MK7.5 OEM LED Tails
VW Motorsport
West
Daohaus
SoCal
Mk7.5 Golf R
t1m1t
SoCal
Mk7 GTI Sport
Just a heads up for anyone purchasing from E-Acca or any other overseas supplier. I purchased my set of 7.5 tail lights and they shipped via FedEx (ordered May 7, order shipped June 10). Apparently FedEx's hub in France is down 80% in staff (from what I was told by multiple CSRs) due to the Covid-19 pandemic, so anything passing through will be stuck there for a while... My tail lights got to "ROISSY CHARLES DE GAULLE CEDEX FR" and has been there for now 10 day without any sign of moving any time soon. Not all packages go through that hub apparently, but if yours does, it may take a while... It's so painfully not seeing any movement hahaha...
halluxvalgas
New Hampshire
My right dynamic tail light not working. It WAS working last night. It does blink standard style, just not dynamic.
The left tail light DOES blink dynamic style.
I ran the wiring for rear fog light using the Shopdap wiring harness and the facelift taillights (OEM).
I coded with the Shopdap App in OBDeleven. I am receiving in OBDeleven: Central Electronics Fault: Left brake lamp/turn signal bulb (open circuit/short circuit to B+)
I do NOT have the switch installed for the fog lights to make the rear fog work. Didn't know if I had to have that installed before coding for rear fog light?
I triple checked the wiring and made sure all the pins are seated correctly.
Car: 2017 VW GTI Sport.
Any help is appreciated!
glin60
UK
Mk 7.5 Golf R
Finished reading all 220 pages in this thread... what a journey these lights have been for many. I'm late to the party, but glad I read through everything, I know I learned a ton and probably saved a bunch of annoying questions... PM sent to ZERO815 for harness build... again, thanks to the trail blazers who figured all this stuff out the hard way.
Daohaus
SoCal
Mk7.5 Golf R
man kudos to you for reading all these pages
glin60
UK
Mk 7.5 Golf R
Have a random question on light clusters. I found a nice used set from eBay in the UK, but prior to shipping, the seller noticed the cluster on the left hand side is missing the black plastic cover panel that goes over the top/side of the light. Easy answer is walk away, but the deal is good and the lights otherwise are in good shape (the specific panel on the lights in pics below). Question is, do you guys know if this panel is swappable from the US spec to Euro tails? Or even replaceable for that matter? I don't mind cannibalizing my US tails for the panel and/or keeping an eye out for a replacement as long as everything will go back together cleanly.
Thanks in advance!
Andy
2017GTI4me
NJ
2017 GTI Autobahn
I'm having a similar issue with the ShopDap harness, except I'm not sure if mine is coding-related or a wiring issue. I followed their install video and have the harness pinned to run a rear fog.
I finished the coding (or at least think I did) but my left reverse light is always on like a rear fog, and the rear fogs function as my reverse lights. I have a euro switch and the rear fog functionality does nothing.
Also, when I activate the left turn signal, both dynamic signals flash. When activating the right turn signal, nothing.
Any thoughts? Thanks in advance.
2017GTI4me
NJ
2017 GTI Autobahn
Update: Found that I coded the right turn signal to blinken links hellphase instead of blinken rechts hellphase. Dynamic signals work perfectly now.
Still struggling with the rear fog and reverse lights though. Now both rear fog lights are on when in reverse. The reverse light that was previously always on does not come on at all any longer. Does anyone have a paper copy of ShopDAP instructions that they can scan or take a pic of?
ZERO815
Köln Germany
2017 GTI SE DSG
What is the current coding of Leuchte28 and Leuchte29?
2017GTI4me
NJ
2017 GTI Autobahn
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 Stored value maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 Stored value maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 Stored value maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 Stored value 100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 Stored value 0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 Stored value 0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 Stored value 0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 Stored value 31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 Stored value 00
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 Stored value 32 - allgemeine LED bis 12W
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 Stored value only_if_closed
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Stored value Nebelschlusslicht auch wenn ein Anhaenger gesteckt
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 Stored value not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 Stored value not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 Stored value not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 Stored value not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 Stored value not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 Stored value not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 Stored value not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 Stored value maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 Stored value maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 Stored value maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 Stored value 100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 Stored value 0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 Stored value 0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 Stored value 0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 Stored value 32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 Stored value 1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 Stored value 9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 Stored value only_if_closed
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Stored value Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 Stored value not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 Stored value not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 Stored value not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 Stored value not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 Stored value not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 Stored value not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 Stored value not active
ZERO815
Köln Germany
2017 GTI SE DSG
Hey,
Doesn't look like your issue is in the coding. Light channel Leuchte28 is used as rear fog, light channel Leuchte29 as reverse. There are some things I would change to have both channels closer to the OEM coding but that shouldn't effect your fault.
Just as a test, please change the coding for:
- LichtfunktionA28 to "aktiv 100%" and report back what happens. My guess is the left reverse light is on all the time. Afterwards change it back to "Nebelschlusslicht ..."
- LichtfunktionA29 to "aktiv 100%" and report back what happens. My guess is both rear fog lights are on all the time. Afterwards change it back to "Rueckfahrlicht"
mcg0
Canada
2018 Golf R
I'm glad I found this thread... was interested in picking up the dynamic LED tails for MK7.5 cars and everyone's contributions was really helpful!
