MK7.5 OEM LED Tails
Kip2MyLou
Because the inner ones wouldn't match up then. The dynamic set inners (ones I posted) aren't the same as the non dynamic inners (ones that come stock NA cars).
Clem604
Vancouver BC, Canada
2018 VW GTI
Why not just buy the outer tails?
The NA LED's are different from the Euro tailights and wouldn't match up
geokilla
Toronto, Ontario, Canada
2018 VW GTI DSG
Oh you're getting the dynamic GTI set. I thought you were referring to the EU MK7.5 low that ZERO815 posted. I just want mine to look like the EU MK7.5 low so I think the Valeo outer tails are what I need?
Nerwin2
Barcelona
Did any of you guys buy the aliexpress harness? I bought this one https://m.es.aliexpress.com/item/1000005098361.html
I have an Euro GTI MK7 and i have bought the OEM EU Dynamic tail lights from a GTI MK7.5. I ve been trying to put them in my car but the Aliexpress harness is not working with any of the codings. So far i tried to contact the seller asking for instructions or coding because he didn't provide anything and all i got from this **** chinese is: "go to a professional installer"
Can anyone send me the coding for this harness?
Thanks
ZERO815
Köln Germany
2017 GTI SE DSG
What lights were in your car before?
goldhawks
NE Indiana
'16 GTI DSG, PP
Hey, I'm looking to get some help with coding on a 2016 Mk7 upgrade to 7.5 dynamic tails. Bought from Black Forest and the instructions I got were the BEC ones. Install went fine and tested the tails before coding and it worked normally.
After coding however, left turn signal turns both turn signals on and right signal doesn't turn either. I've gone through my coding and can't find anything, but I'm sure that's where the issue is. Anyone have any clues?
Sent from my Pixel 2 XL using Tapatalk
ZERO815
Köln Germany
2017 GTI SE DSG
Looks like you selected „Blinken links Hellphase“ instead of „Blinken rechts Hellphase“ for the right turn signal. Links = left and rechts = right. I guess you should check the Leuchte24 setting for that.
gingerbits26
Cyprus
[FONT=&quot]My 2014 MK7 applied dynamic led taillights.I used your cable diagram[/FONT][FONT=&quot][/FONT]
[FONT=&quot]But after application i had some problems.Left taillights dynamic led turn signal a little bit slow from right side.I send you videos you will see that.And when i give right or left turn signal, my car gauge turn indicator very fast flashing.Can you help me ?
[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]Note: I send all videos,coding via "wetransfer" you can see we transfer link below.[/FONT]
[FONT=&quot]wetranfer link : [/FONT]https://we.tl/t-zKeLOHzwH2
gingerbits26
Cyprus
I’m having problems where the dynamic blinkers, reverse, brake and outer lights work, but not the inner tails when in drl or when light switch is fully on. I’ve tried watching videos and codes that others provided on fb, but still not working. Pins are in place as instructed. These are the 7.5 helix tails with the harness that came with it. I’ve reverted back to BECs coding guide. Please help and thanks in advance.
Please send your pin connection diagram
Tapatalk kullanarak iPhone aracılığıyla gönderildi
blaqsheep
Canada
IS38 GTI
Does anyone have a OBD11 backup for stock 2018 NAR tails?
I installed and then uninstalled euro taillights and made coding modifications. I did my best to restore original settings but may have missed something as I am getting the current static fault.
Code:
09 Central Electrics
    System description: BCM PQ37BOSCH
    Software number: 5Q0937087AR
    Software version: 0243
    Hardware number: 5Q0937087AN
    Hardware version: 034
    Serial number: C86423101700V2
    ODX name: EV_BodyContrModul1UDSBosc
    ODX version: 018001
    Subsystems:
        System description: WWS    170823
        Software version: 0551
        Hardware version: 043
        Serial number: 97022066170909152622
        Long coding: 0E4DDD
        System description: RLHS
        Software version: 0105
        Hardware version: 047
        Serial number: S5Y17M10D09H02M52S44
        Long coding: 00A8DD
    Trouble codes:
        B145B15 - Rear side marker lamp bulb Open circuit/short circuit to B+
            Active
ZERO815
Köln Germany
2017 GTI SE DSG
Code:
    ODX version: 018001
    Subsystems:
        Long coding: 0E4DDD
        Long coding: 00A8DD
    Trouble codes:
            Active
Coding for rear side marker lamp:
Leuchte27NSL RC6-Lasttyp 27 41 - LED Kleinleistung
Leuchte27NSL RC6-Lampendefektbitposition 27 0
Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 54
Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
Leuchte27NSL RC6-Lichtfunktion B 27 not active
Leuchte27NSL RC6-Dimmwert AB 27 127
Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always
Leuchte27NSL RC6-Lichtfunktion C 27 not active
Leuchte27NSL RC6-Lichtfunktion D 27 not active
Leuchte27NSL RC6-Dimmwert CD 27 0
Leuchte27NSL RC6-Dimming Direction CD 27 maximize
Leuchte27NSL RC6-Lichtfunktion E 27 not active
Leuchte27NSL RC6-Lichtfunktion F 27 not active
Leuchte27NSL RC6-Dimmwert EF 27 0
Leuchte27NSL RC6-Dimming Direction EF 27 maximize
Leuchte27NSL RC6-Lichtfunktion G 27 not active
Leuchte27NSL RC6-Lichtfunktion H 27 not active
Leuchte27NSL RC6-Dimming Direction GH 27 0
Leuchte27NSL RC6-Dimmwert GH 27 maximize
