xabhax
- Manchester Township, New Jersey
- 15 GTI
Wasnt that what he was asking? The gauges on the cluster were zoomedThat just changes the size of the gauges, from small to large and vice versa
I was talking about the scale of the actual map in the cluster.Wasnt that what he was asking? The gauges on the cluster were zoomed
19868 U015500 Lost Communication With Instrument Panel Cluster (IPC) Control Module (00100111 active/static)
It does, unfortunately.Looks like a remnant of the programming process. I would clear it see if it comes back
This is what's in my OBD11 history last time I did a scan; if there's a way to get more data than that, happy to try!Do you have a full scan?
OBDeleven vehicle history log
Date: 2021-08-10 08:28:28
Year: 2019
Body type: D5 Hatchback
Engine: DKFA kW ( hp) l
Mileage: 9257 mi
Full scan
Control Units: 24
Fault count: 1
Control Units:
01 Engine
System description: R4 2.0l TFS
Software number: 5G0906259Q
Software version: 0007
Hardware number: 06K907425J
Hardware version: H13
Faults:
U015500 - Lost Communication With
static
03 Brakes
System description: ESC
Software number: 5Q0614517DR
Software version: 0108
Hardware number: 5Q0614517BM
Hardware version: H45
Faults:
No trouble codes found
08 Air Conditioning
System description: AC Manuell
Software number: 5GM907426G
Software version: 2001
Hardware number: 5GM907426G
Hardware version: H03
Faults:
14 Wheel Dampening
System description: DAEMPFUNGS-SG
Software number: 5Q0907376B
Software version: 0121
Hardware number: 5Q0907376A
Hardware version: H17
Faults:
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655J
Software version: 0830
Hardware number: 5Q0959655J
Hardware version: 010
Faults:
19 Gateway
System description: GW MQB High
Software number: 3Q0907530AA
Software version: 5366
Hardware number: 3Q0907530C
Hardware version: 521
Faults:
29 Light Control Left
System description: LCM_MLBevo
Software number: 8V0907399D
Software version: 0014
Hardware number: 8V0907399D
Hardware version: H08
Faults:
32 Lock Electronics
System description: Quersperre
Software number: 0CQ907554P
Software version: 8043
Hardware number: 0CQ907554P
Hardware version: H55
Faults:
2B Steering Column Lock
System description: ELV-MQBB
Software number: 2Q0905861A
Software version: 0021
Hardware number: 2Q0905861A
Faults:
39 Light Control Right
Faults:
17 Dashboard
System description: KOMBI
Software number: 5G1920891A
Software version: 3195
Hardware number: 5G1920891A
Hardware version: 408
Faults:
3C Lane Change Assistant Right
System description: HRE_Master
Software number: 5Q0907686C
Software version: 0081
Hardware number: 5Q0907686C
Hardware version: H12
Faults:
13 Adaptive Cruise Control
System description: ACC BOSCH MQB
Software number: 5Q0907572P
Software version: 0682
Hardware number: 3QF907572A
Hardware version: H11
Faults:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5QN909144A
Software version: 5081
Hardware number: 5QN909144A
Hardware version: 507
Faults:
42 Driver Door
System description: TSG FS
Software number: 5Q4959593M
Software version: 0247
Hardware number: 5Q4959593F
Hardware version: 006
Faults:
75 Telematics
System description: OCULowMQBUS
Software number: 5QE035285A
Software version: 0570
Hardware number: 5QE035285A
Hardware version: 009
Faults:
A9 Structure Borne Sound
System description: SAS-GEN 2
Software number: 5G0907159G
Software version: 0001
Hardware number: 4H0907159A
Hardware version: H07
Faults:
D6 LED Module Left
System description: LED1L
Software number: 7P5941572A
Software version: 0002
Hardware number: 7P5941572A
Hardware version: H06
Faults:
4B Multifunction Module
System description: FCM MQB Low
Software number: 3Q0907338C
Software version: 0345
Hardware number: 3Q0907338C
Hardware version: 002
Faults:
D7 LED Module Right
System description: LED1R
Faults:
5F Multimedia
System description: MU-S-S-US
Software number: 3Q0035844B
Software version: 0890
Hardware number: 3Q0035844B
Hardware version: 724
Faults:
52 Passenger Door
System description: TSG BFS
Software number: 5Q4959592M
Hardware number: 5Q4959592F
Faults:
B7 Start System Interface
System description: VWKESSYMQB
Software number: 3Q0959435L
Software version: 1204
Hardware number: 3Q0959435L
Hardware version: 037
Faults:
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937087BA
Software version: 0265
Hardware number: 5Q0937087BA
Hardware version: 036
Faults:
Reseated all the connectors, including the back of the cluster and behind the MIB unit; everything looks okay there. Fender audio is working fine. Dealer checked it out yesterday during the install and couldn't figure it out. I read in another thread there was something about copying coding info from the old cluster, anyone know what that might entail? Paging resident guru @CuzoeThe retrofit didn't require a jumper harness did it?
I would start by checking connections at the back of the cluster. If everything is fine there if the dealer is friendly they should look at it if is wasn't there before
I wouldn't say I'm a guru, but I have spent a lot of money on this stuff, haha. The dealer did my AID (poorly might I add, they didn't input mileage and didn't do any coding really). I did not directly copy coding from my old cluster to the new but I used at as a reference of sorts. It took me about a week of messing around to get everything coded to my liking. For sure the dealer took care of component protection and immo/key pairing but I can't say what else they did/did not do.
I had no faults when I left, but later that day I got a CEL for Glow Plug Indication, which I've had intermittently since that day. I won't go into it but I have a hard time with it being a coincidence that on the day I had the dash replaced I got a fault for Glow Plug Indication... seeing as how the Glow Plug indicator is in the dash. My (that) dealer sucks though, offered no support for that CEL or for failing to enter mileage.
But as @xabhax said, it looks like a coding issue. I would think there's some feature selected (start in the long coding) that your car doesn't have. As an example, DSG selected as installed when you have a manual, the dash would be looking for the mechatronic (sp?) module. Might be worth re-seating both connectors on the cluster as well.
I'm inclined to agree; thanks! Is there any of that coding documented somewhere to reference or just go off the long coding names as best I can decipher them?I copied coding from my old to aid cluster and got all sorts of weird codes. Not that one though. Go through and code it a byte at a time
Now that I think about it, I'm actually not seeing any station logos show up in the cluster; possible it's a bad MOST cable?Yes if you want anything else over the MOST bus (contact photos, radio station logos, etc.)
No if you don't.
