MK7.5 Digital Cockpit retrofit
ksurl
US
GTI MK 7.5
I see you have a 2017 R. any reason it wouldn't work on a 2018 GTI? I've only see confirmations on a 791B and supposedly the only difference is parking/brake is a symbol instead of spelled out on ROW vs NAR
Acadia18
Rhode Island
2017 VW Golf R
Shouldn't be any reason it wouldn't work.
mannymoda
Canada
2019 Alltrack Execli
Good day fellow retrofitters. I finally got my AID unit installed and coded at the dealer for the component protection/immobilizer and to get the odometer reading set. I got some fault codes initially but thought I would be able to code them out......I was wrong. I would appreciate the help of the gurus here to point me in the right direction.
I have a 2019 Alltrack with all the bells and whistles. Most of the faults are Databus related.
Here is the latest VCDS log:
Tuesday,22,November,2022,23:29:28:16365 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.9.0.0 HEX-V2 CB: 0.4622.4 Data version: 20220830 DS341.0 [URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL] VIN: 3VWH17AU9KM521113 License Plate: 6 Mileage: 45222km-28099mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: AU-VW37 (3Q0) Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 3C 42 44 47 4B 52 5F 69 A5 CA D6 D7 VIN: 3VWH17AU9KM521113 Mileage: 45222km-28099miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 29-Left Light -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 39-Right Light -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 47-Sound System -- Status: OK 0000 4B-Multifunc. Module -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010 CA-Sunroof -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb Part No SW: 8V0 906 264 M HW: 06K 907 425 B Component: 1.8l R4 TFSI H13 0001 Revision: --H13--- CVN: C87BA4D6 Coding: 311D00322476002F1000 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_ECM18TFS0208V0906264M 001003 ROD: EV_ECM18TFS020_VW37.rod VCID: 46D55605582413EB9DF-8012 VINID: 0E69D804746525B7450810410C70F68BA1 1 Fault Found: 17178 - Databus U1123 00 [039] - Received Error Message Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 45222 km Date: 2011.01.01 Time: 11:27:20 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 21 °C Intake air temperature: 20 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.242 V Unlearning counter according OBD: 40 Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No Drivetrain coordinator: ACC fault status-ACC active although main switch off: No Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No Drivetrain coordinator: brake fault status-Deceleration sensor not available: No Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No Drivetrain coordinator: brake fault status-ESP system error: No Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No Drivetrain coordinator: brake fault status-Brake light implausible: No Readiness: 1110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb Part No SW: 0D9 300 018 HW: 02E 927 770 AS Component: DQ250-6A MQB H54 5201 Revision: 06454104 Serial number: TFK01907241007 CVN: 0000F57F Coding: 0014 Shop #: WSC 04742 780 00200 ASAM Dataset: EV_TCMDQ250021 001001 ROD: EV_TCMDQ250021.rod VCID: 59EF8D79F99A8C13C0D-800C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP Component: ESC H35 0108 Revision: 00000000 Serial number: 52499000000175 Coding: 43FA6AA13022096D80780301A0C629C2560C9001C005943436435050F0A94B0B0040010312121212B435351919323200 Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007 ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod VCID: 0655960518A4D3EBDDF-8052 1 Fault Found: 0295 - Steering angle sensor B1168 54 [137] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:10:05 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N Component: VWKESSYMQB 037 1307 Revision: 00037000 Serial number: 0524995000 Coding: 132C0C0723 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_KessyHellaMQBAB 004052 ROD: EV_KessyHellaMQBAB.rod VCID: 45D75109652218F3945-8010 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5GM 907 044 G HW: 5GM 907 044 G Component: Climatronic H04 2001 Revision: 00001K05 Coding: 02020024200118010104004C12151008 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_ACClimaBHBVW37X 006146 ROD: EV_ACClimaBHBVW37X_006_VW37.rod VCID: 48C9583D5230059B6F3-801C Fresh air blower control module (front): A/C pressure/coolant temperature sensor: No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 087 BA HW: 5Q0 937 087 BA Component: BCM PQ37BOSCH 036 0265 Revision: -------- Serial number: C86408101907IF Coding: 000000000000000000000000000000000000000000000000000000000000 Shop #: WSC 00066 790 00395 ASAM Dataset: EV_BodyContrModul1UDSBosc 019001 ROD: EV_BCMBOSCH_019_VW37.rod VCID: 7BA3F7F153669E03B21-802E Wiper motor control module: Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB Component: WWS 190702 043 0551 Serial number: 97022066190718200736 Coding: 0E4DDD Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB Component: RLHS 051 0206 Serial number: SAY19M07D29H07M13S38 Coding: 0008DD Humidity sensor: interior: Steering Column Switch: Subsystem 4 - Part No SW: 5Q1 953 521 BK HW: 5Q1 953 569 B Component: Lenks.Modul H23 0160 Serial number: 0100200620180C300539 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb Part No SW: 5QA 919 298 D HW: 5QA 919 298 A Component: PLA 3.0 12KH07 0050 Serial number: 000137089R19220 Coding: 0271167911 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_EPHVA2CAU3700000 009041 ROD: EV_EPHVA2CAU3700000.rod VCID: 51FF7559A16AC45338D-8004 1 Fault Found: 13637426 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 202621] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:10:05 ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A Component: ACC BOSCH MQB H11 0682 Coding: 350000C941FFC728949C810520400600000000000000000004 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_ACCBOSCHVW416 002008 ROD: EV_ACCBOSCHVW416_002_VW37.rod VCID: 44D14C0D6E1821FB83B-8010 4 Faults Found: 0803 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 200959] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 2 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:10:05 Control Module temperature: 32 °C Voltage terminal 15: 12.5 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error 2101 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 201050] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:10:04 Control Module temperature: 32 °C Voltage terminal 15: 12.5 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error 0928 - Databus U1122 00 [009] - Implausible Message [Tip-TNF 226082] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:10:04 Control Module temperature: 32 °C Voltage terminal 15: 12.5 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error 2068 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 208229] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:10:04 Control Module temperature: 32 °C Voltage terminal 15: 12.5 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J Component: AirbagVW20 010 0830 Serial number: 003GCR0CJKCZ Coding: 8CCCFC00000000005000001AC24800000065 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_AirbaVW20SMEVW37X 002144 ROD: EV_AirbaVW20SMEVW37X_VW37.rod VCID: 47CB5B015F2E0AE3669-8012 Seat occupied recognition passenger side: Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B Component: BF-Gewichtss. H14 0022 Serial number: IBH00000000000C78S6L Coding: 303136 Crash sensor for side airbag: driver side: Subsystem 2 - Part No SW: ----------- HW: 480 002 108 19 Component: SideSensor_Df 001 0887 Serial number: 35700000000BE524CE3. Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 3 - Part No SW: ----------- HW: 480 002 008 19 Component: SideSensor_Pf 001 0887 Serial number: 358000000005A18DBE3 Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 4 - Part No SW: ----------- HW: 480 403 107 19 Component: SideSensor_Dr 005 6149 Serial number: 3510001B4F08AF87D64P Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 5 - Part No SW: ----------- HW: 480 400 108 19 Component: SideSensor_Pr 004 6149 Serial number: 35200012A2C061F354D+ Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 6 - Part No SW: ----------- HW: 480 400 909 19 Component: FrontSensor_D 004 6149 Serial number: 3550001202CA45F192F5 Coding: 2D2D2D Crash sensor for front airbag: front passenger side: Subsystem 7 - Part No SW: ----------- HW: 480 400 909 19 Component: FrontSensor_P 005 6149 Serial number: 3560001BEF08AF82D92- Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 5G1 920 791 B HW: 5G1 920 791 B Component: KOMBI 404 4191 Coding: 01AD501DED88080802887A0F5401000080000000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_DashBoardVDDMQBAB 009058 ROD: EV_DashBoardVDDMQBAB_009_VW26.rod VCID: 2B0307B1E386CE83621-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C Component: GW MQB High 521 5366 Serial number: 16091900840961 Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000 Shop #: WSC 00066 790 00160 GVL: 01C63C0000000600C0DC80000000C80010000000000200000000000000000000 ASAM Dataset: EV_GatewNF 013025 ROD: EV_GatewNF_VW37.rod VCID: 6E85CEA51014FBAB05F-803A Generator: Component: 0-00-0d-00-04 Multifunction steering wheel control module: Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB Component: E221__MFL-DC1 H17 0052 Serial number: 40180000057370028175 Coding: 2FFFFF Inverter for electrical outlet: Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A Component: U13DCAC H27 0810 Serial number: 8005883 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:* 0CQ-907-554.clb Part No SW: 0CQ 907 554 J HW: 0CQ 525 130 Component: Haldex4Motion H55 7084 Serial number: HA1-00005.06.19 Coding: 0001 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_AllWheelContrHA1VW37X 004013 ROD: EV_AllWheelContrHA1VW37X_004.rod VCID: 4CC1642D4648E9BB4BB-8018 No fault code found. ------------------------------------------------------------------------------- Address 29: Left Light (J1018) Labels: 8V0-907-399.clb Part No SW: 8V0 907 399 D HW: 8V0 907 399 D Component: LCM_MLBevoH08 0014 ASAM Dataset: EV_LCMLeftHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW37.rod VCID: 47CB5B015F2E0AE3669-8012 No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A Component: ELV-MQBB H08 0021 Serial number: 19000220598015 Coding: 0800000000000000 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_ELVMarqMQBA0 002002 ROD: EV_ELVMarqMQBA0_VW37.rod VCID: 313F15D9C1AAA45358D-8064 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J810) Labels:* None Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 B Component: Sitzmemory H08 0024 Serial number: Y0006PLT16185 Coding: 001000020000040000C481808080000000000000000000F400 Shop #: WSC 00046 123 12345 ASAM Dataset: EV_SeatMemorDriveSide 002022 ROD: EV_SeatMemorDriveSide.rod VCID: 3D2739E90DF25033CC5-8068 No fault code found. ------------------------------------------------------------------------------- Address 39: Right Light (J1023) Labels: 8V0-907-399.clb Part No SW: 8V0 907 399 D HW: 8V0 907 399 D Component: LCM_MLBevoH08 0014 ASAM Dataset: EV_LCMRightHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW37.rod VCID: 47CB5B015F2E0AE3669-8012 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C Component: HRE_Master H12 0081 Serial number: 0524726554 Coding: 02012103 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_HREntryHella 001028 ROD: EV_HREntryHella_VW37.rod VCID: 3D2739E90DF25033CC5-8068 Lane change assistance control module 2: Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C Component: HRE_Slave H12 0081 Serial number: 0527161485 Coding: 020121 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F Component: TSG FS 006 0247 Serial number: 42038927600805 Coding: 003A13200400040000000000 Shop #: WSC 01383 790 50316 ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005 ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod VCID: 4FFB7321B75ED2A32E9-801A Rear Driver Side Door Control Module: Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB Component: Fond FHSG DRV 010 0004 Serial number: 00000000000004280958 Coding: 011000 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 5QM 909 144 B HW: 5QM 909 144 B Component: EPS_MQB_ZFLS 172 1081 Coding: 930A0000 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_SteerAssisMQB 015157 ROD: EV_SteerAssisMQB_015.rod VCID: 50F9705DAA60CD5B373-8004 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A Component: MIB2_lite_amp H40 0200 Revision: 00000001 Serial number: VWZ8Z1KMD05WEVL Coding: 2200000000AAAAAA000000000000 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003 ROD: EV_AMPMst12C1Gen2ALPI.rod VCID: 2E050EA5D094BBAB45F-807A No fault code found. ------------------------------------------------------------------------------- Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C Component: FCM MQB Low 002 0345 Serial number: 05091900842308 Coding: 000000050900211200110F01030000000000000000000000000000000000 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_MultiModulContiVW48X 002006 ROD: EV_MultiModulContiVW48X_002_VW37.rod VCID: 353721C935C28873045-8060 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F Component: TSG BFS 006 0247 Serial number: 46039925400235 Coding: 003A13200400040000000000 Shop #: WSC 01383 790 50316 ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005 ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod VCID: 4EC56E25B054DBAB25F-801A Rear Passenger Door Control Module: Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB Component: Fond FHSG PSG 010 0004 Serial number: 00000000000004277407 Coding: 091000 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B Component: MU-S-NS-US 853 0890 Serial number: Coding: 027312020000000041220002001828009F0508F401200405C6 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_MUStd4CDELP 001001 ROD: EV_MUStd4CDELP_VW26.rod VCID: 33331FD13BB696432A1-8066 Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D Component: ABT_Std-2_Nav 254 8130 Serial number: VWZ6ZMW2835791 Data carrier: Subsystem 2 - Part No SW: 5NA 919 866 BF HW: ----------- Component: NAR 2021 --- 1510 Serial number: -------------------- 1 Fault Found: 1555 - Check Software Version Management B201A 00 [009] - - [Tip-TNF 196497] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:10:04 Voltage terminal 30: 12.6 V Status_Software_Version_Management-module_name: C ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N Component: Anhaenger H27 0264 Revision: 8A001003 Serial number: 0447495495 Coding: 0210000200000000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_TrailFunctGener2Hella 001008 ROD: EV_TrailFunctGener2Hella_VW26.rod VCID: 42DD4A15740C2FCBB17-8016 No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A Component: MQB_B_MFK H12 0610 Serial number: 15071915K23323 Coding: 000307020002020100221355C150490084000E20012000 Shop #: WSC 01383 790 50316 ASAM Dataset: EV_MFKBoschMQBB 002041 ROD: EV_MFKBoschMQBB_002.rod VCID: 40D9401D7A003DDBA73-8014 3 Faults Found: 1135140 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 194669] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:25:16 Control Module temperature: 31 °C Outside temperature: 13.5 °C Vehicle speed: 0.00 km/h System run time: 2299.6 s Voltage terminal 15: 12.6 V mid: 02 65 Status of camera: operational Engine_Running_Info: 0 Software_Info_4: 0 Software_Info_3: 1 Software_Info_2: 6 Software_Info_1: 0 1135139 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 194320] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:25:16 Control Module temperature: 31 °C Outside temperature: 13.5 °C Vehicle speed: 0.00 km/h System run time: 2299.6 s Voltage terminal 15: 12.6 V mid: 02 64 Status of camera: operational Engine_Running_Info: 0 Software_Info_4: 0 Software_Info_3: 1 Software_Info_2: 6 Software_Info_1: 0 1123173 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 239588] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:25:16 Control Module temperature: 31 °C Outside temperature: 13.5 °C Vehicle speed: 0.00 km/h System run time: 2299.3 s Voltage terminal 15: 12.6 V mid: 02 E0 Status of camera: operational Engine_Running_Info: 0 Software_Info_4: 0 Software_Info_3: 1 Software_Info_2: 6 Software_Info_1: 0 ------------------------------------------------------------------------------- Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb Part No SW: 4K0 907 594 AC HW: 4K0 907 594 Component: SAD_STG_1 006 0002 Coding: 00804073720C Shop #: WSC 01383 790 50316 ASAM Dataset: EV_SunRoofCONTIAU736 009011 ROD: EV_SunRoofCONTIAU736_009_VW37.rod VCID: 75B7E1C97542C873C45-8020 No fault code found. ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb Part No SW: 7P5 941 572 A HW: 7P5 941 572 A Component: LED1L H06 0002 ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003 ROD: EV_LEDMinMaxL_KEBODAVW481.rod VCID: 392F2DF919DA6C13E0D-806C No fault code found. ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb Part No SW: 7P5 941 572 A HW: 7P5 941 572 A Component: LED1R H06 0002 ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003 ROD: EV_LEDMinMaxL_KEBODAVW481.rod VCID: 392F2DF919DA6C13E0D-806C No fault code found. End----------(Elapsed Time: 01:45, VBatt start/end: 13.2V/13.0V)-----------
ksurl
US
GTI MK 7.5
If you paste in code format it may be collapsible.
Other than the error, does everything work and drive fine?
mannymoda
Canada
The vehicle drives fine...I do get the following errors on the AID unit upon bootup:
ACC
ECS
TPMS
Park Assist
Hill Assist
Cuzoe
Lots of databus missing message faults, which mean a given module is not receiving the data it expects based on how it is coded. Often this means some other module is not coded properly to send those messages. Your only new module is the AID so I would look through the long coding, using VCDS helper, and make sure to check the boxes for some of your car's equipment (looks like ACC, Park Assist, Lane Assist at least).
But before that I would try to clear that steering angle sensor fault in the ABS module. You may be able to clear it just by turning the steering wheel full lock one way to full lock the other way. Do it with ignition on at least, but should work (and be easier) with engine running. You can run steering angel sensor basic settings with VCDS but i've never done that, lock-to-lock has always cleared the fault.
It would not surprise me if clearing that fault clears up everything else. Makes sense that ACC, lane assist and park assist need to know where the wheels are pointed. But ESC really needs to know where the wheels are pointed. In a turn the outside wheel travels faster and if your car doesn't know which way the wheel is turned it can't know which is the outside wheel, meaning it can't account for the expected difference in wheel speeds... so ESC is not working.
TPMS fault often shows up with that ESC fault because our TPMS is based on wheel speed. And the engine fault is likely related as well because the ESC system, when working, manages power if/when wheel spin is noted.
mannymoda
Canada
Thanks for your input @Cuzoe . I tred to clear the steering angle sensor without success. I took a peak at the measuring values and found IDE04443-MA300815 Steering Angle Sensor Malfunction. I then had a look at the long coding but VCDS does not provide any labels for that module. I verified and my long coding string has not changed post install. Anyone have a similarly equipped 2019 that can share their long code?
Cuzoe
Long coding won't clear a basic settings issue. Measuring values might be showing malfunction because basic settings haven't been done.
Are you saying you ran the steering angle sensor basic settings and cannot complete the procedure?
There are a few links to try, some of the same info in them...
https://forums.ross-tech.com/index.php?threads/4224/
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60)#Basic_Setting
https://www.youcanic.com/reset-vw-steering-angle-sensor/
mannymoda
Canada
I tried the non VCDS and VCDS procedure without success.
Getting a Not Initialized error on the steering angle sensor now (44-Steering Assit)
Wednesday,23,November,2022,14:15:14:16365 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.9.0.0 HEX-V2 CB: 0.4622.4 Data version: 20220830 DS341.0 www.Ross-Tech.com VIN: 3VWH17AU9KM521113 License Plate: 1 Mileage: 45225km-28101mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: AU-VW37 (3Q0) Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 3C 42 44 47 4B 52 5F 69 A5 CA D6 D7 VIN: 3VWH17AU9KM521113 Mileage: 45225km-28101miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 29-Left Light -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 39-Right Light -- Status: OK 0000 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4B-Multifunc. Module -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010 CA-Sunroof -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb Part No SW: 8V0 906 264 M HW: 06K 907 425 B Component: 1.8l R4 TFSI H13 0001 Revision: --H13--- CVN: C87BA4D6 Coding: 311D00322476002F1000 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_ECM18TFS0208V0906264M 001003 ROD: EV_ECM18TFS020_VW37.rod VCID: 46D55605582413EB9DF-8012 VINID: 0E69D804746525B7450810410C70F68BA1 1 Fault Found: 17178 - Databus U1123 00 [047] - Received Error Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 45222 km Date: 2011.01.01 Time: 20:46:13 Engine RPM: 1532.50 /min Normed load value: 30.2 % Vehicle speed: 0 km/h Coolant temperature: 13 °C Intake air temperature: 15 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 11.445 V Unlearning counter according OBD: 40 Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No Drivetrain coordinator: ACC fault status-ACC active although main switch off: No Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No Drivetrain coordinator: brake fault status-Deceleration sensor not available: No Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No Drivetrain coordinator: brake fault status-ESP system error: No Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No Drivetrain coordinator: brake fault status-Brake light implausible: No Readiness: 0010 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb Part No SW: 0D9 300 018 HW: 02E 927 770 AS Component: DQ250-6A MQB H54 5201 Revision: 06454104 Serial number: TFK01907241007 CVN: 0000F57F Coding: 0014 Shop #: WSC 04742 780 00200 ASAM Dataset: EV_TCMDQ250021 001001 ROD: EV_TCMDQ250021.rod VCID: 59EF8D79F99A8C13C0D-800C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP Component: ESC H35 0108 Revision: 00000000 Serial number: 52499000000175 Coding: 43FA6AA13022096D80780301A0C629C2560C9001C005943436435050F0A94B0B0040010312121212B435351919323200 Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007 ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod VCID: 0655960518A4D3EBDDF-8052 2 Faults Found: 0295 - Steering angle sensor B1168 54 [008] - Missing Calibration / Basic Setting Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 2 Reset counter: 59 Mileage: 45225 km Date: 2011.01.02 Time: 01:43:09 0297 - Steering Angle Sensor B1168 F2 [137] - Not Initialized MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 19 Mileage: 45225 km Date: 2011.01.02 Time: 01:47:21 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N Component: VWKESSYMQB 037 1307 Revision: 00037000 Serial number: 0524995000 Coding: 132C0C0723 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_KessyHellaMQBAB 004052 ROD: EV_KessyHellaMQBAB.rod VCID: 45D75109652218F3945-8010 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5GM 907 044 G HW: 5GM 907 044 G Component: Climatronic H04 2001 Revision: 00001K05 Coding: 02020024200118010104004C12151008 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_ACClimaBHBVW37X 006146 ROD: EV_ACClimaBHBVW37X_006_VW37.rod VCID: 48C9583D5230059B6F3-801C Fresh air blower control module (front): A/C pressure/coolant temperature sensor: No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 087 BA HW: 5Q0 937 087 BA Component: BCM PQ37BOSCH 036 0265 Revision: -------- Serial number: C86408101907IF Coding: 000000000000000000000000000000000000000000000000000000000000 Shop #: WSC 00066 790 00395 ASAM Dataset: EV_BodyContrModul1UDSBosc 019001 ROD: EV_BCMBOSCH_019_VW37.rod VCID: 7BA3F7F153669E03B21-802E Wiper motor control module: Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB Component: WWS 190702 043 0551 Serial number: 97022066190718200736 Coding: 0E4DDD Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB Component: RLHS 051 0206 Serial number: SAY19M07D29H07M13S38 Coding: 0008DD Humidity sensor: interior: Steering Column Switch: Subsystem 4 - Part No SW: 5Q1 953 521 BK HW: 5Q1 953 569 B Component: Lenks.Modul H23 0160 Serial number: 0100200620180C300539 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb Part No SW: 5QA 919 298 D HW: 5QA 919 298 A Component: PLA 3.0 12KH07 0050 Serial number: 000137089R19220 Coding: 0271167911 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_EPHVA2CAU3700000 009041 ROD: EV_EPHVA2CAU3700000.rod VCID: 51FF7559A16AC45338D-8004 3 Faults Found: 13637426 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 202621] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:17 13679386 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 231800] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45225 km Date: 2011.01.02 Time: 01:47:21 13688835 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 226614] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.02 Time: 01:21:00 ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A Component: ACC BOSCH MQB H11 0682 Coding: 350000C941FFC728949C810520400600000000000000000004 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_ACCBOSCHVW416 002008 ROD: EV_ACCBOSCHVW416_002_VW37.rod VCID: 44D14C0D6E1821FB83B-8010 5 Faults Found: 2055 - Databus U1122 00 [009] - Implausible Message [Tip-TNF 224741] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45225 km Date: 2011.01.02 Time: 01:47:22 Control Module temperature: 28 °C Voltage terminal 15: 14.6 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error 0803 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 200959] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 2 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:17 Control Module temperature: 37 °C Voltage terminal 15: 12.8 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error 2101 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 201050] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:17 Control Module temperature: 37 °C Voltage terminal 15: 12.8 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error 0928 - Databus U1122 00 [008] - Implausible Message [Tip-TNF 226082] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 59 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:17 Control Module temperature: 37 °C Voltage terminal 15: 12.8 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error 2068 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 208229] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:17 Control Module temperature: 37 °C Voltage terminal 15: 12.8 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_irreversible error ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J Component: AirbagVW20 010 0830 Serial number: 003GCR0CJKCZ Coding: 8CCCFC00000000005000001AC24800000065 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_AirbaVW20SMEVW37X 002144 ROD: EV_AirbaVW20SMEVW37X_VW37.rod VCID: 47CB5B015F2E0AE3669-8012 Seat occupied recognition passenger side: Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B Component: BF-Gewichtss. H14 0022 Serial number: IBH00000000000C78S6L Coding: 303136 Crash sensor for side airbag: driver side: Subsystem 2 - Part No SW: ----------- HW: 480 002 108 19 Component: SideSensor_Df 001 0887 Serial number: 35700000000BE524CE3. Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 3 - Part No SW: ----------- HW: 480 002 008 19 Component: SideSensor_Pf 001 0887 Serial number: 358000000005A18DBE3 Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 4 - Part No SW: ----------- HW: 480 403 107 19 Component: SideSensor_Dr 005 6149 Serial number: 3510001B4F08AF87D64P Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 5 - Part No SW: ----------- HW: 480 400 108 19 Component: SideSensor_Pr 004 6149 Serial number: 35200012A2C061F354D+ Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 6 - Part No SW: ----------- HW: 480 400 909 19 Component: FrontSensor_D 004 6149 Serial number: 3550001202CA45F192F5 Coding: 2D2D2D Crash sensor for front airbag: front passenger side: Subsystem 7 - Part No SW: ----------- HW: 480 400 909 19 Component: FrontSensor_P 005 6149 Serial number: 3560001BEF08AF82D92- Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 5G1 920 791 B HW: 5G1 920 791 B Component: KOMBI 404 4191 Coding: 01AD501DED88080802887A0F5401000080000000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_DashBoardVDDMQBAB 009058 ROD: EV_DashBoardVDDMQBAB_009_VW26.rod VCID: 2B0307B1E386CE83621-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C Component: GW MQB High 521 5366 Serial number: 16091900840961 Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000 Shop #: WSC 00066 790 00160 GVL: 01C63C0000000600C0DC80000000C80010000000000200000000000000000000 ASAM Dataset: EV_GatewNF 013025 ROD: EV_GatewNF_VW37.rod VCID: 6E85CEA51014FBAB05F-803A Generator: Component: 0-00-0d-00-04 Multifunction steering wheel control module: Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB Component: E221__MFL-DC1 H17 0052 Serial number: 40180000057370028175 Coding: 2FFFFF Inverter for electrical outlet: Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A Component: U13DCAC H27 0810 Serial number: 8005883 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:* 0CQ-907-554.clb Part No SW: 0CQ 907 554 J HW: 0CQ 525 130 Component: Haldex4Motion H55 7084 Serial number: HA1-00005.06.19 Coding: 0001 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_AllWheelContrHA1VW37X 004013 ROD: EV_AllWheelContrHA1VW37X_004.rod VCID: 4CC1642D4648E9BB4BB-8018 No fault code found. ------------------------------------------------------------------------------- Address 29: Left Light (J1018) Labels: 8V0-907-399.clb Part No SW: 8V0 907 399 D HW: 8V0 907 399 D Component: LCM_MLBevoH08 0014 ASAM Dataset: EV_LCMLeftHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW37.rod VCID: 47CB5B015F2E0AE3669-8012 No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A Component: ELV-MQBB H08 0021 Serial number: 19000220598015 Coding: 0800000000000000 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_ELVMarqMQBA0 002002 ROD: EV_ELVMarqMQBA0_VW37.rod VCID: 313F15D9C1AAA45358D-8064 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J810) Labels:* None Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 B Component: Sitzmemory H08 0024 Serial number: Y0006PLT16185 Coding: 001000020000040000C481808080000000000000000000F400 Shop #: WSC 00046 123 12345 ASAM Dataset: EV_SeatMemorDriveSide 002022 ROD: EV_SeatMemorDriveSide.rod VCID: 3D2739E90DF25033CC5-8068 No fault code found. ------------------------------------------------------------------------------- Address 39: Right Light (J1023) Labels: 8V0-907-399.clb Part No SW: 8V0 907 399 D HW: 8V0 907 399 D Component: LCM_MLBevoH08 0014 ASAM Dataset: EV_LCMRightHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW37.rod VCID: 47CB5B015F2E0AE3669-8012 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C Component: HRE_Master H12 0081 Serial number: 0524726554 Coding: 02012103 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_HREntryHella 001028 ROD: EV_HREntryHella_VW37.rod VCID: 3D2739E90DF25033CC5-8068 Lane change assistance control module 2: Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C Component: HRE_Slave H12 0081 Serial number: 0527161485 Coding: 020121 1 Fault Found: 338048 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 215225] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 45222 km Date: 2011.01.02 Time: 01:20:59 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F Component: TSG FS 006 0247 Serial number: 42038927600805 Coding: 003A13200400040000000000 Shop #: WSC 01383 790 50316 ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005 ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod VCID: 4FFB7321B75ED2A32E9-801A Rear Driver Side Door Control Module: Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB Component: Fond FHSG DRV 010 0004 Serial number: 00000000000004280958 Coding: 011000 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 5QM 909 144 B HW: 5QM 909 144 B Component: EPS_MQB_ZFLS 172 1081 Coding: 930A0000 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_SteerAssisMQB 015157 ROD: EV_SteerAssisMQB_015.rod VCID: 50F9705DAA60CD5B373-8004 1 Fault Found: 16130 - Steering Angle Sensor B1168 F2 [009] - Not Initialized Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 19 Mileage: 45225 km Date: 2011.01.02 Time: 02:10:05 Motor status: 01 System status: Driving mode Supply voltage: 14.50 V Temperature: 34.0 °C KFC: 3F KFA: 00 02 Freeze frame conditions: 5F uAdSensI_U1V2Filtered_gdu16: 1.20 V uAdSensI_U5VFiltered_xdu16: 0.00000 V uioUdNotFilt_xdu16: 14.61 V uAdSensI_SwitchedKl30_xdu16: 14.56 V NoInitCause_AsicSens: [0x01] ASC_CTRL_SAS_HL_ERR - Error discovered by the High level application NoInitCause_RackPos_Rohwert: 00 00 RP_VALCNTSAV: not activated RP_DIAGJOB: not activated RP_RPS: not activated RP_KMN_RACKPOS_SET: not activated RP_STARTUP: not activated RP_L2PLAUSI: not activated RP_INDEXPLAUSI: not activated RP_WHLSPDPLAUSI: not activated RP_RUKUCNTR: not activated RP_UNDERVOLT: not activated RP_CNTERR: not activated ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A Component: MIB2_lite_amp H40 0200 Revision: 00000001 Serial number: VWZ8Z1KMD05WEVL Coding: 2200000000AAAAAA000000000000 Shop #: WSC 00066 790 00424 ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003 ROD: EV_AMPMst12C1Gen2ALPI.rod VCID: 2E050EA5D094BBAB45F-807A No fault code found. ------------------------------------------------------------------------------- Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C Component: FCM MQB Low 002 0345 Serial number: 05091900842308 Coding: 000000050900211200110F01030000000000000000000000000000000000 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_MultiModulContiVW48X 002006 ROD: EV_MultiModulContiVW48X_002_VW37.rod VCID: 353721C935C28873045-8060 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F Component: TSG BFS 006 0247 Serial number: 46039925400235 Coding: 003A13200400040000000000 Shop #: WSC 01383 790 50316 ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005 ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod VCID: 4EC56E25B054DBAB25F-801A Rear Passenger Door Control Module: Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB Component: Fond FHSG PSG 010 0004 Serial number: 00000000000004277407 Coding: 091000 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B Component: MU-S-NS-US 853 0890 Serial number: Coding: 027312020000000041220002001828009F0508F401200405C6 Shop #: WSC 00066 790 00160 ASAM Dataset: EV_MUStd4CDELP 001001 ROD: EV_MUStd4CDELP_VW26.rod VCID: 33331FD13BB696432A1-8066 Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D Component: ABT_Std-2_Nav 254 8130 Serial number: VWZ6ZMW2835791 Data carrier: Subsystem 2 - Part No SW: 5NA 919 866 BF HW: ----------- Component: NAR 2021 --- 1510 Serial number: -------------------- 1 Fault Found: 1555 - Check Software Version Management B201A 00 [009] - - [Tip-TNF 196497] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 16 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:17 Voltage terminal 30: 12.9 V Status_Software_Version_Management-module_name: C ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N Component: Anhaenger H27 0264 Revision: 8A001003 Serial number: 0447495495 Coding: 0210000200000000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_TrailFunctGener2Hella 001008 ROD: EV_TrailFunctGener2Hella_VW26.rod VCID: 42DD4A15740C2FCBB17-8016 No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A Component: MQB_B_MFK H12 0610 Serial number: 15071915K23323 Coding: 000307020002020100221355C150490084000E20012000 Shop #: WSC 01383 790 50316 ASAM Dataset: EV_MFKBoschMQBB 002041 ROD: EV_MFKBoschMQBB_002.rod VCID: 40D9401D7A003DDBA73-8014 3 Faults Found: 1135140 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 194669] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:18 Control Module temperature: 31 °C Outside temperature: 13.5 °C Vehicle speed: 0.00 km/h System run time: 178.1 s Voltage terminal 15: 12.6 V mid: 02 65 Status of camera: operational Engine_Running_Info: 0 Software_Info_4: 0 Software_Info_3: 1 Software_Info_2: 6 Software_Info_1: 0 1135139 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 194320] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:18 Control Module temperature: 31 °C Outside temperature: 13.5 °C Vehicle speed: 0.00 km/h System run time: 178.1 s Voltage terminal 15: 12.6 V mid: 02 64 Status of camera: operational Engine_Running_Info: 0 Software_Info_4: 0 Software_Info_3: 1 Software_Info_2: 6 Software_Info_1: 0 1123173 - Databus U1123 00 [009] - Received Error Message [Tip-TNF 239588] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 19 Mileage: 45222 km Date: 2011.01.01 Time: 11:30:17 Control Module temperature: 31 °C Outside temperature: 13.5 °C Vehicle speed: 0.00 km/h System run time: 177.2 s Voltage terminal 15: 12.6 V mid: 02 E0 Status of camera: operational Engine_Running_Info: 0 Software_Info_4: 0 Software_Info_3: 1 Software_Info_2: 6 Software_Info_1: 0 ------------------------------------------------------------------------------- Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb Part No SW: 4K0 907 594 AC HW: 4K0 907 594 Component: SAD_STG_1 006 0002 Coding: 00804073720C Shop #: WSC 01383 790 50316 ASAM Dataset: EV_SunRoofCONTIAU736 009011 ROD: EV_SunRoofCONTIAU736_009_VW37.rod VCID: 75B7E1C97542C873C45-8020 No fault code found. ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb Part No SW: 7P5 941 572 A HW: 7P5 941 572 A Component: LED1L H06 0002 ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003 ROD: EV_LEDMinMaxL_KEBODAVW481.rod VCID: 392F2DF919DA6C13E0D-806C No fault code found. ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb Part No SW: 7P5 941 572 A HW: 7P5 941 572 A Component: LED1R H06 0002 ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003 ROD: EV_LEDMinMaxL_KEBODAVW481.rod VCID: 392F2DF919DA6C13E0D-806C No fault code found. End----------(Elapsed Time: 01:46, VBatt start/end: 12.6V/12.5V)-----------
