My car is non performance package. A track day with stock non performance brakes would be a complete waste, and anyone with any experience knows that. They would be shot after a lap and I don’t have time to hit the track whenever, I need to make my time count.
Porterfield makes pads? NO WAY?!?! Who would spend $300 per set of pads and $100 plus per pair for OEM blanks (so that’s up to $800 for those following along) PLUS I’d still need additional street pads since this is my daily driver so figure another $140 and we’re pushing $1000 once you add fluid.
Who here thinks riding the ragged edge on non PP brakes for $1000 makes more sense than a proper four corner upgrade for $2000? “Crickets”. You didn’t “just” pay $500 for your braking upgrade, my under 2k figure is all in for all four corners including (calipers, carriers, rotors, pads, lines, and fluid.
Back to the TCR. First off it has even larger front brakes than my car, which require 19s to run...I own summer and all season sets of 18s and won’t be changing that, just adding an additional track set and track pads. Also, what’s the TCR weigh vs my car? More, by 500# or so? NO WAY?! Maybe, just maybe that’s why Volkswagen uses bigger brakes on the performance package models as well as the R (since 2008) which are exactly what I added to the rear.
I feel there is a risk of others being misled by your example. Jake $1250 for the ST-40s was a good initial deal but you're ignoring the cost of consumables. It'll quickly add up if you plan to head back again for another track day. I could not replicate the higher than usual numbers you quoted so please see the attached spreadsheet
I carefully priced out each of the brake kits before I purchased the 986 calipers. Required braking capacity and total running costs were the two determining factors. My driving instructors have so far been impressed with the setup. I believe they have the required experience and judgement. You still have not shared the feedback from your instructor(s).
Today a proper ST-40 setup would cost me $2,800. Rotors are $200-$350 each, depending on availability, plus over $300 for race pads. FCP doesn't carry race pads for Stoptech so it is not a one time cost like with a 986 setup.
The ST-40s will cost you over x2 the Macans and 4x the 986 setup to run on track. You may have less than $2000 invested today, but without proper pads and spares you are not ready for another track day.
It sounds like track pads are going to blow your mind. You need to report back once you upgrade.
$300 for pads? Correct, that is what track pads cost and for the ST-40s it is over $300.
Luckily, I still haven't outgrown the DTC-30s on the rears which are $110. Proper track pads will last for several hundred hours on the rear. You posted dealer prices for the rear pads. Please do not pay that much for pads.
986 calipers were $126 each and brackets were $280. Still under $600 after a rebuild, lines, and fluid. I was wrong, it should be called the $600 kit. You're right to be pedantic, but you need to focus on total cost.
TCR GTI runs 18x10 wheels not 19s and so could you.
It is not 500lbs less. It weighs 2,833lbs and your car should be around 3,100. 267lbs is still significant but they are driving harder than a street or trackday car, right?
Wouldn't these same engineers want to include the larger rear performance package brakes on a race car? Or it is simply for asthetics, like the slotted rotors on the ST-40? (Slotted rotors will help during hour 2 of an endurance race but neither of use have that opportunity)
