Change the Klemme 15 value (see the instructions sheet he gave you) to 100% active, and that should do it.
Sent from my SM-G930T using Tapatalk
That was it, thanks.
So... now that these have been out for a little bit. What is the cheapest option to go about this? Where is the best place to pick up a harness? I do not mind waiting awhile in order to avoid Shopdap's markup.
The cheapest way is DIY.
I wasn’t really into these lights on pictures but over the Christmas break I got curious if I could make my own harness. With the documents VW provides for the retrofit, Don’s Leuchte tutorial and my own experiences with my ‘17GTI I finally made my own harness. There is a lot of mystery around these harness’ and I guess there are a couple ways of doing it. I’d like to share my way with you now. If it happens to be that someone else is doing it the same way, I didn’t buy a single harness and copied it. By the way it works with no Fog/1x Fog and 2x Fogs.
I’m having trouble interpreting your spreadsheet. What modules or changes do I need to make to enable dual fog?
Sent from my iPad using Tapatalk
Very nice and thanks for posting this. I've been running dynamics for few monhs now, and it is definitely one of my favorite mods. What is the best way to source the VAG connectors etc?
Also, does anyone know/has time to elaborate on these settings? I always wondered why the FOGs wererent as bright (even though thay are set to max), and/or what other options are there avaialbe? Ie. dont make the warning hazards dynamic, rather flash only.
Best post in entire thread.The cheapest way is DIY.
I used the following material:
2x 5G0972715CAP 5-PINe-acca.com
2x 3AA972714CAP 4-PINe-acca.com
4x 1K8972928BPLUG 8-PINe-acca.com
24x 571-1241374-2-CTmouser.com
12x 571-964267-1-CTmouser.com
100ft AWG20 Amazon
2ft AWG16GND-Wire
2x 5G0972715 CAP 5-PIN e-acca.com
2x 3AA972714 CAP 4-PIN e-acca.com
4x 1K8972928B PLUG 8-PIN e-acca.com
24x 571-1241374-2-CT mouser.com
12x 571-964267-1-CT mouser.com
100ft AWG20 Amazon
2ft AWG16 GND-Wire
100ft AWG20 Amazon
2ft AWG16GND-Wire
This being said, I would really like to get the official coding from VW after the SVN code is applied. If anyone would like to provide that, please, let me know.
I haven’t had a chance to see the official coding for it. During my research I thought about different options and started with Klemme 30G=Batterie switched. The lights got “powered on” and all functions work. Today I tried one other option: “Versorgung LCM” = Supply Light Control Module? All I can say is everything works w/o faults. Going to keep Leuchte27 setting that way.
