You could do it but you would need fenders from a mk7.5 as well, they're slightly different then the mk7Just need some help. Can the 7.5 headlights be retrofitted to the mk7? If yes, do you know anyone who is doing them and what price?
That’s the problem. The stickers have been removed (before I bought the vehicle). Thinking what I should do?The part number of your cracked headlight should be on there. Typically the stickers are on the inside where the grill meets the headlight.
RHD vehicle headlights typically start with 5G2 ... ... . Order exactly the same part number and you should be good to go.
Are you sure they're not aftermarket? I don't know if aftermarket puts the labels on but I don't see someone going through the effort to remove oem labels from a lightThat’s the problem. The stickers have been removed (before I bought the vehicle). Thinking what I should do?
i know label has been taken of as person I bought car told me but doesn’t remember part number. He just says he had a Full front end collision and so face lifting cost Only a little more amount Than buying mk7 full front end. Dealers won’t know what headlight it is without VIN which I don’t have. Will it all have to be re-wired again? Is that the only solution? Right now all I have is the left light working the whole right light has malfunctioned. Waiting to see if my neighbours cameras caught what happened to the light at night.I would think you could go to the dealer and they can look it up for you. You have an R so it's the headlights without the red strips like the GTI has. If the dealer wants a VIN, just look on their lot and see if they have something with the same headlights and give them that VIN. You're sure these are OEM headlights and not reps right?
I’m thinking the only thing I can do, is order Two new headlight and then they have to be re-wires again? Unless I keep on orderIng right headlights and eventually fine the one that fits. But that’s would be quite difficult.Are you sure they're not aftermarket? I don't know if aftermarket puts the labels on but I don't see someone going through the effort to remove oem labels from a light
Just ordered a set of mk7.5 euro tails for my 17 Sport (will be ordering Zero's harness as well) off E-Acca! I've been in contact with Anna (E-Acca) and ZERO815 (forum) and they both have been super responsive and helpful with all the questions I had. Thank you all the information in this thread. Can't wait to get and install them!!
