Scrubby
- Netherlands
- Golf 7.5
Thank u! I have obd eleven at home but only used the simple coding . What is the difference between 8ix and 8it?
The changes i`ve sent are in German too, use the search option for the Leuchte appropriate to what i have sent under 09 module adaptions.Ok i tried to change some things, but there is like so many different things you can change and so many options in obd. I don’t know where to find those settings exactly. Also these settings look german while my obd is in english
can you send a copy of the 09 module adaptions on here?*Update. I managed to turn on the left drl and left turning light, after about 2 more hours i managed to turn on the right Drl with turning light. I am all happy because it’s a going somewhere. I arrive at my house, turn the car off and about 20 minutes later i want to show my neighbour the lights, but..... It fucking resets itself so nothing works again. If i connect my obd and just change the headlight coding to 2 or 3 they light back up, but again after i turn off the car, only 1 light or nonekeep working. Someone had this as well? Grr
also have you done the basic settings too in the 4b module?can you send a copy of the 09 module adaptions on here?
Have you done the basic settings in the multifunction module 4b?????????????/Is there a way to copy them without screenshots? All my settigs are exactly the same as awd16 in his first messages! Except for the headlight coding because it only lights up 1 light in coding 1, when i switch this to another number they both light up... but then again when i turn the car off, wait for a couple of minutes they stop working
Yes like awd mentioned, i have implemented all those settings.Have you done the basic settings in the multifunction module 4b?????????????/
i replaced my 4b module as i found it didnt have the same adaptions in, has yours? maybe thats your problem?The number is exact the same except for the letter C yeah. It says Afs cornerlight fault, carlightning fault and right blink light fault.
