GrisGTI
- Salt Lake City
- 2015 GTI
I'm looking for some additional help to see if I've missed anything.
My car has cold start rough idle, that appeared after I did a media blast to clean the valves (I had also changed the PCV valve and the water pump/thermostat). It wasn't bad at first, just a sputter every once in a while when cold and showing improvement as the car warmed up. But it progressively became worse until the car registered both an ECP and check engine light. It shows a misfire in cylinder #2. Using OBDEleven I verified that it was only cylinder #2 that is misfiring. I replaced all plugs and all coil packs. Nothing. I switched the coil pack and plug from cylinder #1. Still same outcome—misfire in cylinder #2. I read on this forum that you should do a throttle body adaptation if you have removed the throttle body (which I did to change to water pump/thermostat). I used OBDEleven to run a throttle body adaptation. Symptoms got way worse. Instead of throwing a code sometimes it now throw a code immediately after the idle settled down after start. And it now shows a Hide Cylinder code. I assume it's shutting down cylinder #2. I took the throttle body off to clean it out. It actually looked pretty clean, but I wiped it down some more. I also put a scope down cylinder #2, but didn't see anything obvious.
My next guess is simply a bad injector. Before I spend a good chunk of money on replacing the injectors. Is there a way for me to confirm I just have a bad injector?
What would your next move be? Would you just clean them and put it back together? Or would you spend the big bucks to replace all of them?
