Has anyone done a swap with a 891B unit? Id rather get the NAR part than ROW
I see you have a 2017 R. any reason it wouldn't work on a 2018 GTI? I've only see confirmations on a 791B and supposedly the only difference is parking/brake is a symbol instead of spelled out on ROW vs NAR
Tuesday,22,November,2022,23:29:28:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0 HEX-V2 CB: 0.4622.4
Data version: 20220830 DS341.0
[URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL]
VIN: 3VWH17AU9KM521113 License Plate: 6
Mileage: 45222km-28099mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 3C 42 44 47
4B 52 5F 69 A5 CA D6 D7
VIN: 3VWH17AU9KM521113 Mileage: 45222km-28099miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13--- CVN: C87BA4D6
Coding: 311D00322476002F1000
Shop #: WSC 00066 790 00424
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS020_VW37.rod
VCID: 46D55605582413EB9DF-8012
VINID: 0E69D804746525B7450810410C70F68BA1
1 Fault Found:
17178 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 45222 km
Date: 2011.01.01
Time: 11:27:20
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 21 °C
Intake air temperature: 20 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.242 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: 1110 1101
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01907241007 CVN: 0000F57F
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 59EF8D79F99A8C13C0D-800C
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP
Component: ESC H35 0108
Revision: 00000000 Serial number: 52499000000175
Coding: 43FA6AA13022096D80780301A0C629C2560C9001C005943436435050F0A94B0B0040010312121212B435351919323200
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: 0655960518A4D3EBDDF-8052
1 Fault Found:
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:10:05
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0524995000
Coding: 132C0C0723
Shop #: WSC 00066 790 00160
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D75109652218F3945-8010
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 02020024200118010104004C12151008
ASAM Dataset: EV_ACClimaBHBVW37X 006146
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 48C9583D5230059B6F3-801C
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 087 BA HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C86408101907IF
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 00066 790 00395
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7BA3F7F153669E03B21-802E
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 190702 043 0551
Serial number: 97022066190718200736
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SAY19M07D29H07M13S38
Coding: 0008DD
Humidity sensor: interior:
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 BK HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0160
Serial number: 0100200620180C300539
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000137089R19220
Coding: 0271167911
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000.rod
VCID: 51FF7559A16AC45338D-8004
1 Fault Found:
13637426 - Databus
U1123 00 [009] - Received Error Message
[Tip-TNF 202621]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:10:05
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 350000C941FFC728949C810520400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D14C0D6E1821FB83B-8010
4 Faults Found:
0803 - Databus
[Tip-TNF 200959]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:10:05
Control Module temperature: 32 °C
Voltage terminal 15: 12.5 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Status_ACC_System: ACC_irreversible error
2101 - Databus
[Tip-TNF 201050]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:10:04
0928 - Databus
U1122 00 [009] - Implausible Message
[Tip-TNF 226082]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:10:04
2068 - Databus
[Tip-TNF 208229]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:10:04
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR0CJKCZ
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 47CB5B015F2E0AE3669-8012
Seat occupied recognition passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000C78S6L
Coding: 303136
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: ----------- HW: 480 002 108 19
Component: SideSensor_Df 001 0887
Serial number: 35700000000BE524CE3.
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: ----------- HW: 480 002 008 19
Component: SideSensor_Pf 001 0887
Serial number: 358000000005A18DBE3
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: ----------- HW: 480 403 107 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001B4F08AF87D64P
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 400 108 19
Component: SideSensor_Pr 004 6149
Serial number: 35200012A2C061F354D+
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 400 909 19
Component: FrontSensor_D 004 6149
Serial number: 3550001202CA45F192F5
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 909 19
Component: FrontSensor_P 005 6149
Serial number: 3560001BEF08AF82D92-
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 404 4191
Coding: 01AD501DED88080802887A0F5401000080000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2B0307B1E386CE83621-807E
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 16091900840961
Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
GVL: 01C63C0000000600C0DC80000000C80010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CEA51014FBAB05F-803A
Generator:
Component: 0-00-0d-00-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 40180000057370028175
Coding: 2FFFFF
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: U13DCAC H27 0810
Serial number: 8005883
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00005.06.19
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4CC1642D4648E9BB4BB-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000220598015
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F15D9C1AAA45358D-8064
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 B
Component: Sitzmemory H08 0024
Serial number: Y0006PLT16185
Coding: 001000020000040000C481808080000000000000000000F400
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide.rod
VCID: 3D2739E90DF25033CC5-8068
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0524726554
Coding: 02012103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0527161485
Coding: 020121
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F
Component: TSG FS 006 0247
Serial number: 42038927600805
Coding: 003A13200400040000000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 4FFB7321B75ED2A32E9-801A
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000004280958
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 930A0000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 50F9705DAA60CD5B373-8004
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD05WEVL
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E050EA5D094BBAB45F-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 05091900842308
Coding: 000000050900211200110F01030000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 353721C935C28873045-8060
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F
Component: TSG BFS 006 0247
Serial number: 46039925400235
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 4EC56E25B054DBAB25F-801A
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000004277407
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 853 0890
Serial number:
Coding: 027312020000000041220002001828009F0508F401200405C6
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 33331FD13BB696432A1-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 254 8130
Serial number: VWZ6ZMW2835791
Data carrier:
Subsystem 2 - Part No SW: 5NA 919 866 BF HW: -----------
Component: NAR 2021 --- 1510
Serial number: --------------------
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Tip-TNF 196497]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:10:04
Voltage terminal 30: 12.6 V
Status_Software_Version_Management-module_name: C
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0447495495
Coding: 0210000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 42DD4A15740C2FCBB17-8016
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 15071915K23323
Coding: 000307020002020100221355C150490084000E20012000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D9401D7A003DDBA73-8014
3 Faults Found:
1135140 - Databus
[Tip-TNF 194669]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:25:16
Control Module temperature: 31 °C
Outside temperature: 13.5 °C
Vehicle speed: 0.00 km/h
System run time: 2299.6 s
Voltage terminal 15: 12.6 V
mid: 02 65
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
1135139 - Databus
[Tip-TNF 194320]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:25:16
mid: 02 64
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
1123173 - Databus
[Tip-TNF 239588]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:25:16
System run time: 2299.3 s
mid: 02 E0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 00804073720C
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B7E1C97542C873C45-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F2DF919DA6C13E0D-806C
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:45, VBatt start/end: 13.2V/13.0V)-----------
When you edit, the 3 dot menu next to the pic attachment toolbar has more options. Code is the last one on the rightNot sure how I would paste in code format....
Wednesday,23,November,2022,14:15:14:16365
www.Ross-Tech.com
VIN: 3VWH17AU9KM521113 License Plate: 1
Mileage: 45225km-28101mi Repair Order:
VIN: 3VWH17AU9KM521113 Mileage: 45225km-28101miles
3C-Lane Change -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
1 Fault Found:
17178 - Databus
U1123 00 [047] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 45222 km
Date: 2011.01.01
Time: 20:46:13
Engine RPM: 1532.50 /min
Normed load value: 30.2 %
Coolant temperature: 13 °C
Intake air temperature: 15 °C
Voltage terminal 30: 11.445 V
Readiness: 0010 0101
Coding: 0014
2 Faults Found:
B1168 54 [008] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 59
Mileage: 45225 km
Date: 2011.01.02
Time: 01:43:09
0297 - Steering Angle Sensor
B1168 F2 [137] - Not Initialized
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 19
Mileage: 45225 km
Date: 2011.01.02
Time: 01:47:21
Coding: 132C0C0723
Revision: 00001K05
Coding: 0E4DDD
Coding: 0008DD
Coding: 0271167911
3 Faults Found:
13637426 - Databus
[Tip-TNF 202621]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:17
13679386 - Databus
[Tip-TNF 231800]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45225 km
Date: 2011.01.02
Time: 01:47:21
13688835 - Databus
[Tip-TNF 226614]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.02
Time: 01:21:00
5 Faults Found:
2055 - Databus
[Tip-TNF 224741]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45225 km
Date: 2011.01.02
Time: 01:47:22
Control Module temperature: 28 °C
Voltage terminal 15: 14.6 V
0803 - Databus
[Tip-TNF 200959]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:17
Control Module temperature: 37 °C
Voltage terminal 15: 12.8 V
2101 - Databus
[Tip-TNF 201050]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:17
0928 - Databus
U1122 00 [008] - Implausible Message
[Tip-TNF 226082]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:17
2068 - Databus
[Tip-TNF 208229]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:17
Coding: 303136
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Generator:
Coding: 2FFFFF
Coding: 0001
Coding: 02012103
Coding: 020121
1 Fault Found:
338048 - Databus
[Tip-TNF 215225]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.02
Time: 01:20:59
Coding: 011000
Coding: 930A0000
1 Fault Found:
16130 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Mileage: 45225 km
Date: 2011.01.02
Time: 02:10:05
Motor status: 01
System status: Driving mode
Supply voltage: 14.50 V
Temperature: 34.0 °C
KFC: 3F
KFA: 00 02
Freeze frame conditions: 5F
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 14.61 V
uAdSensI_SwitchedKl30_xdu16: 14.56 V
NoInitCause_AsicSens: [0x01] ASC_CTRL_SAS_HL_ERR - Error discovered by the High level application
NoInitCause_RackPos_Rohwert: 00 00
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_KMN_RACKPOS_SET: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_WHLSPDPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Coding: 091000
Serial number:
Data carrier:
1 Fault Found:
B201A 00 [009] - -
[Tip-TNF 196497]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 16
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:17
Voltage terminal 30: 12.9 V
3 Faults Found:
1135140 - Databus
[Tip-TNF 194669]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:18
System run time: 178.1 s
mid: 02 65
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
1135139 - Databus
[Tip-TNF 194320]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:18
mid: 02 64
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
1123173 - Databus
[Tip-TNF 239588]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 19
Mileage: 45222 km
Date: 2011.01.01
Time: 11:30:17
System run time: 177.2 s
mid: 02 E0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
End----------(Elapsed Time: 01:46, VBatt start/end: 12.6V/12.5V)-----------
