What options open up with the FL BCM?
Anyway, these all seem to have a light channel 35 which, I believe, is only for dynamic tail lights but this is not a physical connection channel
Someone lately published his Canadian MY18 adaptation map. Channel 35 is shown there as Hazard Warning Switch with C48.
Switched over from Scandinavian DRL to this mode however they are at full brightness (100) Does anybody know how to adjust the brightness of this channel?Yes Scandinavian DRLs tweak turns your license plate on too, which I don't like. It basically turns on your running lights with the DRLs, hence, turning on your license plate lights.
Go to Leutche27 -> Lichtfunktion B27 -> choose "Tagfahrlicht" (which means DRL)
FYI, I was using OBD11 for it.
Car went into dealer for a couple things and in process they reset the code on the car so now my lights are all kinds of messed up. Going to have to recode them.....really didnt want to have this hassle again....heres to hoping it works.
You can make a backup in the app. It's actually a good idea to make backups at least before you make changes in case you mess up somethingIs it possible to "save configuration" with OBDeleven after we make changes?
Why did the dealer reset the BCM back to stock?
Front assist had error codes so he cleared it and wiped my code. Idk how/why. Left the dealer with more problems then it went in with. Have audimant harness so I don't have a coding scheme to go with. I'm comparing to others and guess and check basicallyIs it possible to "save configuration" with OBDeleven after we make changes?
Also can someone PM me the jbale coding. Looked thru about 40 pages of the thread and didn't see anything.
Sent from my Pixel 2 XL using Tapatalk
Original audiamant coding that I know of was for row cars. The coding Marcel did I have a compaire to another audiamant NAR car but most of our coding and values are different. So I got the turn signals working again, the brake lights are correct but when u let off they shut off passenger, center, driver in that order not all at once. And the running lights show brake lights on with them. To fix that last time we swapped terminals 4 and 5 but I'm unsure what code was changed after that. Im stuck due to the dealer being a bunch of idiots.You'll need to follow the original audiamant coding and then make the change I sent to you to fix the flicker. I believe the rest of the wiring is different enough from mine that using my coding will only make things worse...
That's what I was using last night. I found the email after like 10 minutes of looking since I didn't add those files to my Google drive. Can you send me your vcds backup file for 09 cent elec? Like just the section for that module.I still have that spreadsheet that we put together of your codes and mine. I also still have the email that you sent me with your full output file if you want it.
