trevorwilson
- Glasgow
- 2018 1.6 TDI SE
I have a 2018 1.6 TDI SE DSG and it has run perfectly it's whole life (45k miles). I had it serviced recently and ever since then it has run badly for a minute or two when it is started after it has been left for a few hours. When I start the engine after it has been idle for approx. 12 hours or more it starts just fine. Then, after a few seconds it seems to misfire (I know that's probably not the right term but you can put me right ) and the engine runs very rough for about a minute, almost stalling at times. Revving the engine a little doesn't really help. As soon as I have driven for a couple of minutes the engine runs normally again. Did a 500 mile drive yesterday and it all appeared to run as normal once I had got past the initial jittery phase in the morning.
- It seems to be related more to the length of time the car has been sat idle rather than the temperature of the engine - after four hours yesterday the engine was completely cold but it started and ran perfectly fine, but then when I left it overnight the problems resumed this morning.
- The garage think it is dirty injectors. I have just run through a tank of fuel with Forte Injector Cleaner but the problem is getting worse, not better. Also, why would that start just after a service?
- The garage said there were no error codes relating to the engine when they checked it.
