MK7.5 Digital Cockpit retrofit
Reaper1
Does it matter if I Use a 791A or 791B cluster? Seller said the only difference is manufacturing date.
And do you guys have any experience with a cockpit off Aliexpress? not the knockoff, Im talking about Chinese OEM.
Cuzoe
Yes the manufacture date is different. The B units were manufactured later... So they have later software/hardware revision. There is no guarantee an A unit can be upgraded to a B, if you care about that.
If you have a later Mk7 the B unit is the better choice. Can't help with regard to the Chinese OEM units.
mannymoda
Canada
2019 Alltrack Execli
The install I just completed was with a B unit from China via AliExpress. Dealer had no issues coding it for Imo/CP.
From what I understand, if you have a mk7.5, the B version is the way to go. Price difference is not worth going for the earlier HW/SW.
Specifically, the part I purchased was 5G1 920 791B
mannymoda
Canada
@mannymoda Are you positive these faults were but present (even intermittently) before the AID?
If so... go through your AID long coding (with experimental) and then through adaptations as well, noting anything you see that has to do with ACC and Emergency Stopping... Almost certainly something is coded as not installed or not active.
I am positive that these faults were not present prior to the AID install.
I will go through the coding again. Must be a rogue bit somewhere in there :)
bobloblawGTI
DC
2019 GTI SE 6MT
Erase it from your mind, as I have! You shouldn't be touching that anyway since the power symbol still rotates. Be civilized and use the steering wheel controls.
Or do what I did which is replace the volume knob on your screen with the tuner knob (sans symbol) from a different screen!
ksurl
Socal
GTI MK 7.5
Hey just want to report my experience with this install.
Model: 2018 Golf GTI SE NAR
Parts:
5G1 920 891B - display
5G0 857 189B AAH - trim
I also had a straight through fiber cable courtesy of @bobloblawGTI but actually ended up not using it since I do not have navigation or fender audio. If anyone wants it, I’ll pay it forward with just cost of shipping.
Rented vas5054a obd tool from @brownnugen
Programmed by @simaservis1108
Keys, mileage, component protection
Highly recommended if you can get your hands on a vas5054a obd tool and save the hassle with a dealer bumbling it. Just need a laptop with a usb port and decent internet connection.
Overall, pretty happy with it so far.
Some tips:
When putting the left air vent trim back, the vent may have sagged back into the dash so open the side panel where the fuses are to be able to push it back up and support it while fitting the trim back.
If using torx bits with extensions if you don't have a solid screwdriver set, use some electrical tape to secure the extension so it doesn’t fall into the steering wheel column (ask me how I know).
No need to open glovebox or right side panel if not running fiber to mib.
