatch somewhere, just have to find it. Thanks again for your help.
ZERO815
Köln Germany
2017 GTI SE DSG
Leuchte20BR LA71
Leuchte21BR RC8
Leuchte23SL HLC10
Leuchte24SL HRA65
Brake light / Running lights / Turn signals on NA MK7s are under channel 20&21.
