vw019283
- The Netherlands
- Golf 7 GTE
GGrrrrrrr............... I hate the way that this forum implements advertisements!!! Why do I need to navigate through 3 x versions of the same ad to post a response?@DV52 The first one, which long code to use![]()
I don’t *think* the order really matters, as long as when you’re done with all 5 you clear the codes from all the modules and check what codes are remaining, if there are any. like the OP @AWD4416 mentioned you have to try different combinations until all the codes disappear. the 4B module seems to have a list of the variants it supports in its dataset and I’m assuming it checks 29/39/D6/D7 to see if they match.I have found all the same files as the russian done it with do you know in what order i need to flash the 5 modules? And the 4b pack has 4 different bundles 1 commen data en 3 for different versions, do you think i need to upload commen data + the right version for my car or only the right version for my car?
Hello dear, is this the schematic of the 8it?seems to me like the only thing you must do on a ROW car when switching from 8IT to 8IU is to interconnect pin 4 to pin 8.Also, there is nothing on pin 13, so it would be only for specific countries, I assume.
View attachment 278945View attachment 278946
Hello People,
I retrofited a 7gtd with xenon and afs to the 7.5 front.
My normal beam was not working after the retrofit.
I followed the procedure as outlined by @AWD4416. thank u very much for al the explanation.
after doing everything I still only have normal beam the rest is not working.
after checking everything I see that I didn't buy the 5GM941077A/5GM941078A but the 5g1941035/5g1941036...
I'm sure that's the reason its not working.
I searched for the 5GM941077A/5GM941078A headlights but I couldn't find it and if I do the price is too high for me.
Now I am searching the schematics for the 5g1941035/5g1941036, and the coding of these.
like I said I followed the hole proces of @AWD4416 so also the removal of the afs and the installation of the 4b module.
I hope somebody here can help me. I am out of ideas without schematics and coding for my lamps
I think all the mk7.5R have 2DRL. my mk7.5 headlights have only 1 DRLView attachment 308386
This is from a Canadian MK7.5 Golf R. Is this what you are looking for?
I just did a search on eBay for the part you posted:I think all the mk7.5R have 2DRL. my mk7.5 headlights have only 1 DRL
Hello sir,@Franswa agreed with @git443 I think you're fine with the lights you got already, the 035 and 036. I don't think you want or need the 077A/078A because those are specific to US/Canada, they have the orange reflector and orange marker light.
I think what you have (035/036) are the lower-line LEDs, the "8IT" if I'm not mistaken - with only one "U" DRL in each. if they're not working right I am guessing it's an issue with coding/parameters. I would scan all the modules for codes to figure out more what the problem is.
It look like 2 but have only 1 in each lamp. I have also only 1 module on each. The one with 2 DRLs have 2 modules on each lamp.
