MK7.5 Digital Cockpit retrofit
mannymoda
Canada
2019 Alltrack Execli
Finally got it to accept the procedure!!! :)
As you had suspected @Cuzoe , once the steering angle was sorted, all the other faaults melted away.
The only one that remains is on 5F....Check Software Version Management
A couple of other issues, the maps don't load up on the AID.....just an endless "loading maps" message.
I also get a TPMS deactivated message but I think it is looking for an direct TPMS system which I don't have.
Cuzoe
Still the same fault really... where in the process did it fail?
Got me as I was responding, haha... awesome!
Also some code tags would be nice, haha.
Code:
Scan goes in here
- As for the 5F fault... https://www.audienthusiasts.com/Application_SVMError.html
- The TPMS message is probably long coding in dash.
- For the maps there are some adaptations that need to be made in 5F... I'll find the link here in a few minutes OG guide, has coding/adaptations in the first post.
---- Safe to assume you connected the MOST (fiber optic) between radio in the glove box and your AID?
Nuje
Island near Vancouver
2015 Sportwagen TDI
As for having the maps appear in the AID, from my experience....
Module 5F (Information Electr.) - ADAPTATIONS
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps; (make sure this is OFF; @bbusato had this as adapting to ON, but with that setting, I had no maps in the AID; changing it back to OFF gave me maps in the AID)
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture; adapt from OFF to ON
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most; adapt from OFF to ON
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode; adapt from RLE to H264
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode; adapt from OFF to MOST_streaming
Weird that the code tags are still making everyone scroll.
(This is what it should look like:)
Code:
Wednesday,23,November,2022,14:15:14:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0  HEX-V2 CB: 0.4622.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: 3VWH17AU9KM521113   License Plate: 1
Mileage: 45225km-28101mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 3C 42 44 47
          4B 52 5F 69 A5 CA D6 D7
VIN: 3VWH17AU9KM521113   Mileage: 45225km-28101miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---    CVN: C87BA4D6
   Coding: 311D00322476002F1000
   Shop #: WSC 00066 790 00424
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS020_VW37.rod
   VCID: 46D55605582413EB9DF-8012
   VINID: 0E69D804746525B7450810410C70F68BA1
1 Fault Found:
17178 - Databus
          U1123 00 [047] - Received Error Message
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 20:46:13
                    Engine RPM: 1532.50 /min
                    Normed load value: 30.2 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 13 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 11.445 V
                    Unlearning counter according OBD: 40
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
                    Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
                    Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
                    Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
                    Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: 0010 0101
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 018     HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01907241007 CVN: 0000F57F
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 59EF8D79F99A8C13C0D-800C
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 52499000000175
   Coding: 43FA6AA13022096D80780301A0C629C2560C9001C005943436435050F0A94B0B0040010312121212B435351919323200
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
   VCID: 0655960518A4D3EBDDF-8052
2 Faults Found:
0295 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 59
                    Mileage: 45225 km
                    Date: 2011.01.02
                    Time: 01:43:09
0297 - Steering Angle Sensor
          B1168 F2 [137] - Not Initialized
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 19
                    Mileage: 45225 km
                    Date: 2011.01.02
                    Time: 01:47:21
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0524995000
   Coding: 132C0C0723
   Shop #: WSC 00066 790 00160
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D75109652218F3945-8010
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05
   Coding: 02020024200118010104004C12151008
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 48C9583D5230059B6F3-801C
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86408101907IF
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 00066 790 00395
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3F7F153669E03B21-802E
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190702  043 0551
   Serial number: 97022066190718200736
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: SAY19M07D29H07M13S38
   Coding: 0008DD
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 BK    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0160
   Serial number: 0100200620180C300539
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000137089R19220
   Coding: 0271167911
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF7559A16AC45338D-8004
3 Faults Found:
13637426 - Databus
          U1123 00 [009] - Received Error Message
          [Tip-TNF 202621]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:17
13679386 - Databus
          [Tip-TNF 231800]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 45225 km
                    Date: 2011.01.02
                    Time: 01:47:21
13688835 - Databus
          [Tip-TNF 226614]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.02
                    Time: 01:21:00
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 350000C941FFC728949C810520400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D14C0D6E1821FB83B-8010
5 Faults Found:
2055 - Databus
          U1122 00 [009] - Implausible Message
          [Tip-TNF 224741]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 45225 km
                    Date: 2011.01.02
                    Time: 01:47:22
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: 0.00 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
                    Status_ACC_System: ACC_irreversible error
0803 - Databus
          [Tip-TNF 200959]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:17
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 12.8 V
2101 - Databus
          [Tip-TNF 201050]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:17
0928 - Databus
          U1122 00 [008] - Implausible Message
          [Tip-TNF 226082]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:17
2068 - Databus
          [Tip-TNF 208229]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:17
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 J    HW: 5Q0 959 655 J
   Component: AirbagVW20    010 0830
   Serial number: 003GCR0CJKCZ
   Coding: 8CCCFC00000000005000001AC24800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 47CB5B015F2E0AE3669-8012
   Seat occupied recognition passenger side:
   Subsystem 1 - Part No SW: 4M0 959 339 B    HW: 4M0 959 339 B
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000C78S6L
   Coding: 303136
   Crash sensor for side airbag: driver side:
   Subsystem 2 - Part No SW: -----------    HW: 480 002 108 19
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000BE524CE3.
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 008 19
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000005A18DBE3
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 4 - Part No SW: -----------    HW: 480 403 107 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B4F08AF87D64P
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 108 19
   Component: SideSensor_Pr  004 6149
   Serial number: 35200012A2C061F354D+
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 909 19
   Component: FrontSensor_D  004 6149
   Serial number: 3550001202CA45F192F5
   Coding: 2D2D2D
   Crash sensor for front airbag: front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 909 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001BEF08AF82D92-
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 01AD501DED88080802887A0F5401000080000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B0307B1E386CE83621-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 16091900840961
   Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
   GVL: 01C63C0000000600C0DC80000000C80010000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013025
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85CEA51014FBAB05F-803A
   Generator:
   Component: 0-00-0d-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 40180000057370028175
   Coding: 2FFFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: U13DCAC  H27 0810
   Serial number: 8005883
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00005.06.19
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
   VCID: 4CC1642D4648E9BB4BB-8018
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000220598015
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F15D9C1AAA45358D-8064
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0024
   Serial number: Y0006PLT16185
   Coding: 001000020000040000C481808080000000000000000000F400
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3D2739E90DF25033CC5-8068
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Part No SW: 5Q0 907 686 C    HW: 5Q0 907 686 C
   Component: HRE_Master    H12 0081
   Serial number: 0524726554
   Coding: 02012103
   ASAM Dataset: EV_HREntryHella 001028
   ROD: EV_HREntryHella_VW37.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0527161485
   Coding: 020121
1 Fault Found:
338048 - Databus
          [Tip-TNF 215225]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.02
                    Time: 01:20:59
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038927600805
   Coding: 003A13200400040000000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 4FFB7321B75ED2A32E9-801A
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000004280958
   Coding: 011000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  172 1081
   Coding: 930A0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F9705DAA60CD5B373-8004
1 Fault Found:
16130 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 45225 km
                    Date: 2011.01.02
                    Time: 02:10:05
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.50 V
                    Temperature: 34.0 °C
                    KFC: 3F
                    KFA: 00 02
                    Freeze frame conditions: 5F
                    uAdSensI_U1V2Filtered_gdu16: 1.20 V
                    uAdSensI_U5VFiltered_xdu16: 0.00000 V
                    uioUdNotFilt_xdu16: 14.61 V
                    uAdSensI_SwitchedKl30_xdu16: 14.56 V
                    NoInitCause_AsicSens: [0x01] ASC_CTRL_SAS_HL_ERR - Error discovered by the High level application
                    NoInitCause_RackPos_Rohwert: 00 00
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_KMN_RACKPOS_SET: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_WHLSPDPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05WEVL
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E050EA5D094BBAB45F-807A
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 05091900842308
   Coding: 000000050900211200110F01030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353721C935C28873045-8060
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46039925400235
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 4EC56E25B054DBAB25F-801A
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000004277407
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Serial number:
   Coding: 027312020000000041220002001828009F0508F401200405C6
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 33331FD13BB696432A1-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  254 8130
   Serial number: VWZ6ZMW2835791
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 BF    HW: -----------
   Component: NAR 2021  --- 1510
   Serial number: --------------------
1 Fault Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
          [Tip-TNF 196497]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 16
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:17
                    Voltage terminal 30: 12.9 V
                    Status_Software_Version_Management-module_name: C
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0447495495
   Coding: 0210000200000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 42DD4A15740C2FCBB17-8016
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 15071915K23323
   Coding: 000307020002020100221355C150490084000E20012000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D9401D7A003DDBA73-8014
3 Faults Found:
1135140 - Databus
          [Tip-TNF 194669]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:18
                    Control Module temperature: 31 °C
                    Outside temperature: 13.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 178.1 s
                    Voltage terminal 15: 12.6 V
                    mid: 02 65
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
1135139 - Databus
          [Tip-TNF 194320]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:18
                    mid: 02 64
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
1123173 - Databus
          [Tip-TNF 239588]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 19
                    Mileage: 45222 km
                    Date: 2011.01.01
                    Time: 11:30:17
                    System run time: 177.2 s
                    mid: 02 E0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 00804073720C
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B7E1C97542C873C45-8020
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2DF919DA6C13E0D-806C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:46, VBatt start/end: 12.6V/12.5V)-----------
mannymoda
Canada
Sorry about the Code Tag guys.....first time I tried it and managed to mess it up :(
@Cuzoe Got rid of the TPMS issue....long coding in the instrument cluster.
I will try the link for the 5F fault. Thanks
@Nuje Got the maps to work but like @bbusato, I needed ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps turned to ON for it to work. I can only have the NAV on either the dash or the infotainment screen....not both.
I can't seem to figure out how to get the map to expand in the AID. Tried the UP/Down arrows, the Left/Right arrows.....No go.
bobloblawGTI
DC
2019 GTI SE 6MT
You can only have maps in one or the other unless you have Discover Pro infotainment (the 9.2” screen with no knobs.)
When on the map screen in the AID, press the “ok” button on the right side of the steering wheel. That should expand the maps between the dials.
mannymoda
Canada
By the way, I thought I would paste the procedure that worked for me regarding the Steering Angle Sensor off of the VCDS forum:
This may be useful to someone that runs into the same problem.
Engine at idle.
[44-Steering Assist]
Rotate steering wheel 90deg left then center, 90deg right then center so steering wheel is level, front wheels pointed straight ahead.
[Security Access - 16]
Enter 19249
[Basic Settings - 04]
In Basic Settings, pick [MAS00815] Steering angle sensor
[Go!]
Rotate steering wheel all the way to the left, hold firmly against end stop for 5 seconds.
Rotate steering wheel all the way to the right, hold firmly against end stop for 5 seconds.
Center steering wheel, front wheel straight ahead.
Note: our testing of this would still be "Running", never got a message of "Finished Correctly"
[Stop]
Now a bunch of error messages and warnings will appear on the cluster, what messages you get can vary based on how the vehicles is equipped.
[Done, Go Back]
Now most warning messaged in instrument cluster should be removed.
[Close Controller, Go Back - 06]
Cycle the ignition off for 10 seconds.
Several other control modules will flag DTCs, "Databus" type codes that can now be cleared out.
Cuzoe
This is mostly correct, but there are MIB II Discover Pro units that are not MIB 2.5 (9.2" screen). I would guess the MIB II (non 2.5) is a bit more prevalent than the MIB 2.5 units.
There are even MIB I discover pro units, though I suspect you'll never see one in the states.
bobloblawGTI
DC
2019 GTI SE 6MT
That’s super interesting, I didn’t know that. I thought MIB 2 was either composition media or discover media in the states. This would have been pre-facelift cars with the 8” matte display that would have been MIB2 discover pro, yes? To my knowledge I’ve never seen a facelift 8” glass discover pro system.
mannymoda
Canada
@Cuzoe I remember reading one of your posts where you outlined how to get the cover art to show up on the AID. I can't seem to locate that thread now. Would you remember off the top of your head where I would find that option? If I remember correctly, it was a long coding option that was only available with the full listing.
Cuzoe
https://golfmk7.com/forums/index.php?threads/mk7-5-digital-cockpit-retrofit.348993/post-7881969
I always check the box to show experimental coding. You might see a neat option worth trying and if it doesn't work you just undo it, haha.
Anything that shows only in experimental just means it hasn't been verified by enough people for the folks at VCDS to confidently label it. It doesn't mean that you are doing something that is "unsupported," if that makes sense.
Cuzoe
I think the 8-in matte display came in some passat's here in the states, but I don't know if they are discover pro. A pre facelift golf outside of the US with an 8-in matte screen would have been Discover Pro, I assume.
I don't know the extent of à la carte options VW offers outside of North America though... technically the screens aren't a guaranteed indicator of anything other than the generation of MIB. You could have any of the MIB 2 screens (6 inch matte, 8 inch matte or 8 inch glass) and have MIB2 Composition Media, Discover Media or Discover Pro. Likewise, the 5-in screen could be any level of MIB1.
The only screen that is a good indication is 9 inch glass, which is MIB 2.5, which only came as Discover Pro. In hushed corners of some forums you'll find discussion of MIB 2 being modified to use the 9.2 inch screen, but we're not in one of those hushed corners, lol.
bobloblawGTI
DC
2019 GTI SE 6MT
:ROFLMAO: I still have dreams that 9 inch glass with the single knob... damn you for making me know about that!
mannymoda
Canada
Good morning all and happy Thanksgiving :)
A couple of faults reappear. They don't seem to affect the functionality of the vehicle in any way. I clear them successfully but after a while they reappear.
Hopefully someone has had this issue and found a solution.
2 Faults Found:
1218 - Databus
U1121 00 [008] - Missing Message
[Tip-TNF 204493]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 45260 km
Date: 2022.11.24
Time: 09:26:10
Control Module temperature: 33 °C
Voltage terminal 15: 12.1 V
Status_ACC_System: ACC_StandBy
1219 - Databus
[Tip-TNF 204494]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 45260 km
Date: 2022.11.24
Time: 09:26:10
Cuzoe
Erase it from your mind, as I have! You shouldn't be touching that anyway since the power symbol still rotates. Be civilized and use the steering wheel controls.
@mannymoda Are you positive these faults were but present (even intermittently) before the AID?
If so... go through your AID long coding (with experimental) and then through adaptations as well, noting anything you see that has to do with ACC and Emergency Stopping... Almost certainly something is coded as not installed or not active.
