MK7.5 OEM LED Tails
G7Lover
Poland
MK7 GTI
Hi. I've chosen option 2, rewired and recoded and inner lights work. But.. I have a problem with outer lights. As my gti is a NAR version, and I fitted EU tailights I've recoded brake lights, indicators but I messed somehow. Could anyone share eu codings for leuchte18, 19, 20, 21 and 23, 24, please? Can't figure proper coding.
bobloblawGTI
DC
19 GTI SE 6MT
Oh you're getting the dynamic GTI set. I thought you were referring to the EU MK7.5 low that ZERO815 posted. I just want mine to look like the EU MK7.5 low so I think the Valeo outer tails are what I need?
Long shot, but does anyone know the part #s necessary to get this middle column on an NA Mk7.5? Looks like just an outer tail would be necessary but everything I'm finding online is the right dynamic column.
geokilla
Toronto, Ontario, Canada
2018 VW GTI DSG
Yep it's in the forums here somewhere. 5G0945095Q and 5G0945096Q with the @ZERO815 harness is what I used. He sent me custom coding too. Man is amazing!
geokilla
2018 VW GTI DSG
Nice, thank you! And they match the NAR inners? Just getting the outers would definitely be hella cheaper.
Yes all I did was replace the outers. You can search for the Valeo ones vs OEM VW ones. I got the OEM VW ones thinking it'll be better built. Turns out they're still made and marked as Valeo so I overpaid for them lol. I bought the OEM ones off E-Acca. Cars245 sold the Valeo ones. Probably still do.
parms747
Toronto, Canada
2016 MK7 Golf TSI
Do you have any photos/videos of how this looks? Would love to see the amber turn signals!
Winrahr
Bay Area, CA
MK7 GTI
I bought the dynamic replicas not knowing that they had a significant brake light delay, and for safety reasons I cannot run them (even though the new versions with the startup animation looks amazing).
So now I am looking to run OEMs, but my situation is a bit different. I have a NAR car but the previous owner has added wiring to the BCM for full ROW functionality.
I don't quite want to pull my interior apart to do the same thing, so I'm wondering if there's a ROW MK7 LED to ROW MK7.5 Dynamic harness that I can buy, and what drawbacks it would have.
Or I could run a NAR dynamic harness since I just have more pins than needed?
ZERO815
Köln Germany
2017 GTI SE DSG
No need to take the interior apart. No drawback if you use a ROW MK7 LED to ROW MK7.5 dynamic harness. It's even the better solution IMO.
Winrahr
Bay Area, CA
MK7 GTI
Awesome, thanks! I assumed there's probably enough channels to go around but not sure if such harness existed.
Is e-acca still the best place to source OEM tails?
geokilla
2018 VW GTI DSG
Just Google MK7 or MK7.5 dynamic tails and a whole bunch of shops should come up. E-Acca and Cars245 doesn't come up but you can buy from there too.
duckboss
NY
2017 GTi
I'll check tonight when I get home, I don't believe I touched that one at all per the coding instructions. I'll look at what it's coded as presently, and try setting it to Active.
Here's what I worked off of (wrote down the old values in pencil just in case)
Thank you!
That absolutely did not work lol
Car is gone to carvana. Someone getting cool tail lights lol
duckboss
NY
2017 GTi
Hi, I have a set of factory 2019 GTi tail lights. Does anyone make a harness so I can fit them to my 2015 Golf TDi
dmsyr
New Mexico
ricola_mk7.5
Miami
2019 Mk7.5 GTI
Having two fault codes since I had my Mk7.5 euros installed on my Mk7.5 NA.
Does anyone have have an idea? Or could someone take some time to double check my long coding please?
