MK7.5 OEM LED Headlights Retrofit
Franswa
Belgium
Mk7 gtd abt
Monday,12,August,2024,15:18:57:38388
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
Dealer/Shop Name: All in Auto Elektronica
Workshop Code: 198 24750 050014
Mileage: 219596km-136450mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 29 2B 39 3C 42 44
47 4B 52 5E 5F A5 A9 C0 D6 D7
VIN: WVWZZZAUZHW162742 Mileage: 219596km-136450miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
29-Left Light -- Status: Cannot be reached 0100
2B-Steer. Col. Lock -- Status: OK 0000
39-Right Light -- Status: Cannot be reached 0100
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5E-Ctrl Head LR -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BS HW: 04L 907 309 R
Component: R4 2,0L EDC H23 1541
Revision: B5H23--- CVN: B4EC2C4A
Coding: 011D001A036405083000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
ROD: EV_ECM20TDI01104L906026BS_002.rod
VCID: 7CA00255D66238AA0BB-8028
VINID: 9E69EAAAA465A989C11821C408B0E7710C
7 Faults Found:
21472 - Databus
U1122 00 [00100111] - Implausible Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 219596 km
Date: 2024.08.12
Time: 14:13:42
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 29 °C
Intake air temperature: 30 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.680 V
Unlearning counter according OBD: 40
ACC variants-Bits 0-7: 2
CCS Switch-Bits 0-7: 2
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 49
ACC variants (coding)-Bits 0-7: 3
Acceleration: 0.000 m/s²
17165 - Databus
U1123 00 [00100111] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:16
Voltage terminal 30: 11.200 V
Cruise control switch actuation-Bits 0-7: 48
17156 - Databus
U1123 00 [00100110] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 219596 km
Date: 2024.08.12
Time: 14:11:04
Coolant temperature: 28 °C
Voltage terminal 30: 13.740 V
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 0
17919 - Cruise Control Switch (E45)
P0568 00 [01100100] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:17
Voltage terminal 30: 11.220 V
16697 - Implausible Data Received from Steering Column Control Module
U0429 00 [00100111] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:03
Cruise control switch actuation-Bits 0-7: 32
18875 - Cruise Control Switch (E45)
P0568 00 [00100111] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:16
17166 - Cruise Control Switch (E45)
P0568 00 [00100110] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 219596 km
Date: 2024.08.12
Time: 14:14:52
Cruise control switch actuation-Bits 0-7: 33
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 042 N HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5006
Revision: 06454104 Serial number: TFK01611150449 CVN: 00004DC0
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 24101A350E52A06A13B-8070
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
P1734 00 [00000010] - -
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 63346000000694
Coding: 01FA6BA13426096E477E0604C0C5A980D62C90E260039575186250F8C2A9430000000012121212B835351919323200
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
VCID: 79AE1B41D9500D8210D-802C
4 Faults Found:
32830 - Parking Brake Motors
C10E1 29 [10001001] - Signal Implausible
[IPB-Actuator: Actuator state UNKNOWN]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
32900 - Left Parking Brake Motor Voltage Supply
C100D 13 [10001001] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
32901 - Right Parking Brake Motor Voltage Supply
C100E 13 [10001001] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
32951 - Control Module for Electronic Parking Brake
C10E2 54 [10001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0425278139 Dataset Number: V03935252RB 0001
Coding: 032C0C
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_KessyHellaMQBAB 002019
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3B22C14993ECFF92421-806E
No fault code found.
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 CG HW: 5G0 907 044 CG
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002011420441101110500020010102A
ASAM Dataset: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 6E84381D901E5A3AB5F-803A
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
2 Faults Found:
262914 - Refrigerant Pressure
B10AB F0 [00001001] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
Outside temperature: 25.5 °C
Engine RPM: 0 /min
Compressor current: actual value: 0.000 A
Temperature downstream of evaporator: 26.7 °C
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 255 s
1048838 - Functional Limitation due to Energy Management
B10CD 00 [00001000] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 245
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
Voltage terminal 30: 10.6 V
CAN input signal(s) status-Transport mode: On
CAN input signal(s) status-Static current measuring mode: OFF
CAN input signal(s) status-Windshield wiper: OFF
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
CAN input signal(s) status-Wipe wash: OFF
CAN input signal(s) status-Rear window heater actual value: OFF
CAN input signal(s) status-Back-up lamp: OFF
CAN input signal(s) status-Actual value of windshield heater: OFF
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061632902558 Dataset Number: V03935237L 0001
Coding: 00111C66C24132FF0BA44080B11C07281C00000000000000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 04507AB5AE92406A73B-8050
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 161106 043 0551
Serial number: 161124091501
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y16M12D05H14M58S28
Coding: 00A8EE
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1629212S0
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000067718121
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001BO9Y700000
Coding: 181901
7 Faults Found:
10762 - Bulb for Right Tail Light
B12BF 15 [00001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:25:01
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 13.7 V
526359 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:57
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 13.7 V
568086 - Databus
U1123 00 [00001001] - Received Error Message
[LCM links - Blinker defekt]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:57
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 13.7 V
568342 - Databus
[LCM rechts - Blinker defekt]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:57
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 13.7 V
569092 - Databus
U1121 00 [00001001] - Missing Message
[LCM links Kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:57
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 13.7 V
576516 - Databus
[LCM rechts - Kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:57
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 13.7 V
929796 - Light Switch
U110B 00 [00001001] - No Communcations
[Lichtschalterkeine Kommunikation]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:58
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 13.7 V
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331633803899 Dataset Number: V03935236FM 0001
Coding: 0071155011
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 43D2B9A9EB1C87520A1-8016
1 Fault Found:
13637120 - Databus
[Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:03
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Component: ACC BOSCH MQB H10 0620
Dataset Number: V03935253UB 0001
Coding: 350047C151FFC428949C810530300600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002005
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 3C20C25596E2F8AA4BB-8068
10 Faults Found:
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [00001001] - -
[FAULT_ALIGNMENT_NOT_OK]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
Control Module temperature: 50 °C
Voltage terminal 15: 11.1 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Status_ACC_System: ACC_irreversible error
2086 - Databus
[FAULT_EPB_ACTUATOR_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
2162 - Databus
[FAULT_EPB_FAULT_STATUS]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
2163 - Databus
[FAULT_EPB_RESILIENCE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
2165 - Steering Column Control Module
B105D 00 [00001001] - -
[FAULT_GRA_TYPE_MISMATCH]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
2062 - Databus
U1123 00 [00001000] - Received Error Message
[FAULT_MAINSWITCH_FAIL]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 245
Mileage: 219596 km
Date: 2024.08.12
Time: 13:57:39
Voltage terminal 15: 11.0 V
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
[FAULT_MISALIGNMENT_VERTICAL]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
2064 - Databus
U1122 00 [00001000] - Implausible Message
[FAULT_MISMATCH_CONSTANT_CONTROL_UNIT_TYPE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:12:46
Control Module temperature: 45 °C
Voltage terminal 15: 13.6 V
Status_ACC_System: ACC_Init
2127 - Databus
[FAULT_OP_FAIL]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 254
Reset counter: 245
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:37
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0121
Serial number: 24101641350524 Dataset Number: V03935231PP 0001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3828DE45A2DAD48AAF3-806C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AS HW: 5Q0 959 655 AS
Component: AirbagVW21 003 0317
Serial number: 003TMR2AUZVH Dataset Number: V03935251WF 0001
Coding: 98FCC0C0000000005C5400CF000800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002154
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 117E43E1E1E025C2C8D-8044
Left seat belt tensioner:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34169667D05121641250
Coding: 333135
Right seat belt tensioner:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34169668D08121650298
Coding: 333135
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 000 612 16
Component: SideSensor_Df 001 0887
Serial number: 35700000000042B4402%
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 000 112 16
Component: SideSensor_Pf 001 0887
Serial number: 3580000000011524CF1E
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 480 400 112 16
Component: SideSensor_Dr 000 6149
Serial number: 35100019F23692E124D4
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 480 402 411 16
Component: SideSensor_Pr 000 6149
Serial number: 3520001AD2388B5477BE
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 112 16
Component: FrontSensor_D 000 6149
Serial number: 3550001B1234EB1591A0
Coding: 2D2D2D
1 Fault Found:
9440283 - Driver side knee airbag igniter
B100C 1B [10001001] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 03121604400306
Coding: 6C10
Shop #: WSC 24750 198 50014
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_VW37.rod
VCID: 094E6B8189B01D0200D-805C
4 Faults Found:
229131 - Cruise Control Switch
B1154 13 [00001001] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
Operating time: 300133 min
Terminal 30 power supply: 11.3 V
Voltage at switch: 4.98 V
Terminal 15 status: active
System status: 30
FF U GRA Plus Minus AD value: 254
FF U GRA Resume Cancel AD value: 254
FF U GRA Main Switch AD value: 115
FF U GRA Set AD value: 254
FF U GRA ACC AD value: 254
229147 - Cruise Control Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
System status: 30
229195 - Cruise Control Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
System status: 30
229211 - Cruise Control Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:04
System status: 30
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 791 HW: 5G1 920 791
Component: KOMBI 408 2180
Coding: 07AD31187F8C000801886B0B5400000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 698E4B01A9F0BD02E0D-803C
1 Fault Found:
16776970 - Databus
U1121 00 [00001000] - Missing Message
[LWR_AFS_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 219596 km
Date: 2024.08.12
Time: 14:12:27
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Component: STH-MQB 008 0075
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 3A2CC44D9CD6C69A597-806E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000150814
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 27111610801712 Dataset Number: V03935242HR 0001
Coding: 030100041F086800FB00027E9D0F00010001050000000000000000000000
GVL: 01573C100000060040CC80001004CC0000000000000300000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160003055380076474
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 5989422404
2 Faults Found:
131592 - No Communications with Undefined Control Module
U1126 00 [00001001] - -
[Timeout Knoten 0x08]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:23:50
Terminal 30 power supply: 13.6 V
Terminal 15: On
131752 - No Communications with Undefined Control Module
[Timeout Knoten 0xA8]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:21:53
Terminal 30 power supply: 13.5 V
Terminal 15: On
Address 29: Left Light
Cannot be reached
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000203672005
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 3430EA75BEB230EA83B-8060
Address 39: Right Light
Cannot be reached
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0422646198 Dataset Number: V03935221MX 0001
Coding: 02011103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0423346324
Coding: 020111
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 191116EKH14146 Dataset Number: V03935248YZ 0001
Coding: 003F1220D000048000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000012397530
Coding: 110000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Dataset Number: V03935249RP 0001
Coding: 9107
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GMD000QLP Dataset Number: V03935254VB 0001
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI_VW37.rod
VCID: 6D863F119D18A1228C5-8038
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0346
Serial number: 01021911600494 Dataset Number: V03935286KS 0001
Coding: 000000050900194A01101F60220000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3536D771B5C829E2B45-8060
4 Faults Found:
0016 - Databus
U1121 00 [10001001] - Missing Message
[BCM_05 data bus missing message]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:30
131080 - Databus Front Lights
U1504 00 [10001001] - No Communications
[Databus AFS no communication]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:30
13706005 - Databus
U1123 00 [10001001] - Received Error Message
[BCM1_LDS_Stellung received error value]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:30
0032 - Headlight
C107E 54 [10001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:24:30
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 211116EK609278 Dataset Number: V03935249AG 0001
Coding: 003F1020DE00048000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 42DCBCADF4068E5A017-8016
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000012504607
Coding: 090000
Address 5E: Ctrl Head LR
Cannot be reached
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 043 D HW: 5NA 035 043
Component: MU-H-N-EU H54 1367
Serial number: A848G0HB007609 Dataset Number: V03935262VW 0001
Coding: 02738001FF0000005111000200080A001F0102F401200400DE
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 372ADD79AFC4DBF2A69-8062
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJV2642686
Data carrier:
Subsystem 2 - Part No SW: V03 959 806 NB HW: -----------
Component: ECE 2021 --- 0189
Serial number: --------------------
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
2 Faults Found:
1555 - Check Software Version Management
B201A 00 [00001001] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:22:39
Voltage terminal 30: 13.9 V
Status_Software_Version_Management-module_name: MMIBLite/MIBLite
13697024 - Component Protection
U1100 00 [00001001] - No Basic Setting
[Anti-theft protection - component protection: no basic setting or basic setting incorrect]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 14:22:34
Voltage terminal 30: 13.8 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 07121612P10394 Dataset Number: V03935243PT 0001
Coding: 0003070000000401002623548040A90094000E100040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
1 Fault Found:
1122675 - Databus
[TIMEOUT_LWR_AFS_02]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 219596 km
Date: 2024.08.12
Time: 13:55:03
Control Module temperature: 52 °C
Vehicle speed: 0.00 km/h
System run time: 1322.0 s
mid: 01 E8
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 161106202225
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_003_VW37.rod
VCID: 6B823109A30CAF12921-803E
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 5G0 907 160 HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0006
Serial number: 161004201408
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS_VW12.rod
VCID: 639259294BDCE7522A1-8036
Address D6: Light Ctrl Left 2
Cannot be reached
Address D7: Light Ctrl Right 2
Cannot be reached
End----------(Elapsed Time: 02:22, VBatt start/end: 13.7V/13.7V)-----------
Franswa
Belgium
Mk7 gtd abt
This is the full log of my car. I don't have connection between module 4b and the lamps. Cannot reach module D6 and D7.
DV52
Australia
Wow, what a mess - this car certainly has a very, very DTC rich SCAN report!
Yes, the lighting system on this car does indeed have a problem with the "connection between module 4b and the lamps"!
I assume that the modules 29, 39, D6 and D7 are properly registered in the Gateway Installation List (I have no idea about the status of the 5E module - does this car even have this module installed?). And do your new Headlight fittings use the 29 & 39 modules?
The fact that the 4B module is reported on the SCAN means that the Extended CAN bus is working - but the "cannot be reached " errors on both left-side and right-side lighting modules suggests that the AFS CAN bus is not operating. It's not clear why - maybe one of the missing modules is shorting the CAN bus (I'm guessing, of course).
My sense is that there are both coding and wiring problems with the lighting modules on this car - I suggest that you concentrate on the latter first. Check CAN wires for correct polarity on the AFS modules and measure voltage on the power-supply pin(s) - meaning the "KL 15a" pins on my 8IT wiring diagram above.
Don
Gearloose
Greece
Golf CZEA
Hi, apologies for being a noob and asking noob questions, but I just need some help and assurance before I start ordering things.
I have a mk7 with "bi-xenons" and AFS and cornering lights, either a servo steering the xenon beam and/or diagonal halogen lights depending on speed.
I take it that my job will be easier than what AWD4416 did.
I take it that I already have an AFS and 4B module.
Just to get a general idea, you reckon I will need "just" the headlights themselves, some wiring adjustments and a bit coding to get 8IU led headlights installed and working?
Any particular heads-up that you may want to share with me?
Gearloose
Greece
Golf CZEA
Thanks!
Indeed, I just received my VCDS and did that - I should have also read the initial instructions better!
Since I don't have the 4B module, should I be opting to get a particular version of it from a particular car - or would I be OK with just about any used 4B module?
Note that I read something about flashing it... I will not be able to do that.
Also, would I need an updated (from mk7.5) BCM?
DV52
Australia
:LOL: I agree. I think maybe instead of retrofitting lights they should focus on the other countless databus errors on the other modules first.
Yes indeed - I suspect that lots of "countless databus errors" are the consequential result of just a few other key DTCs.
@Franswa: accepting @git443 excellent recommendation as a prudent way forward for this car - maybe focus in the first instance on the Fault-priority: 2 DTCs in your SCAN report
Don
2018gti
Boston, MA, USA
Golf GTI Autobahn MT
@vw019283 did you end up figuring this out?
I'm currently stuck with the same problem as you, I'm getting some data record invalid issues.
edit to add more info: I’m having a problem with the 4B module, it’s currently giving me a “Data set RTM not valid” fault code (among many other “RTM” related ones) which when I search that on google there are essentially zero results 😀 🔫 the 29,39,D6,D7 modules just have one error code each which is: high beam variant implausible.
It may have been a bad idea to update my 4B module... I went from 0286 to 0367 and that wiped all the coding and adaptations, and maybe it wiped some more stuff too that the parameters aren’t filling back in. ugh..
everything has been resolved - i just need to check the adaptations more closely. "RTM_DTC" and "RTM_data_set" need to be set to not activated.
Headlights
Boston, MA
MK 7.5 GTI
Hey 2018gti and anyone else who can help,
I got a couple of questions for you about your retrofit since it seems that you had some of the same issues that I am having. I read through this whole forum but I couldn’t find the exact information I was looking for.
Just to note I have a VCP with an active subscription, and all my modules, to my knowledge, have the correct software and firmware
  • We’re you ever able to find how to change the head lamp variant under the headlamp modules? Mine currently said e076 and e077.
  • How did you clear the “high beam implausible” error for D6 and D7? Does that have to do with the headlamp variant?
I have some more questions, but they are less directed at 2018gti directly.
  • For my control modules 29 and 39 I have 3 errors:
  1. data set implausible
  2. Supply voltage too low
    • I am confused by this one since I checked the voltage and it is getting 12 volts
    • Because of this low voltage I cannot flash firmware
  3. Terminal 15 implausible signal
  • My last question has to do with the correct flash files which I downloaded from VCP, I just want to make sure I was using the correct ones.
    • 7P5941572A_golfE_ D6_left 8IU_STANDARD flash
    • 7P5941572A_golfE_D7_right_8IU_STANDARD.flash
    • 8V0907399D_BIU_STANDARD_LCM_29.flash (if I could flash but voltage error)
    • 8V0907399D_BIU_STANDARD_LCM_39.flash (if I could flash but voltage error)
    • 4B I did not flash yet since I got it directly from a 2019 GTI
Any and all help on these issues would be appreciated! Everything up until this part has gone very smooth. I made this account and post in a rush (clearly with my username haha) so let me know if i need to provide some more info for people.
DV52
Australia
@Headlights: Hi.
hmm........ remote diagnostics on forums like this is very hit-and-miss even when the best information is provided by the post author - relying on short snippets of SCAN reports ain't a good idea!! No offense intended.
So based ONLY on your words (which means I'm really guessing) - maybe consider the following:
  1. Dataset implausible - clearly the 29/39 modules do not like the dataset/parameter-set version - it means that either the file versions are wrong, or the download to the modules was incomplete!! Also, if you haven't installed the correct dataset into the 4B module - maybe this has caused the "implausible" error in the slave modules?
  2. Supply voltage low - J667/J668 has just the 2 x power-supply pins (see OP's wiring diagram that I copied in my post at the top of this thread-page. My hunch is that this error may be connected to the KL 15 error
  3. Terminal 15 implausible signal - is this the ONLY T15 error on this car? If not, check the J329 relay - does it "click" with ignition-ON? If ONLY J667/J668 modules have the T15 error, check the voltage on pin #4/pin #8 on the 14 x pin connector. Is the voltage battery volts and do the volts disappear with ignition-OFF. If so, check the integrity of the earth connections on pin #5 & pin #7
  4. “high beam implausible” error for D6 and D7 - can't comment because there simply ain't enuff information! What are the errors (if any) on D6 and D7? Likely this error will not clear until the 29/39 errors are fixed and D6/D7 are otherwise error free
Maybe also consider starting again and post-up a copy of a FULL, unedited (meaning NO changes) SCAN report for this car as an attachment (don't dump the SCAN contents directly into your post). I'm sure that future replies will be much better informed if we can see how this car was factory built and we can see the Freeze-frame data that has been ommitted from the error information
Don
Headlights
Boston, MA
MK 7.5 GTI
@Headlights: Hi.
Don
Hey DV52,
Thank you for the quick response. This is my first retrofit so sorry if my original post was lacking needed details. Also I’m hoping I didn’t botch all the work I have done, which is completely possible. I attached the OBDeleven scan log (Edit: Added VCP scan), let me know if you need a different log.
I will do my best to respond to your responses above:
  1. I have not been able to change the data set on the modules due to the voltage being too low. As for the 4B that is a fair point, it did not have the exact same software that the AW used. Pardon me if this is an uninformed question, but can the incorrect software on the 4B result in the voltage error?
  2. The two power pins are transferring voltage to the headlights and modules.
  3. The terminal 15 errors on 29 and 39 are the only ones I could see. The volts do disappear when the ignition is off. Pins 5 and 7 do seem to be grounded / earthed correctly. This is probably important to mention, instead of splicing up the original 10 pin connector, in case I messed it up. I actually used the 10 to 14 pin adapter, so the grounds 5 and 7 are adapted to the original ground.
  4. The high beam error was the only error so I am hoping once I figure out 29 and 39 those will properly clear.
My knowledge in retrofitting is not the best so I really appreciate the help on this.
  • OBDeleven_Log_23NOV2024.txt
  • autoscan_VCP_23NOV2024.txt
DV52
Australia
@Headlights: Arrh......... that's much better - actual specific information ALWAYS provides clarity!! Thanks for the extra data.
So, please correct me if I'm wrong, but as I now understand from your latest post - this is the set-up:
  1. this "Yankee" car was factory built with Halogen headlight fittings (hence the "original 10 x pin headlight connectors").
  2. New headlight fittings (that have 14 x pin connectors) have been installed. These headlights are true OEM (meaning the new fittings are NOT manufactured by a third-party and advertised as "OEM")
  3. A new 4B (Multifunction Module} has been installed into the car and the factory wiring loom has been suitably modified for the new J745 module.
OK, I note that the new J745 is a 3Q0-series module and this car has been built on a 5Q0-series chassis. I can't comment on the suitability of this arrangement - hopefully, someone else is better placed to advise?
I'm intrigued by your words "I actually used the 10 to 14 pin adapter". The adaptor/harness is usually purpose built to suit a particular non OEM manufaturer's headlights. Cleary by design, the adaptor is expecting true OEM pin positions from the factory wires that terminate on the original 10 x pin connector. How did you manage this requirement given that you must have re-purposed the pin positions on the 10 x pin connector to accomodate the new headlights
Also, the Central eectrics module on your SCAN is complaining about the DRLs - how did your manage the DRLs on this retrofit project?
Don
Headlights
Boston, MA
MK 7.5 GTI
Don
Hello thanks again for the quick response,
Let me answer everything above:
1. Correct, this came stock with the halogen 10 x pin connectors.
2. I got the exact 14 pin adapter that the author used in the original post of this thread and have installed it in the same manor as him, the only difference is I did not splice up my original 10 pin, I moved wires around in the harness adaptor to be in the correct locations per the authors table on the first page. The headlights are OEM Volkswagen headlights.
3. The 4B has been installed, and the wiring loom has been modified.
Can you clarify what you mean by this “J745 is a 3Q0-series module and this car has been built on a 5Q0-series chassis” if I understand what you are saying, the 4B I have is built for a different model car?
Just to clarify what I said above, I moved wires around in the harness adapter to match exactly what I needed per the wire table the author created, not the original 10 pin, I didn’t want to mess up my original harness just in case I couldn’t get the headlights working right away. I have an excel sheet that I plotted out to make sure the wires went to the correct place if you want to see.
I am not sure why that is complaining about my DRLS. I am assuming since I haven’t been able to activate the basic settings for the headlights that is why it is upset. When I have the headlights on the DRLs are the only lights that actually work haha.
I am really hoping that there are not some wire placement issues, I saw in central electronics there were some “open circuits”
DV52
Australia
My bad about the 3Q0/5Q0 matter - I've re-looked at your SCAN and I now don't believe this is a problem!
Since you have confirmed that DRLs are working properly - I suspect the error is due to the fact that the central electrics module still thinks that it controls the original halogen DRLs. Have you disabled the factory Leuchte-sets for the DRLs? And have you done the same for ALL of the other halogen headlight lamps?
This matter goes to the more general question regarding what actual changes were made to the 09 module coding? Meaning how did you tell the 09 module that it should no longer control the factory halogen fittings and instead, pass control to the new J745 (and subsequently to 29/39 modules & D6/D7 modules via the newly installed Extended CAN bus)? Maybe post-up a list of your 09 module coding changes for this project?
I can't comment about the 10 x pin/14 x pin splicing/pinning. I too assume that this was done properly!!
Don
