Please share pics of the plugs.
Those are the plugs on the lights
Those are the plugs on the DAP harness.
Oh really lol Ok i'll give it a shot thanks!View attachment 185139
Trim connector w/ knife. Should have come that way from DAP imo. VW uses hardware and color coding „Poka Yoke“ system. Remove hardware coding and you‘re good to go.
The lights themselves appear to be the same according to the part numbers. Looks like the more expensive kit are individual collected lights while the second option is the official retrofit-kit including wiring for MK7.5 cars.
Thank you for your reply. What do you mean by individual collected lights? On the cheaper one it explicitly mentions that it's not compatible with mk7 golfs, while on the other hand the expensive one does not.![]()
Oh right, that explains a lot. Thanks.It means that they put the kit together themselves by bundling each individual light/part number. The other kit is the official retrofit kit from VW and only has 1 part number.
Still getting this error after coding Leuchte27NSL back to stock.Coding for rear side marker lamp:
Leuchte27NSL RC6-Lasttyp 27 41 - LED Kleinleistung
Leuchte27NSL RC6-Lampendefektbitposition 27 0
Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 54
Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
Leuchte27NSL RC6-Lichtfunktion B 27 not active
Leuchte27NSL RC6-Dimmwert AB 27 127
Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always
Leuchte27NSL RC6-Lichtfunktion C 27 not active
Leuchte27NSL RC6-Lichtfunktion D 27 not active
Leuchte27NSL RC6-Dimmwert CD 27 0
Leuchte27NSL RC6-Dimming Direction CD 27 maximize
Leuchte27NSL RC6-Lichtfunktion E 27 not active
Leuchte27NSL RC6-Lichtfunktion F 27 not active
Leuchte27NSL RC6-Dimmwert EF 27 0
Leuchte27NSL RC6-Dimming Direction EF 27 maximize
Leuchte27NSL RC6-Lichtfunktion G 27 not active
Leuchte27NSL RC6-Lichtfunktion H 27 not active
Leuchte27NSL RC6-Dimming Direction GH 27 0
Leuchte27NSL RC6-Dimmwert GH 27 maximize
Ok, last question: anyone with a US model with halogens, preferably a 2017, have the original coding for the following channels under 09 - Central Electronics:
Leuchte27NSL RC6 - Dimmwert AB 27
Leuchte27NSL RC6 - Lasttyp 27
Leuchte28RFL LC11 - Lampendefektbitposition 28
Leuchte28RFL LC11 - Lasttyp 28
Leuchte28RFL LC11 - Lichtfunktion A 28
I copied a Canadian members adaptations to revert back and the issues I'm having are 1) the running lights don't turn on either in the running light switch position or lights on switch position and 2) brake light overrides turn signals. Everything else seems fine but suspect these two channels might be different cuz his had some kind of LED input for one of them.
| (1)-Leuchte27NSL RC6-Lasttyp 27 | 36 - LED Kleinleistung |
| (2)-Leuchte27NSL RC6-Lampendefektbitposition 27 | 0 |
| (3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 | 47 |
| (4)-Leuchte27NSL RC6-Lichtfunktion A 27 | Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) |
| (5)-Leuchte27NSL RC6-Lichtfunktion B 27 | not active |
| (6)-Leuchte27NSL RC6-Dimmwert AB 27 | 127 |
| (7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 | Always |
| (8)-Leuchte27NSL RC6-Lichtfunktion C 27 | not active |
| (9)-Leuchte27NSL RC6-Lichtfunktion D 27 | not active |
| (10)-Leuchte27NSL RC6-Dimmwert CD 27 | 0 |
| (11)-Leuchte27NSL RC6-Dimming Direction CD 27 | maximize |
| (12)-Leuchte27NSL RC6-Lichtfunktion E 27 | not active |
| (13)-Leuchte27NSL RC6-Lichtfunktion F 27 | not active |
| (14)-Leuchte27NSL RC6-Dimmwert EF 27 | 0 |
| (15)-Leuchte27NSL RC6-Dimming Direction EF 27 | maximize |
| (16)-Leuchte27NSL RC6-Lichtfunktion G 27 | not active |
| (17)-Leuchte27NSL RC6-Lichtfunktion H 27 | not active |
| (18)-Leuchte27NSL RC6-Dimmwert GH 27 | 0 |
| (19)-Leuchte27NSL RC6-Dimming Direction GH 27 | maximize |
| (1)-Leuchte28RFL LC11-Lasttyp 28 | 9 - allgemeine Gl¸hlampe 27W; auch H15 |
| (2)-Leuchte28RFL LC11-Lampendefektbitposition 28 | 0B |
| (3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 | 31 |
| (4)-Leuchte28RFL LC11-Lichtfunktion A 28 | Rueckfahrlicht |
| (5)-Leuchte28RFL LC11-Lichtfunktion B 28 | not active |
| (6)-Leuchte28RFL LC11-Dimmwert AB 28 | 100 |
| (7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 | Always |
| (8)-Leuchte28RFL LC11-Lichtfunktion C 28 | not active |
| (9)-Leuchte28RFL LC11-Lichtfunktion D 28 | not active |
| (10)-Leuchte28RFL LC11-Dimmwert CD 28 | 0 |
| (11)-Leuchte28RFL LC11-Dimming Direction CD 28 | maximize |
| (12)-Leuchte28RFL LC11-Lichtfunktion E 28 | not active |
| (13)-Leuchte28RFL LC11-Lichtfunktion F 28 | not active |
| (14)-Leuchte28RFL LC11-Dimmwert EF 28 | 0 |
| (15)-Leuchte28RFL LC11-Dimming Direction EF 28 | maximize |
| (16)-Leuchte28RFL LC11-Lichtfunktion G 28 | not active |
| (17)-Leuchte28RFL LC11-Lichtfunktion H 28 | not active |
| (18)-Leuchte28RFL LC11-Dimmwert GH 28 | 0 |
| (19)-Leuchte28RFL LC11-Dimming Direction GH 28 | maximize |
Here is everything from both channels:
(1)-Leuchte27NSL RC6-Lasttyp 27 36 - LED Kleinleistung (2)-Leuchte27NSL RC6-Lampendefektbitposition 27 0(3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 47(4)-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) (5)-Leuchte27NSL RC6-Lichtfunktion B 27 not active (6)-Leuchte27NSL RC6-Dimmwert AB 27 127(7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always (8)-Leuchte27NSL RC6-Lichtfunktion C 27 not active (9)-Leuchte27NSL RC6-Lichtfunktion D 27 not active (10)-Leuchte27NSL RC6-Dimmwert CD 27 0(11)-Leuchte27NSL RC6-Dimming Direction CD 27 maximize (12)-Leuchte27NSL RC6-Lichtfunktion E 27 not active (13)-Leuchte27NSL RC6-Lichtfunktion F 27 not active (14)-Leuchte27NSL RC6-Dimmwert EF 27 0(15)-Leuchte27NSL RC6-Dimming Direction EF 27 maximize (16)-Leuchte27NSL RC6-Lichtfunktion G 27 not active (17)-Leuchte27NSL RC6-Lichtfunktion H 27 not active (18)-Leuchte27NSL RC6-Dimmwert GH 27 0(19)-Leuchte27NSL RC6-Dimming Direction GH 27 maximize (1)-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Gl¸hlampe 27W; auch H15 (2)-Leuchte28RFL LC11-Lampendefektbitposition 28 0B (3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31(4)-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht (5)-Leuchte28RFL LC11-Lichtfunktion B 28 not active (6)-Leuchte28RFL LC11-Dimmwert AB 28 100(7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 Always (8)-Leuchte28RFL LC11-Lichtfunktion C 28 not active (9)-Leuchte28RFL LC11-Lichtfunktion D 28 not active (10)-Leuchte28RFL LC11-Dimmwert CD 28 0(11)-Leuchte28RFL LC11-Dimming Direction CD 28 maximize (12)-Leuchte28RFL LC11-Lichtfunktion E 28 not active (13)-Leuchte28RFL LC11-Lichtfunktion F 28 not active (14)-Leuchte28RFL LC11-Dimmwert EF 28 0(15)-Leuchte28RFL LC11-Dimming Direction EF 28 maximize (16)-Leuchte28RFL LC11-Lichtfunktion G 28 not active (17)-Leuchte28RFL LC11-Lichtfunktion H 28 not active (18)-Leuchte28RFL LC11-Dimmwert GH 28 0(19)-Leuchte28RFL LC11-Dimming Direction GH 28 maximize
Brake light / Running lights / Turn signals on NA MK7s are under channel 20&21.Thanks man! Strange.....have the same values as you for these two channels but still having issues with the running lights + brake light override.
These are the only other channels I would have made adaptations for:
Leuchte20BR LA71
Leuchte21BR RC8
Leuchte23SL HLC10
Leuchte24SL HRA65
Could I bother you for the stock values from these as well? Guessing there is some mismatch somewhere, just have to find it. Thanks again for your help.
