MK7.5 OEM LED Headlights Retrofit
Scrubby
Netherlands
Golf 7.5
Ok i tried to change some things, but there is like so many different things you can change and so many options in obd. I don’t know where to find those settings exactly. Also these settings look german while my obd is in english
red9
Newbie
uk
The changes i`ve sent are in German too, use the search option for the Leuchte appropriate to what i have sent under 09 module adaptions.
make sure you copy original coding before changing any.
Scrubby
Netherlands
Golf 7.5
I can’t find any of these settings. I went to module 09, but it doesn’t recognize any of the settings in the searchbar. Also if i go to the led module and press long coding it says; failed to read long coding...
Any fixes for this?
Scrubby
Netherlands
Golf 7.5
Okay i found them and changed all those settings. For me i had to change the exact same setting but after changing all the settings, the headlights are still acting the same as before. What am i missing here?
Scrubby
Netherlands
Golf 7.5
*Update. I managed to turn on the left drl and left turning light, after about 2 more hours i managed to turn on the right Drl with turning light. I am all happy because it’s a going somewhere😅. I arrive at my house, turn the car off and about 20 minutes later i want to show my neighbour the lights, but..... It fucking resets itself so nothing works again🤣😭. If i connect my obd and just change the headlight coding to 2 or 3 they light back up, but again after i turn off the car, only 1 light or nonekeep working. Someone had this as well? Grr
red9
Newbie
uk
can you send a copy of the 09 module adaptions on here?
Scrubby
Netherlands
Golf 7.5
Is there a way to copy them without screenshots? All my settigs are exactly the same as awd16 in his first messages! Except for the headlight coding because it only lights up 1 light in coding 1, when i switch this to another number they both light up... but then again when i turn the car off, wait for a couple of minutes they stop working
