Hi all I have retrofitted 5G1052200C With the electrical conversion kit 5G0 052 400 and (4x tail light connector 1K8 972 928 B) and followed the supplied instructions and pulled the yellow cable to BCM Socket C Pin6 and Connected everything like I suppose to do. Dynamic lights are working brake lights are working revervese lights working but I cant get the Running lights to work not on the inner lights or outer lights. But if I remove the yellow cable from chamber one and put in chamber 3 instead then almost everything works but then the outer light stopped working dynamic sweep and just blink regular so the inside are dynamic and outside works regular and the running lights only works when the car is parked, Please someone help me I have been at this for a whole week up to 10hrs a day switching cables trying to code differently with VCDS, you guys are my last hope sincerely Markus.
Ps. I live in Sweden
Problem has been solved thanks to ZERO815 ty once again my friend?
