MK7.5 OEM LED Tails
ZERO815
Köln Germany
Thanks for the info. Any idea how can I code them to be always on then with my DRL’s on?
Search in your Leuchte settings of xx= 16, 17, 20, 21, 23, 24, 27, 28 for LichtfunktionAxx = Standlicht... . Set LichtfunktionBxx to Tagfahrlicht (Daytime Running Lights).
E.g. LichtfunktionA27 is set to Standlicht..., change LichtfunktionB27 to Tagfahrlicht.
Makkish
Sweden
Ride
Golf GT TDI DSG
Hi all I have retrofitted 5G1052200C With the electrical conversion kit 5G0 052 400 and (4x tail light connector 1K8 972 928 B) and followed the supplied instructions and pulled the yellow cable to BCM Socket C Pin6 and Connected everything like I suppose to do. Dynamic lights are working brake lights are working revervese lights working but I cant get the Running lights to work not on the inner lights or outer lights. But if I remove the yellow cable from chamber one and put in chamber 3 instead then almost everything works but then the outer light stopped working dynamic sweep and just blink regular so the inside are dynamic and outside works regular and the running lights only works when the car is parked, Please someone help me I have been at this for a whole week up to 10hrs a day switching cables trying to code differently with VCDS, you guys are my last hope sincerely Markus.
Ps. I live in Sweden
Problem has been solved thanks to ZERO815 ty once again my friend🙏
lijetta18t
Is there anything plugged into Pin4 of the outer tail lights? Did you have LED tail lights or incandescent tail lights from the factory?
alexanderodd
Norge
Ride
GOLF MK7 R-line 2014
Non dynamic LEDs
Hey!
I've been trying to search far and wide and i can't seem to find anything about it.
I got a 2014 MK7 with the OEM LEDs. My car is a EU car as i live in Norway.
I want to upgrade from OEM MK7 LED to 7.5 NON(!) dynamic tails. Everyone's doing the dynamic 7.5 fit, but i actually like the non dynamic better.
My question is: Do i need new wiring on those non-dynamic tails or is it plug and play?
Thanks
ZERO815
Köln Germany
Hey!
Thanks
If you're able to re-pin connectors you'll need new connector housings (8-pin instead of 4-pin & 5-pin) / Otherwise just 4 short adapters from MK7LED to MK7.5non dynamic / Slightly different coding.
alexanderodd
Norge
Ride
Thanks!
Re-pin sounds like a lot of work as i have minimal tech skills :p
So if i just buy these adapters you're speaking of i can connect the tails and do coding?
Any idea where i can find these adapters?
geokilla
Toronto, Ontario, Canada
Ride
2018 VW GTI DSG
@ZERO815 I have a NA MK7.5 GTI and I got the regular Golf Euro 7.5 outer tails (5G0945095Q & 5G0945096Q) from E-Acca. Does a standard euro tail harness or do I need a different one? I know I need different coding too from what is usually posted on the forums, especially if I want to keep my tailights blinking while I signal.
ZERO815
Köln Germany
A harness for the MK7.5 dynamic LED tails doesn't work. You have several options: a) get short adapters for the outer tails to re-arrange the existing vehicle wiring b) re-pin the existing vehicle wiring and modify the existing vehicle plug yourself. In both cases there's some coding to be done. You'll have all NA light functions except for the side markers (EU parts don't have them) and separate amber turn signals.
geokilla
Ride
2018 VW GTI DSG
Are you able to direct me to purchase these adapters for option A? I'd rather not mess up the wiring and modify the plugs. Coding isn't too difficult with some direction as I was able to code it so the NA outer tails blink when I signal.
mopar22
Va/MI
He actually makes and sells adapters, would for sure recommend him
