I'm not sure if it helps, but for those having a problem with headlight aiming - this is how to tell the car "true-horizontal" with
OBD11 (it's a 2 x part process):
Important: Make sure the car is fully settled on its suspension and that the vehicle is on level ground
Procedure 1
- Ignition-ON, engine-OFF (IOEF)
- Fire-up OBD11 software and connect to dongle
- Navigate to the Control Units screen - select the module that has the Basic setting error (the error can appear in different modules)
- On the Module screen - scroll-down the options and select Basic Settings
- Select Basic headlamp setting and start the procedure
- Adjust headlights using the manual screws as referenced against a suitable aiming target - or, if no adjustment needed - go to next step
- Wait a period of time (suggest 10 seconds)- then stop the procedure
Procedure 2 (still in
Basic Settings)
- Select Acknowledge basic setting and start the procedure
- The reference settings from Procedure 1 above should now be "recorded" in the module
- Wait a period of time (suggest 3 seconds)- then stop the procedure
- Back-out of the module, clear any error codes and exit OBD11 software (don't forget to disconnect the OBD11 dongle)
Don
