JerseyDrew77
- Virginia & NC
- 2016 TR GTI S 6MT
standard Pzero AR Racing spec
And you liked those over the PS4S?
gawd yes the Pzero’s I’d had are pretty close to the PSC2 on my setup atleastAnd you liked those over the PS4S?
unfortunately I will have to remove the PSC2 off my car because they run too wide and rub which I did not before.
dude PSC2 N0 sidewalls and top shoulder run more like a 255 I'm running 1.50 camber now with et47 front and et38 rear its like virgin tight. Tirerack is really good at there tread width measurement which helps me but not sure if the standard versions are a tad more narrow which I have a set sitting in the garage.
If I can find a full set I'm going to go with Pzero Corsa's which run narrow, then I guess sell this set if possibleConsider adding some more camber if you have issue with the other set, generally around -2.5 to -2 front and -2 to -1.8 rear is acceptable for the street and ideal for track
