Misfire after Unitronic Stage 2 IS20
jeffdemara
Vancouver, BC
Well, I just got the car up to an E20 blend for fuel, and it took away ALL the timing corrections I was seeing on logs. BUT, the same issue is still persisting, this time Cylinder 2 misfire. (Before I was getting Cyl 1 and 3 pretty consistently...) Pretty much only happens during a shift while in boost during a pull. For this example, I've been doing pulls in 3rd gear (car feels great during the pull and I feel NO loss of power!), but when it goes to shift to 4th during the pull, it then displays the EPC light and goes into limp mode.
StorableComa
SoCal, USA
17 GSW S FWD
Are you DSG or Manual?
Not Uni, but I have something similar happen in a non repeatable fashion on my Slush box. Shifting around 6.7k it seemed to hesitate from third, then bam EPC light and car runs like shit post shift. Have to stumble to the breakdown and restart the engine to get it to run.
Scanned codes, Misfire cyl 3 and 4 with a cylinder deactivation. A few tranny implausable codes, but the timestamp seems to suggest that popped from trying to limp over on two cylinders.
jeffdemara
Vancouver, BC
I'm regular 6spd auto slushbox.
jeffdemara
Vancouver, BC
This may or may not provide any insight as it's just a still photo of the log, but wanted to post it up anyways. Made a few notes, arrows, and circles for some things I found interesting.
Guessing the green dip I have circled is when the transmission shifts and there's a temporary reduction in torque/output.
TwinDad
Fort Lee, NJ
This is in the tune then. It's something with the post shift boost and afr. I would have Uni revise it
8055WAGEN
MICHIGAN
Just for some solidarity, I had similar troubles with the IS20 Unitronic tune, I would regularly get a P0234 Overboost error. Now I am IS38.
tigeo
That is a different issue that I had as well and a revised tune sorted it. He's got something else going on. I've had misfires with both my IS20 and 38 tunes related to crappy fuel quality and using a few gallons of E85 fully sorts it.
8055WAGEN
MICHIGAN
Agreed. Also have experienced the wonders that E does for us.
tigeo
Scanner
Whitby, ON
2018 Golf TSI 1.8
I have the same combo Uni Stage 2 IS20 + 6sp auto. I had misfires earlier when Stage 1+, random, the same way as you've mentioned when shifting 3rd to 4th gear. All solved by new OEM Golf plugs with a shorter gap + APR coils. My car has been smooth, with zero misfires, for more than 40k km. Here in Ontario, I've been using the Petro Canada Ultra 94, no E pumps.
jeffdemara
Vancouver, BC
So your car would misfire during the shift, throw an EPC light, and go into limp mode? And you changed plugs and coils and it solved it for you?
I've changed my plugs so far, but not coils yet. Car only has 44,000kms.. but maybe it's time?
Mk7tsi3door
Nova Scotia
What gap? 25?
GTI Jake
Charlotte, NC
It’s going to be an issue with something you just changed.
-tune
-DV on the is20 (is it a known good part?)
-fuel
It’s highly unlikely coil packs just so happened to go bad out of nowhere the day you slapped a new turbo on. I’d start with double checking the tune and Dv
jeffdemara
Vancouver, BC
-tune
-fuel
I can swap the known to be good diverter valve from my original is12 on to my is20 pretty easily. Will give it a try just to be sure and eliminate the possibility.
ZuMBLe
NY
Alltrack 6MT
I'm just gonna say. You should not need to mix ethanol in to the tank to get rid of misfires or excessive knock in a OTS tune. This is crazy.
@jeffdemara
The lean area after the shift could be because the ECU is not reverting to the full load table after the shift. My car exhibits this problem also, but I just tune around it by making the the last row in my part throttle fuel table match what I want a full load.
What are you using to log and display the log?
