MK7.5 NAR GTI - Enable static LED AFS lights when high-beams enabled?
quailallstar
WOB DJ496
Ormond Beach, FL
MY19 MK7.5 GTI Bunny
I often drive on very dark country roads at night and could use some additional side lighting. We have large deer and bears - something I don't want to hit going 85 mph/136 km/h.
I've already coded my LED AFS NAR-spec headlights to enable foglamps on - with high beams (no issues. we don't have vehicle inspections here).
Is it somehow possible to enable the static AFS sidelights when the high beams - are switched on?
This thread is also posted on the Ross-Tech forums, so If I get some answers there, I'll make sure and post findings here and vice versa.
Thank you all in advance! :cool:
Reggie Enchilada
WV
The AFS functions are controlled by the 4B multifunction module. You may be able to get the result that you're looking for by messing around with the Leuchte programming in the Central Electrics module.
If you're interested in unlocking the AFS capabilities to get some of the functions that the Euro market cars have, I did a write-up on it that you can find here.
quailallstar
WOB DJ496
Ormond Beach, FL
Reggie - thanks for posting those tweaks! I had already been using these very same tweaks on my GTI - for about two years now, and with great results. :cool:
Here's my adaptation map in hopes that someone like @DV52 can assist with my original question above (fingers crossed).
Code:
;SW:3Q0-907-338-C   HW:3Q0-907-338-C ---  Multifunc. Module
;Component:FCM MQB Low   002 0342     Coding:000000050900214A01113F00CA0000000000000000000000000000000000
;EV_MultiModulContiVW48X    2004    EV_MultiModulContiVW48X_002_VW37.rod
;Thursday    22    July    2021    07:31:51:61205
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210708 DS325.1
;VCID: 3537212475CF87F36C5-8060
IDE00001-Production mode    not active     3
IDE00820-Activating and deactivating all development messages    not active     1
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection    Yes     1
IDE01996-SFT00041-Installation list: specified installations-Left light control    Yes     1
IDE01996-SFT00057-Installation list: specified installations-Right light control    Yes     1
IDE01996-SFT00075-Installation list: specified installations-Multi-function module    Yes     1
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit    No     1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2    Yes     1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2    Yes     1
IDE01996-SFT33031-Installation list: specified installations-Antenna module    No     1
IDE02332-Deactivate production mode    0    3
IDE03641-Presentation run dynamic AFS light    active     1
IDE03642-Presentation mode    not active     1
IDE03679-Adaptive light functions    active     1
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE08418-Matrix light: total dimming    0.00%    1
IDE09156-Matrix headlamp: function at standstill    not active     1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1    OFF     12
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2    OFF     12
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3    OFF     12
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4    OFF     12
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5    OFF     12
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6    OFF     12
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7    OFF     12
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8    OFF     12
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9    OFF     12
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10    OFF     12
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11    OFF     12
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12    OFF     12
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13    OFF     12
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14    OFF     12
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15    OFF     12
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16    OFF     12
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17    OFF     12
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18    OFF     12
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19    OFF     12
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20    OFF     12
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21    OFF     12
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22    OFF     12
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23    OFF     12
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24    OFF     12
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25    OFF     12
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26    OFF     12
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27    OFF     12
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28    OFF     12
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29    OFF     12
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30    OFF     12
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31    OFF     12
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32    OFF     12
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33    OFF     12
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34    OFF     12
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35    OFF     12
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36    OFF     12
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37    OFF     12
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38    OFF     12
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39    OFF     12
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40    OFF     12
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41    OFF     12
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42    OFF     12
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43    OFF     12
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44    OFF     12
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45    OFF     12
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46    OFF     12
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47    OFF     12
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48    OFF     12
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49    OFF     12
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50    OFF     12
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51    OFF     12
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52    OFF     12
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53    OFF     12
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54    OFF     12
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55    OFF     12
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56    OFF     12
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57    OFF     12
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58    OFF     12
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59    OFF     12
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60    OFF     12
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61    OFF     12
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62    OFF     12
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63    OFF     12
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64    OFF     12
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65    OFF     12
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66    OFF     12
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67    OFF     12
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68    OFF     12
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69    OFF     12
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70    OFF     12
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71    OFF     12
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72    OFF     12
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73    OFF     12
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74    OFF     12
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75    OFF     12
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76    OFF     12
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77    OFF     12
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78    OFF     12
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79    OFF     12
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80    OFF     12
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81    OFF     12
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82    OFF     12
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83    OFF     12
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84    OFF     12
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85    OFF     12
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86    OFF     12
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87    OFF     12
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88    OFF     12
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89    OFF     12
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90    OFF     12
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1    OFF     12
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2    OFF     12
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3    OFF     12
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4    OFF     12
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5    OFF     12
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6    OFF     12
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7    OFF     12
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8    OFF     12
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9    OFF     12
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10    OFF     12
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11    OFF     12
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12    OFF     12
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13    OFF     12
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14    OFF     12
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15    OFF     12
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16    OFF     12
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17    OFF     12
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18    OFF     12
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19    OFF     12
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20    OFF     12
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21    OFF     12
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22    OFF     12
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23    OFF     12
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24    OFF     12
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25    OFF     12
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26    OFF     12
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27    OFF     12
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28    OFF     12
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29    OFF     12
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30    OFF     12
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31    OFF     12
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32    OFF     12
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33    OFF     12
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34    OFF     12
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35    OFF     12
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36    OFF     12
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37    OFF     12
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38    OFF     12
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39    OFF     12
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40    OFF     12
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41    OFF     12
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42    OFF     12
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43    OFF     12
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44    OFF     12
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45    OFF     12
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46    OFF     12
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47    OFF     12
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48    OFF     12
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49    OFF     12
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50    OFF     12
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51    OFF     12
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52    OFF     12
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53    OFF     12
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54    OFF     12
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55    OFF     12
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56    OFF     12
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57    OFF     12
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58    OFF     12
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59    OFF     12
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60    OFF     12
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61    OFF     12
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62    OFF     12
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63    OFF     12
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64    OFF     12
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65    OFF     12
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66    OFF     12
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67    OFF     12
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68    OFF     12
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69    OFF     12
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70    OFF     12
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71    OFF     12
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72    OFF     12
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73    OFF     12
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74    OFF     12
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75    OFF     12
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76    OFF     12
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77    OFF     12
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78    OFF     12
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79    OFF     12
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80    OFF     12
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81    OFF     12
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82    OFF     12
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83    OFF     12
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84    OFF     12
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85    OFF     12
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86    OFF     12
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87    OFF     12
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88    OFF     12
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89    OFF     12
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90    OFF     12
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1    OFF     3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2    OFF     3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3    OFF     3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4    OFF     3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5    OFF     3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6    OFF     3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7    OFF     3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8    OFF     3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9    OFF     3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10    OFF     3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11    OFF     3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12    OFF     3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13    OFF     3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14    OFF     3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15    OFF     3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16    OFF     3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17    OFF     3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18    OFF     3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19    OFF     3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20    OFF     3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1    OFF     3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2    OFF     3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3    OFF     3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4    OFF     3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5    OFF     3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6    OFF     3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7    OFF     3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8    OFF     3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9    OFF     3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10    OFF     3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11    OFF     3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12    OFF     3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13    OFF     3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14    OFF     3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15    OFF     3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16    OFF     3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17    OFF     3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18    OFF     3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19    OFF     3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20    OFF     3
IDE13611-Cornering lamp in operation    not active     1
IDE13612-Matrix head lamps: steering angle    9600.00 °    2
ENG124608-Order_Reference_Run_Activation_Effect    No dependency     1
ENG124607-Reference_Run_Activation_Effect    Activation effect disabled     1
ENG103979-Reference_Run_Start_Condition    Engine start     1
Elapsed Time: 00:11
